LVPS Damaged?
Arno P
Posted: Thu Aug 28, 2008 1:45 pm    Post subject: LVPS Damaged?
Confused Crying or Very sad
Watched 2 movies on this 800hrs 9500lc ultra and now it won't switch on and the LVPS LED is on (and a oscillating clicking sound in the PJ).
Can this be repaired? Any ideas what might be the component(s) that died?
"Obviously you're not a golfer"
Arno P
Posted: Thu Aug 28, 2008 2:19 pm    Post subject:
I took away the frontpanel of the LVPS/HVPS and of the LED's on the LVPS the second one on the right (PJ ceiling mounted) was blinking in the same frequency of the (relay)clicking (1sec interval)...
Anyone got an idea what error this LED is displaying?
Posted: Thu Aug 28, 2008 2:39 pm    Post subject:
Disconnect/pull all modules. A short in the set can cause that. Remove the short, the set will fire up (probably without a picture though), and you'll have found the problem. It could be the LVPS as well though.
Arno P
Posted: Thu Aug 28, 2008 2:45 pm    Post subject:
With only mains connected the LVPS seems to be ok...fans running...no LED's...when pushing the power button the second LED on the LVPS starts blinking...any idea to what area this LED is refering to?
Posted: Thu Aug 28, 2008 2:47 pm    Post subject:
It's stamped below each LED...
Arno P
Posted: Thu Aug 28, 2008 2:50 pm    Post subject:
The LED's on the backpanel of the pj do have this, but I mean the LED's on the LVPS
Posted: Thu Aug 28, 2008 2:58 pm    Post subject:
Yes, pull out the LVPS and look on the PC board below them. The voltage rails that each LEd represents is stamped on the board. That is pretty useless though, you're faster pulling/disconnecting boards.
Arno P
Posted: Thu Aug 28, 2008 3:03 pm    Post subject:
Ok, started with that,
VIM out, still the same
Focus board out, still the same
HDM out, still the same
Arno P
Posted: Thu Aug 28, 2008 3:04 pm    Post subject:
CLM should stay in? Otherwise the power-on via remote will not work...right?
jantje112
Posted: Thu Aug 28, 2008 3:15 pm    Post subject:
The main reason I run a test chassis. The led system is pretty useless Sad
Arno P
Convergence/BackPanel Boards disconnected: same result
(Feels like testing matches Laughing ...every thing I remove is ok)
Posted: Thu Aug 28, 2008 3:22 pm    Post subject:
Neck boards...Smile
Also, leaking glycol on the backplane can cause this too. Check for leaking tubes...
Arno P
Posted: Thu Aug 28, 2008 3:24 pm    Post subject:
Neck boards...Smile
Mr. Green was just busy on the neckboards gimme a minute Wink
No leaking glycol here (so far Laughing )
Arno P
Posted: Thu Aug 28, 2008 3:38 pm    Post subject:
Removed the side panels to get to the neckboard shields....Neckboards....enough to pull the big connector and the two thick wires to that metal strip?
David_Web
Posted: Thu Aug 28, 2008 3:53 pm    Post subject:
If I understand you right that should be -85V.
Flashing means short.
LVPS troubleshooting indicated VNB as the only thing using -85V.
Could this mean a G2(or is it G1?) short on one of the tubes?
The big connector should supply -85V on one of the utmost pins. (the other side would be +85V)
*edit* maybe pulling the HV lead to the tube tested is a good idea. You never know what could happen.
Arno P
Posted: Thu Aug 28, 2008 4:01 pm    Post subject:
Crying or Very sad don't say that.... Crying or Very sad
I removed the Neckboards one by one and after each step I powered up the lvps again....with B/G removed still the same....with red removed....oversupply on responded to remote and no LED on the LVPS...
So......assemble again with RED as potential failure board....then switch board to Green and see if the problem remains (so it is the board....and if green is ok with the Red neckboard.....(then I might as well bought a new tube from VDC with the RED C in it Evil or Very Mad Laughing )
Arno P
Posted: Thu Aug 28, 2008 4:15 pm    Post subject:
OK,
I have put the green neckboard back on the green tube....LVPS is ok....
After that I removed the green neckboard and put the red neckboard on the green tube....lvps led started blinking again... Wink ...so red tube is ok...right?
The red neckboard also looked somehow different....brown connector on it and the B/G have white...
Can the neckboard be repaired? ....or always get a new one?
Posted: Thu Aug 28, 2008 4:27 pm    Post subject:
It depends on what went bad on the VNB, if its one of those white transistors thatre screwd to the heat sink its preety much shot as those parts are hard to find and hard to replace if you do have one. Looks like you need a new VNB, the tubes should light up even if one neck board is not connected I think, Curt am I right? Or should he just disconect the balckk unbilical cord while the VNB is on the tube and try to fire it up?
David_Web
Posted: Thu Aug 28, 2008 4:29 pm    Post subject:
Red tube should be OK. Looks like it's the VNB.
Is should be possible to repair but I would not personally touch it due to vital components for spotkill on it. Curt would know for sure.
Posted: Thu Aug 28, 2008 4:35 pm    Post subject:
If the neckboard is faulty, you need to disconnect all wires on that neckboard, weather its attached to the tube or not, in order to see if the projector is other wise functioning properly.
Its only when the tube is the culprit that you just pull it off the tube.
