XG-750: Uneven Geometry Issues
Satanier
Posted: Wed Sep 10, 2008 5:32 am    Post subject: XG-750: Uneven Geometry Issues
I'm having some serious geometry issues, bad enough its bothering me when watching video.
I tried EVERYTHING in alignment, I can't fix it. Source is 1920x1080 from HTPC, windows desktop properties.
Here is a picture::: Look at the circles. There's almost no distortion from the camera here, its just as bad as it looks. The center is an egg and all 4 outer circles are different.
Also, two other things:
1. Is it normal for the corners to be dimmer than the center?
2. I still cant get the left //// right side of my green, and to a somewhat lesser extent blue, to focus right, and its really bad in the upper left corner. In the upper left corner theres some kind of distortion that pulls things out of square, like when dragging a computer window up to that corner, and the focus is just awful there. I followed instructions to neutralize all electronic focus controls, then adjusted the focus pots for perfect center focus, then I checked beam astigmatism, then I adjusted electronic focus, it just wont dial in on the left side especially, and the right as well. Upper left corner is worst of all.
These issues are really bothering me, and preventing me from fully enjoying my new toy. Any insight would be awesome!
kschmit2
Posted: Wed Sep 10, 2008 7:34 am    Post subject:
did you start by resetting Geometry, Convergence and Point Convergence?
And did you set phase properly?
Elaine Benes
Posted: Wed Sep 10, 2008 10:20 am    Post subject:
What is your screen size and shape ? How far from the screen is your projector ie. screen center to green lens center ? Have you measured to determine it is EXACTLY perpendicular to the screen surface ? What are your lens flapping tabs set to for each color ?
When you did your initial Signal Entry for this input, what information did you choose, ie. Default, Temporary, etc ?
dropzone7
Posted: Wed Sep 10, 2008 12:35 pm    Post subject:
Of course others here know better than me but at first glance I would say that your linearity is off. Look at the height and width of the blocks on your top row compared to your bottom row. If you have converged to that geometry then of course all three colors are off. You need to turn off red and blue and get your linearity correct for green. Then go back and work on converging red and blue to your corrected green.
Yes, it is normal to see a somewhat dimmer image near the edges of the screen compared to the middle. This is especially true if your screen surface is "hotspotting" at all. It might not be that your edges are dimmer but that your center is actually brighter due to this hotspotting. I use a piece of Designer White Laminate for my screen and have observed this in my setup. As for focus, it takes a lot of practice and careful setup to get corner and edge focus looking as good as center focus. This is especially true if you are maximizing your rasters. Corner focus will suffer a bit so it's a trade off of a larger raster and image size, utilizing more phosphur or a smaller raster and image size, achieving better overall focus. The choice is yours but personally I would rather have a big screen with good center focus than a smaller one with perfect focus. After all, most of what you look at on screen is in the center and not at the far edges so chances are that you won't notice less than perfect focus at the edges during most movies.
"Coffee is for Closers."
Posted: Wed Sep 10, 2008 2:51 pm    Post subject:
I agree, if the pix above is not distorted, then the V lin is off. Also check the lin balance, done by pressing 'ctrl' and 'lin.
Satanier
Posted: Wed Sep 10, 2008 5:23 pm    Post subject:
Phase was set properly.
I reset Geometry, Convergence, and Point Convergence then I adjusted Alignment keystone and amplitude to roughly fit my screen, I then did full convergence. No point convergence was used.
Satanier
Posted: Wed Sep 10, 2008 5:25 pm    Post subject:
Good to hear that slightly dimmer corners are normal on all screen types, mine is budget blackout cloth. I may paint it eventually with something. Also good to hear that side focus being less is somewhat normal, although I feel like its worse on the left side than the right. I don't notice it in movies though, you are right.
Satanier
Posted: Wed Sep 10, 2008 5:27 pm    Post subject:
My screen is a 100" 16:9 screen. The projector is around 9 feet from the screen or so, I measured only roughly by eye. The green wasn't measured to be exactly perpendicular to the screen, but it's close enough that I don't think it could be causing this. The distortion is also vertical, not horizontal. When I selected the initial input I chose default I believe. My lens flapping is set according to the NEC manual.
Posted: Wed Sep 10, 2008 5:28 pm    Post subject:
Have you seen this?
http://www.curtpalme.com/CRTSetupGuide.shtm
Good work BTW on that image with no point. Let that picture be a benchmark on how accurate you can get convergence without a bit of point. Kal, take note, might be an idea to post that pix in the NEC PG/XG section regarding excessive point use. I can write something up...
Satanier, would you mind posting a simular pix of the internal crosshatch pattern?
Satanier
Posted: Wed Sep 10, 2008 5:29 pm    Post subject:
I had played with the alignment v lin and lin balance for a while last night, and was unable to get it to look better, I can try again later today.
Posted: Wed Sep 10, 2008 5:34 pm    Post subject:
From the pix it looks like it's your main V lin that's off. Shrink the top, stretch the bottom.
