I love CRTs, but ...
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8
Elaine Benes
Posted: Sat Dec 06, 2008 1:20 am    Post subject:
VideoGrabber wrote:
Elaine,
If what you're claiming was true, all those films would have their original bitrates of ~28 MBit/sec, so they'd be easy to discern from other variants.
Which is why they were so highly valued as downloads even though the films themselves had been posted from other sources many times. Their files were huge (30GB range) compared to the same film from HBO HD, etc generally being in the 10-14ish GB range for file size.
You're a newsgroup user, no ? These were posted at least a year ago... 5c is circumventable in the digital domain too, as Japanese WoWo movies are posted regularly too now...Again, the super high bitrates is exactly WHY people like them...
VideoGrabber
Posted: Sat Dec 06, 2008 4:25 am    Post subject:
That's interesting, Elaine. Thanks for the information. You're certainly correct about what the file size would have been.
> You're a newsgroup user, no? <
Well, I was a heavy newsgroup user, back in the 70's, 80's, and 90's, and participated in a lot of discussions over the years. But not at all in the last 5-8 years, though I am aware that large files get segmented and streamed in various alt.bin groups.
> 5c is circumventable in the digital domain too, as Japanese WoWo movies are posted regularly too now <
I have to say I'm more than a little surprised (I would have expected to have caught a hint of it through tech channels), but it sounds like you know more about it than I do, so it would be silly for me to argue the point. Thanks for educating me.
- Tim
Posted: Sat Dec 06, 2008 4:27 am    Post subject:
Such a polite young man Mr. Green
Elaine Benes
Posted: Sat Dec 06, 2008 11:26 am    Post subject:
Large files...haha, "The Dark Knight" BD was over 48GB !
kschmit2
Posted: Mon Dec 08, 2008 2:45 pm    Post subject:
What he's claiming is true. The captures are raw bitstream captured from before the mpeg2 decoder. No analog conversion is involved.
The actual video bitstream on D-Theater tapes is 21.50 Mbps for titles with DTS audio, and 22.95 Mbps for titles w/o DTS audio. The transport stream mux rate with nullpackets is 28 Mbps in both cases.
Dolby Digital streams are 576 kbps, DTS streams are 1536 kbps.
Most titles have a hardcoded telecine sequence, bus some use telecine metadata (i.e. they essentially are progressive on the tape - same approach as on HD DVDs).
VideoGrabber
Posted: Tue Dec 09, 2008 7:37 am    Post subject:
Kai,
thanks for the details on the transport streams. I knew the TS achieved the constant (CBR) 28 MBit/sec with NULL packets. I didn't know the bitrate breakdowns though. The audio from D-Theater was always exceptional, and that explains why.
It also explains how it was accomplished, which was as I expected... a hardware hook that simply bypassed the encryption technique. So, in a sense, Dave is still correct that 5C and D-Theater protections have not been cracked, but simply circumvented. A moot point, in a sense.
- Tim
kschmit2
Posted: Tue Dec 09, 2008 9:51 am    Post subject:
there is no "D-Theater" protection. That was all marketing hype.
The tapes only use 5C protection.
And any encryption system is broken once you can access the data w/o a key. Only the licensor of a circumvented/broken encryption system will claim otherwise. Their robustness requirements simply weren't adequate.
VideoGrabber
Posted: Wed Dec 10, 2008 4:47 am    Post subject:
Kai wrote:
> there is no "D-Theater" protection. That was all marketing hype. <
Question So why won't my D-Theater tapes play on my Mitsu 2000 D-VHS deck, only my JVC-30K, 40K, or 5U? Is it just a codec thing, and not an encryption thing?
- Tim
Elaine Benes
Posted: Wed Dec 10, 2008 8:25 am    Post subject:
VideoGrabber wrote:
:?: So why won't my D-Theater tapes play on my Mitsu 2000 D-VHS deck, only my JVC-30K, 40K, or 5U? Is it just a codec thing, and not an encryption thing?
Regular 5c encrypted tapes won't play in those either, will they ?
Your Mits decks don't have built in MPEG decoders(unlike the JVC's), so you have to transfer the bitstream to an outboard decoder for an image, right ? Wasn't 5c encryption designed to prevent exactly that ?Supposedly no digital transfer whatsoever depending on the flag ?
VideoGrabber
Posted: Wed Dec 10, 2008 9:13 am    Post subject:
Thanks for the followup, Elaine.
> Regular 5c encrypted tapes won't play in those either, will they ? <
Yes, they play (and record) 5C just fine. It would be kind of silly if they didn't.
> Your Mits decks don't have built in MPEG decoders(unlike the JVC's), <
That is correct. No analog encoders OR decoders, and thus only digital bitstreams in and out.
> so you have to transfer the bitstream to an outboard decoder for an image, right? <
Yes. I can play them through my Samsung SIR-T165 tuner/switcher, or my LG LST-3410A HD-DVR. They can also be played on a FW-equipped TV (which I don't have), or through any of my JVC D-VHS decks (as long as Record isn't engaged). There are folks with Mitsu decks (rock-solid transports) playing their 5C tapes back through JVC deck (decoders), with totally non-functional transports.
> Wasn't 5c encryption designed to prevent exactly that? Supposedly no digital transfer whatsoever depending on the flag? <
No digital transfer to an untrusted recipient. All of the above devices I mentioned above can handle the 5C handshaking requirements. That capability is not limited to JVC decks.
It's always possible I was doing something wrong, the one time I tried playing one of my D-Theater tapes on my Mitsu, which is why I was inquiring. But since I "knew" (had read) that it wasn't possible for it to work, I didn't spend any time trying to finagle it.
- Tim
Elaine Benes
Posted: Wed Dec 10, 2008 9:26 am    Post subject:
But I thought the whole point of 5c was there were varying degrees of protection easily set via a flag ? What if the D-Theater tapes simply have a copy never flag set ?
VideoGrabber
Posted: Wed Dec 10, 2008 11:59 am    Post subject:
> the whole point of 5c was there were varying degrees of protection easily set via a flag ? <
Yes, that's correct.
> What if the D-Theater tapes simply have a copy never flag set ? <
Then they can never be copied. That doesn't mean they can't ever be played. Smile
- Tim
KoBE
Posted: Fri Mar 25, 2011 1:45 pm    Post subject:
What kind of equipment did they use to capture the raw bitstream?
Page 8 of 8
