stevecagle59
Joined: 17 Jul 2008 Posts: 4 Location: Cape Canaveral Florida
| Posted: Sun Sep 07, 2008 5:12 pm Post subject: Goodies for the Marquee |
Hello everyone..
I'm looking for a little feedback on some project ideas. We are interested in extending the life of the CRT projector in particular the Electrohome/VDC Marquee projectors for the home theater market.
Project 1: Alignment, convergence in particular seems to be a problem area. We are currently designing a new modern system similar to the original ACON. The new unit will setup the projector up from scratch after the mechanical installation is complete. There is even an intelligent assist mode to help maximize the mechanical setup.
Project 2: The rev 3 VIM board that supports blending, they are rare but allow two projectors to have a vertical blend making two projectors into one display. We are considering building the blend board and offering it as an upgrade.
Project 3: A Software application that allows remote control of the Marquee via the serial port for single or multiple projector configurations, that’s a starting point but the sky is the limit. It is kinda handy to have a single point of control with multiple projectors. But, I’ll let you folks come up with the ideas.
So if you ever wanted custom hardware or software to make your CRT projector(s) have better performance and display a better picture, this is the time.
Please send me your wish lists, comments and ideas.
Steve
| Posted: Sun Sep 07, 2008 5:31 pm Post subject: |
The blending board would be great if it had HDMI input, Right now Moome HDMI cards and external blend units from Analog way and the TV-One units are what we are doing, TV-One actually just sold the entire two batches of their C2-2250/2255 units to mostly home theater enthusiests who have been saving up to blend(I have two of these)
For the blend VIM/softwear it should have 11 to 21 point global gamma adjustments and also possibly the same amount of point adjustment in the blendzone.
Better contrast modulation, maybe 12 zones instead of 9. Better lens' that focus better in the edges for blending.
Really only one Vim would be needed with an output to go to the other Vim, it have to be a package deal like the master vim and the secondary blending input Vim, this would keep cost down especially if it could be an add on to existing Vims to go into slot 2, and if more room is needed it could be added to the area where the quad decoder goes as this is not used in home theater anymore with A/V recivers doing the swithcing and out board scalers.
the new vime should have increased bandwidth to easily handle 1080p@72 HZ or higher.
Aslo a redesihgn of the focus coil, look at the design of the Kanto Denshi focus coil, it has a longer magnetic feild to focus the beam much better and the astig coils are right next to the tube for better spot control, maybe make a electronic contoled CPC magnet set?
Aslo get VDC to sell parts to us, they have refused to sell bellows and C-Elements for us who want to repair or convert our machines to LC units.
Ther eis more but i cant thinkl of it right now, i am sure more will chime in, Are you at VDC or another after market company?
| Description: |
| Kanto Denshi paten design for focus coils |
 Download |
| Filename: |
5113162.pdf |
| Filesize: |
688.21 KB |
| Downloaded: |
286 Time(s) |
| Posted: Sun Sep 07, 2008 6:01 pm Post subject: Re: Goodies for the Marquee |
| stevecagle59 wrote: | | Hello everyone.. |
Hi Steve, and welcome to the best CRT forum on the net.
I'm looking for a little feedback on some project ideas. We are interested in extending the life of the CRT projector in particular the Electrohome/VDC Marquee projectors for the home theater market. |
That's fantastic! Considering these projectors have a life span of 15-20 years that would keep us in CRT's for years to come.
If you could get this to 99% of a perfect setup I think it would be a huge marketing tool for all those that have heard CRT's are hard to setup. Also in your install manual you should add a procedure to maximize the raster usage before the final installation.
Shouldn't that be a horizontal blend? We're trying to do 2.35:1 on 12 -14 foot wide screen in most blending situations.
Also a value added product for the consumer. If you did offer this, along with the ACON3 ( or whatever you decide to name it ) an end user could follow the raster maximization instructions, mount the unit on the ceiling ( preferably with an included mount ) Hit the ACON3 system up for the alignment, and plug in an HDMI Bluray player out putting 1080p/24fps and have the VIM triple the frame rate to 72Hz for film content.
It would be a boon to also have 48HZ for those that prefer it, and 96Hz for 1080i ATSC film broadcasts. 120Hz would be great for those 720P/60 sports broadcasts, although that may be exceeding the bandwidth too much. For sure the 48/72HZ would be a must if you decided too add the frame rate doubling/tripling functionality to the VIM. Keep the RGBHV inputs too. Some of us are analog and prefer it to HDMI headaches.
Steve |
A simplified set of RS-232 commands would be great along side the advanced commands. Also adding a USB port is almost a must now due to the computer manufactures insistence that newer is better, not building new computers with RS-232ports. Keep the RS-232 and add USB control beside it. Many people try to control their projectors with a USB to RS-232 converter and find not every converter works properly. T.F.H, Time frustration and headaches going back and forth exchanging those converter could be prevented.
