New audio toy
how much do you think this costs, or should cost?
$200. or less
18%
 18%  [ 2 ]
$500. or less
72%
 72%  [ 8 ]
$750. or more
9%
 9%  [ 1 ]
Total Votes : 11
Posted: Mon Oct 20, 2008 9:20 pm    Post subject:
WTS wrote:
Well I don't know how much of a jaw dropping improvement I would expect because you are going to be running this through a solid state amp.
I never noticed a connection between systems I really was impressed with and whether they were using SS or tube amps. i'm not sure where the magic lye's, some say impedance matching, others say it's this or that but the perfect combo escapes me so far.
WTS
Posted: Mon Oct 20, 2008 11:09 pm    Post subject:
Impedance matching doesn't play much of a role unless you're talking about balanced lines. Some tube based power amps did have different taps on the output tranformer depending on the Z of the speaker connected to it.
I've heard the perfect combo and it is SS, but like I said before tubes have a certain glow to them, not very true to the actual music but easy to listen to. But this debate can get into some pretty messy arguments as to what is better tubes/SS, vinyl/digital (CD).
Walter
Posted: Wed Oct 22, 2008 6:15 pm    Post subject:
I didnt vote 'cause its impossible to say. What kind of tube amp is it? It could be a cheaply done, solder by numbers job and sound crappy.
As far as tube sound goes, efficient speakers are generally better because tubes put out less power. But when you match a good tube amp with nice speakers, the sound you get is very engaging.
Posted: Wed Oct 22, 2008 6:49 pm    Post subject:
well I thought I posted enough info inthe first post to show that it's not a solder by numbers job, it's all hand soldered point to point, no PCB. However here's a little bit more
circuit on this unit is a straight-line with gain- meaning that it does'nt use any other phase invertors, or other circuitry than what is required to pass the signal cleanly and smoothly. I've heard that my preamp has more in common with the bottlehead , foreplay than differences in terms of sound- albeit mine has a smoother overall presentation, and the foreplay has a more analytical sound to it.
The 3.6 uses 18 gauge o.f.c. straded wire for the signal, metalized poly caps in the signal path, metal oxide resistors throughout, and solid-core copper wire (16 gauge) for the power. The power supply filter caps are xicon 25 volt units. The connectors are gold-plated brass.
I am not pairing this with a tube amp either, I don't have high efficeincy speakers and tubed power amps just aren't for me. I am runing pair of these
http://www.monarchyaudio.com/STreview.html
The Pre-amp I bought is being specially built with XLR balanced output jacks to match my pair of Monarchy SM-70 mono blocks.