Generally the lin balance controls need to be set to 0 unless you're mounting on some screwy angle.
You can also use the point on green to move the raster a bit in various areas, then adjust the R and B on top of the green image, but try the lin and lin balance controls first.
Satanier
Posted: Wed Sep 10, 2008 6:00 pm    Post subject:
I adjusted my Vertical Linearity to -85% and was able to get it looking MUCH better!!! Linear Balance is at 0///0. It's no longer noticeable in movies!!! The 4 outside circles are still squished slightly downward, but its even all on 4 now(even though the pic makes the right ones look wider)
It's OK to have horiz amplitude at 100 to fill my screen right? And my projector is mounted 3 feet off the ground, on a table.
I wonder if there is a way to pull those side circles in a bit, I tried horiz amplitude but that affects the center circle as well, and I lose screen size.
Well, here is where I stand right now:
Posted: Wed Sep 10, 2008 6:04 pm    Post subject:
You're being very anal about this setup.... that's a good thing..Very Happy
Yes, V lin can sometimes be close to maxed out, ditto for H width.
I would now use the point controls to tweak the green geometry to perfection, there's no control short of point that will allow the width of the outside edges to be adjusted. Like I said, massively good job on the convergence without using point so far!
Satanier
Posted: Wed Sep 10, 2008 6:27 pm    Post subject:
It's ok to have horizontal amplitude at max?
I tweaked my blue convergence a bit because it gone out of whack a bit, I updated my above image. Not quite perfect but better. The blue is SO hard to see, I often can't notice errors until I look at a picture of it.
Also, is it possible to fix the corner circles so they arent squashed a bit without affecting the center one? I should use point for this? Won't that blow up my c-board. I'm really just nitpicking at this point. Thank you for the help with the v lin.
Posted: Wed Sep 10, 2008 6:43 pm    Post subject:
That's some damned good work, Satanier. I think you get full membership in the CRT club for this effort - not bad at all so quickly. How much time do you think you've spent on it?
I'd be interested to see some closeup shots of the resolution hashes in ntest. It looks like you've got stuff pretty sharp, but of course it's hard to evaluate sharpness of a 1920-wide image with a 1500-wide photo... Smile
Satanier
Posted: Wed Sep 10, 2008 7:05 pm    Post subject:
Thank you, I couldn't have done it without the help of the people here. I've devoted most of my spare time to it over the past 4 days or so, most of the time has been spent learning, I think I could do a full setup in a couple of hours now. I'm actually getting my carpets done soon so I'll have to move it and then put it back, I should only have to do focus, and alignment and convergence I'm hoping, I shouldn't have to do any raster centering and beam astigmatism again I would hope.
Here are some shots from ntest, I'm not sure if these are resolution hashes, I used the "resolution" pattern. I didn't resize these to 1024 on computer, I left them at "small" size from camera.
The off white center rectangle encompassing the screen is some sort of artifact from the camera.
The grain you see is the material of my screen, I used manual focus on the camera as auto focus couldn't lock in on it.
The center line is where I had stitched two pieces of blackout together when the screen had been larger, I couldn't afford to buy a new piece so I reused this one, I'm going to paint over it eventually even though It's not really noticeable in movies.
The three blurry black dots you see are dust on my DSLR Sensor.
The Pictures:
Whole screen:
Center:
Corner:
Elaine Benes
Posted: Thu Sep 11, 2008 1:25 am    Post subject:
I'll bet the majority of your focus issues are caused by : "The projector is around 9 feet from the screen or so, I measured only roughly by eye. The green wasn't measured to be exactly perpendicular to the screen, but it's close enough that I don't think it could be causing this."
Pretty much exactly the opposite way you are supposed to physically set an NEC. They MUST be EXACTLY perpendicular to their screen, and exactly centered too...NEC's don't have infinitely variable lens flapping, they DEPEND on exact physical placement in order that the lenses can focus properly over the entire screen.
When you have to re-place your projector after the carpets are cleaned. Measure and place it so it is EXACTLY in the correct orientation to the screen and see if your focus is still an issue...
Bert Randolph
Posted: Thu Sep 11, 2008 8:54 am    Post subject:
These side-'circles' are not supposed to be exactly round, they are meant to be an 'egg' on this test pattern.
I am not exactly sure if thats what you are trying to achieve (making them perfect circular), just thought I would let you know in case Smile
Daniel.
kschmit2
Posted: Thu Sep 11, 2008 2:37 pm    Post subject:
Can you try the NEC Test Pattern Generator, please, and tell us how the circles look using that tool.
NEC Test Pattern Generator 1.0.rar
 Filename:  NEC Test Pattern Generator 1.0.rar
 Filesize:  134.12 KB
 Downloaded:  207 Time(s)
Satanier
Posted: Thu Sep 11, 2008 7:21 pm    Post subject:
Daniel.
They aren't an egg on my Dell 2407WFP-HC 24" LCD