Give us the ultra high res tubes. I don't know the details of them other than what I have read here and previously at AVS. But it seems a 4k tube would be a feather in CRT's cap so to speak. Then we could run an external scaler and input 1080P tripled or quadrupled. Plus it would future proof our projectors. I've read about a higher output tube as well. More brightness would be great.
Increase the bandwith in the video chain, please see Mike Parker for details. Those 4K tubes would greatly benefit from the needed and necessary bandwidth increase.
Add color options to the cases. Many people like to match the colors of their projectors to their decors. Please prime the plastic before painting to prevent the paint form chipping off to easily.
Ship all the projectors with the darker green and the red C-elements in place so we don't need to do the conversion.
Keep the parts available. I'll second this one. We can't watch them if we cant service them.
That's all I can think of off the top of my head. I'll see what else I can come up with.
| Posted: Sun Sep 07, 2008 7:01 pm Post subject: |
Hello
To be useful, the blend board would need to scale, and render left and right image segments and take in HDMI and component.
| Posted: Sun Sep 07, 2008 7:37 pm Post subject: Re: Goodies for the Marquee |
| stevecagle59 wrote: | Hello everyone..
Project 1: Alignment, convergence in particular seems to be a problem area. We are currently designing a new modern system similar to the original ACON. The new unit will setup the projector up from scratch after the mechanical installation is complete. There is even an intelligent assist mode to help maximize the mechanical setup. |
alignment and convergence for a single marquee are some of the easiest set-ups for any CRT out there. The problem comes when you try to align and converge a Horizontal blend or stack. If your new system can somehow address that then it would be a meaningful feature.
| stevecagle59 wrote: | Please send me your wish lists, comments and ideas.
Steve | a little less hardball business practices towards the HT crowd would be a first good step. In the past we've had to deal with things like the doubling of tubes costs, C elements, and now a refusal to sell replacement bellows to us. I don't know who makes these decisions but it has made VDC at times a non-option for people looking to maintain or refurbish CRT's.
| Tim in Phoenix wrote: | Hello
To be useful, the blend board would need to scale, and render left and right image segments and take in HDMI and component. . | why do you think it needs to scale tim?Pretty much any DVD player and blue Ray already do excellent scaling.
The only thing the new card needs to do is accept a HDMI signal, split it, and send it to a second machine. It also needs to cost less than the $7500. TV1 scaler.
I like Athanasios idea of using the quad decoder expansion slot above the main VIM for a Blending board. I know the original blend card designed for the Marquee was a daughter-board on the main VIM but I doubt that option will handle HDMI inputs and deliver a seamless blend.
stevecagle59
| Posted: Sun Sep 07, 2008 7:38 pm Post subject: |
Thanks for your great input so far. All ideas will be given significant consideration.
Anyone care to estimate how many Marquee's are out there in the home theater market?
We would be happy to support other CRT brands but we would need detailed technical documentation.
Thanks Again!
| Posted: Sun Sep 07, 2008 8:02 pm Post subject: |
"We would be happy to support other CRT brands but we would need detailed technical documentation. "
A......A........A......., oh I just can't bring myself to say it.
_________________ Chip
| Posted: Sun Sep 07, 2008 8:44 pm Post subject: |
| Nashou66 wrote: |
The new vime should have increased bandwidth to easily handle 1080p@72 HZ or higher.
Athanasios |
All of this circuitry will need more room than the 02 slot. I would use the decoder slot. One also needs to keep an eye on added power consumption, will a more robust LVPS be needed, and will more heat dissipation be needed too. IF a GUI is needed for setup then the board will need RS232 or similar connectivity.
Elaine Benes
| Posted: Mon Sep 08, 2008 1:26 am Post subject: |
I'm just curious to know if the plan is to keep the Marquee in the same price range it currently occupies ? I ask because everyone here has a Marquee they bought used for hundreds of dollars, not thousands or, I guess more accurately, tens of thousands...
It would be great for crt projectors life to be extended with factory support, but the pool will inevitably get smaller and smaller if the price doesn't change to reflect the overall lowering of display technology pricing...
| Posted: Mon Sep 08, 2008 1:44 am Post subject: |
| stevecagle59 wrote: | Thanks for your great input so far. All ideas will be given significant consideration.
Anyone care to estimate how many Marquee's are out there in the home theater market? | it has to be in the thousands but exactly how many is anybody's guess. I have refurbished and sold about 50 in 5 years but Tim at E-tech,Curt Palme, and a few others have done many more.
| stevecagle59 wrote: | We would be happy to support other CRT brands but we would need detailed technical documentation.
