tri_joel
Joined: 03 Jul 2007 Posts: 646 Location: Northern Virginia
| Posted: Thu Aug 21, 2008 5:48 pm Post subject: DIY Surround |
My HT and my library will be one and the same. I have a BG1208 ceiling mounted and an electric Draper screen. THE screen rolls down in front of what will be a wall of book cases. I would like to build the left and right speakers into the stiles between the book cases, in other words the book cases will be the the speaker boxes. I have never built a speaker. I was going to buy some of those tall floor standing speakers and build them into the cases, but I just can't get the look I'm after.
I checked out AVS and they talk in a language I don't understand. Anyone have any suggestions? Is there a speaker kit ai can buy with the speakers, crossovers, and whatever I need to put inside the boxes? I am smart enough to know there is more to the box than flat sides, but not smart enough to figure out how to divide the box up. I don't want to end up with crappy sound. Any instruction, guidance, comments, are welcome, useful or not.
I have the book case carcasses together, I'll get some pics tonight.
Peace,
Joel
tri_joel
| Posted: Thu Aug 21, 2008 6:39 pm Post subject: |
Those look like an easier and probably better way to go. There's also a dealer five miles from my house.
Thanks, I'll check them out.
_________________ www.vawinesnob.com
GEBrown
tri_joel
| Posted: Fri Aug 22, 2008 2:51 pm Post subject: |
Thanks. I was browsing through parts express yesterday. Has enyone heard Dayton speakers before? Just wondering how well they perform.
Peace,
Joel
JustGreg
| Posted: Fri Aug 22, 2008 3:01 pm Post subject: |
| tri_joel wrote: | Thanks. I was browsing through parts express yesterday. Has enyone heard Dayton speakers before? Just wondering how well they perform.
Peace,
Joel |
I've been getting their catalog for a couple years and wonder the same about Dayton. I know a name shouldn't be a barometer of quality but....would you get a burger at a joint called 'Cow Cuttins'?
Seriously, every time I get ready to place an order for something from PE I just can't seem to pull the trigger. I think it's because of all the EOL/clearance stuff they sell right along side products with great specs (but no actual reviews other than internally generated ones).
I like the in-wall solution for your application also. You can disassemble the thing and either mount everything to matching wood, or what would be even cooler would be to find cloth with the spines of books printed on it to cover them. Good luck with that one...especially finding something accoustically transparent enough to maintain all the goodness.
_________________ Greg
tri_joel
| Posted: Fri Aug 22, 2008 3:13 pm Post subject: |
I'm going to check out the in-wall speakers Nashou recommended. I think I will be able to build them into the stiles of the cases for the L/R fronts. I haven't decided what to do about the center channel. I have eight foot ceiling and six foot screen. I was thinking about building the center channel into the crown moulding hiding the screen case. I can't mount the the screen in the ceiling because the floor joists run the wrong direction.
Peace,
Joel
paw
| Posted: Fri Aug 22, 2008 10:20 pm Post subject: |
You might what to look at using in wall speakers and building the bookcase to hold them. Here's one suggestion
http://www.atlantictechnology.com/default.asp?IsDev=False&NodeId=23
Take a look at the IWCB series. They are an enclosed in wall. So, no need to calculate what size "box" is needed behind them. Look closely at how they mount into the frame. The frame mounts into the wall and the speaker into the frame. The speaker attaches to the frame by screwing into tabs. You could build these tabs into your bookcase and eliminate the frame. These tabs will have to be recessed from the front of the cabinet to make the speaker box flush or even slightly recessed from the front of the cabinet. Then make a speaker grill out of thin hardboard and attach it do the bookcase with magnets. Parts Express sell those magnets. Actually them sell kits to make the entire grill.
Beware these are pricey speakers. $550 EACH and up. I don't believe these are available retail. Only though dealers. Amazon has some Atantic Tech speakers but not these. A search of the net will probably find someone to sell these to you. Even a local dealer will likely sell you a pair. If you ask nicely.
Atlantic Tech in walls also have "Boundary control to compensate for the upper bass/lower midrange buildup that occurs when a speaker is mounted near a ceiling or wall boundary, and there’s a three-position HF level control to adjust tweeter level for varying room acoustics." The boundary control can be quite useful to reduce the boominess that can result from putting speakers in something.