Thanks Again! | why waste your time, Sony, NEC, and Barco are all out of production.
| Elaine Benes wrote: | | I'm just curious to know if the plan is to keep the Marquee in the same price range it currently occupies ? I ask because everyone here has a Marquee they bought used for hundreds of dollars, not thousands or, I guess more accurately, tens of thousands.... | I think if you averaged out what people have paid for nice 8500's with clean tubes, + what others have paid for 9500's + refurbishing costs it is more like thousands of dollars per machine but certainly not tens of thousands.
| Elaine Benes wrote: | | It would be great for crt projectors life to be extended with factory support, but the pool will inevitably get smaller and smaller if the price doesn't change to reflect the overall lowering of display technology pricing... | I think steve is inquiring about supporting Marquee's with new hardware that you could install into existing Marquee's on the market.
The market for this is still there. Lots of people blending and hot-rodding their Marquee's with higher bandwidth video chains. Maybe Mike Parker will sell his circuit design to VDC? I can imagine having a new high-bandwidth, low noise VIM that you could buy new from VDC for lets say $750.?
| Posted: Mon Sep 08, 2008 3:40 am Post subject: |
| Nashou66 wrote: | Way to go analog, I was at work and replied hastily . I think you covered much of what we want, Also make one of those pulley mounts for the PJ out of aluminum or some high stregnth plastic/carbon fiber so its not as heavy as the PJ like the steel ones I have.
Athanasios |
Oh yeah a powered pully mount! That's the icing on the cake. Yeah what he said but with powered winch!
Gino
| Posted: Mon Sep 08, 2008 5:37 am Post subject: |
I'd like to see firmware improvements. From what I've heard, Sony Barco and NEC give more options.
Of particular interest to me would be more zones/point control for RGB focus and convergence.
Also if you could create electronic flare/astig/triangularity controls, that would be an awesome feature.
Also, to be able to adjust geometry for red and blue tubes.
And last on my wish list would be to have a marquee that didn't create banding!
| Posted: Mon Sep 08, 2008 5:53 am Post subject: |
Simple request: A better method of holding the focus and HDM in place. H fails due to the H board lifting up a fraction of an inch are common, and when you've got the set on someone's ceiling with the back heatsink tied up with a wire, the HDM and focus boards fall out of place, shutting the set down.
Make the Ultra convergence yoke connector 'keepers' available to me as an aftermarket item. I'd like to put those white plastic clips on all MArquees that I sell, so that it's impossible to insert the convergence yoke connector off by one pin. That results in 3 hours of convergence board repairs when you accidentally blow them up. I've done it twice this year...
| Posted: Mon Sep 08, 2008 9:45 pm Post subject: |
| Curt Palme wrote: | Make the Ultra convergence yoke connector 'keepers' available to me as an aftermarket item. I'd like to put those white plastic clips on all MArquees that I sell, so that it's impossible to insert the convergence yoke connector off by one pin. That results in 3 hours of convergence board repairs when you accidentally blow them up. I've done it twice this year... | in lieu of protective clips a few hours sleep at nigth also prevents blown boards.
| Posted: Tue Sep 09, 2008 1:00 am Post subject: |
"nigth"
It also helps you spell.
antorsae
| Posted: Tue Sep 09, 2008 6:13 am Post subject: |
I think it should be possible to do a VIM-HD input card (such as moome) with HDMI input and blend capabilities.
I do not think rescaling is a MUST HAVE, having 1:1 pixel mapping (digital domain, obviously) would yield better quality and would make the card easier to implement (you don't need to hold the entire input frame, for one, etc...).
A while back I researched about this and found this:
http://www.microtronix.com/_dat/products/files/96/sendero_pds.pdf
Would would make a good test enviroment to do a blend with DVI in-out capabilities. In the real world, you'd only need the FPGA talking to the HDMI receiver which and then just a 10 or 12 bit DAC.
Conceptually, gamma ramps are easy to implement if done using look up tables, especially if you do 10-bit (or 12-bit) operations (and there is a 10 or 12 bit DAC so there is no posterization due to gamma processing).
The HDMI receiver card could take configuration parameters and store in unused areas of the EDID memory (http://en.wikipedia.org/wiki/EDID) so even an external USB or RS232 cable would not be required. EDID memory can be extended up to 32 Kbytes so one could easily store 6 separate gamma LUTs (3 channels for the non-blend zone, 3 channels for the blend zone). If the LUTs are 8 bit->16 bit, this is just 3 Kbytes. The only two required parameters are the blend zone size in px (16-bits) and the total of left or right area of the incoming image to display (16 bits can do).
With all the above, one could do an HDMI input card with non-posterization gamma control independent for all 3 channels (RGB) with OPTIONAL blend processing.
antorsae
| Posted: Tue Sep 09, 2008 6:23 am Post subject: |
Or better yet, the settings of the in-blend and out-blend gammas could be controlled from the CLM (instead of from a computer retrofitting the communication using the EDID memory, as I previously suggested). I understand the aux VIM card can still send/receive I2C commands from the CLM.