I'd also recommend you get the face of the speaker as close to the same plane as the front of the bookcase. In other words, don't mount it deep into the bookcase and leave a lip around the speaker. This can lead to defaction of the sound. It make the sound muddy and hard to understand voices, etc. Cup your hands around your mounth to hear the effect.
Another super company it Triad Speakers
http://www.triadspeakers.com/
They can be made to custom specs. These can be REALLY pricey. Many custom installers like these speakers.
_________________ Aubrey
| Posted: Fri Aug 22, 2008 11:01 pm Post subject: |
| tri_joel wrote: | I'm going to check out the in-wall speakers Nashou recommended. I think I will be able to build them into the stiles of the cases for the L/R fronts. I haven't decided what to do about the center channel. I have eight foot ceiling and six foot screen. I was thinking about building the center channel into the crown moulding hiding the screen case. I can't mount the the screen in the ceiling because the floor joists run the wrong direction.
Peace,
Joel |
Definitely go listen the the Phase techs you'll be pleasantly surprised , one nice thing they have is a movable soft dome tweeter so if you ceiling mount say the center channel you can swivel the tweeter to face the seating. Also great to fine tune the sound for the right and left as well.
| Posted: Tue Sep 02, 2008 3:26 am Post subject: |
Parts Express is legitimate. A lot of their speakers products are of good quality. Check out www.zaphaudio.com for some test on speaker drivers. If you are going to put speakers in a case, then you may want to check out htguide. I believe there is a DIY inwall speaker that might work for you.
tri_joel
| Posted: Tue Sep 23, 2008 4:46 pm Post subject: |
Phase Technology CI-110 II = $699 each.
Wow. Looking at maybe building in somthing like the Polk RTi8. Anyone have these speakers? Comments?
| Posted: Tue Sep 23, 2008 5:02 pm Post subject: |
My very nontechnical comment is that it's very hard to 'duplicate' the exact sound of a consumer speaker. Changes in cabinet dimensions, structure and material used will affect what you end up hearing. So will putting the identical speaker into a different room with different furniture, carpeting and dimensions.
Having said that though, assuming you have decent woodworking skills, no question that you can make something that far outperforms the average poorly constructed consumer speaker. Having seen blown speakers from JBL and Energy that were made within the last 5 years, gawd, it's rude what these companies get away with now and call it 'hi fi'. Complete crap. Tiny magnets. Plastic cabinets. Pure garbage.
tri_joel
| Posted: Tue Sep 23, 2008 6:43 pm Post subject: |
Thanks Curt!
I have several years of woodworking experience building everything from custom furniture to framing houses.
You and Spanky Ham have encouraged me to try the parts express route. I'm not very confident about my crossover building skills so I found a plan on zaphaudio that I think will work well in my theater. I'll update in a few months when I get it together.
Joel
tri_joel
| Posted: Fri Sep 26, 2008 4:53 pm Post subject: |
I received the speaker parts from parts express yesterday. I have to say that after initial inspection that they have a quality look and feel to them. I may be some dumb, but I ain't plumb dumb - so I will hold out on a real review until after after I have them put together and sound coming out of them.
My Bride, however, does not like the idea of putting them into the stiles. We have come up with a more better placement that will allow better placement. I will continue to update as I progress.
Anyone ever built their own speakers? I'm nervous about putting the crossovers together. It looks pretty straight forward. Hope I don't mess it up too much.
esl_57
| Posted: Sat Sep 27, 2008 4:19 pm Post subject: |
I just noticed your thread.
I used the HiVi TN25 tweeter - $8.28 and the B4N woofer - $15.21, in an MTM (midrange - tweeter - midrange) configuration.
All 5 speakers use the same baffle, simplifiing the construction and ensuring that there is no tonal difference from front, to centre, to rear. I fussed with a few crossover designs but found that the parts wouldn't fit into the 0.2 cubic foot sealed enclosure.
Woofers wired in series for 16 ohms (trust me, your AV receiver will love it!) and a 4 micro farad capacitor in series with the tweeter.
Thats it! The tone is pleasant enough for this tube loving, electrostatic speaker, type guy and the lack of low pass filter on the woofer (a coil for 6db / octave slope) gets you back the 3db loss in efficiency that using one costs you.
Now the 2 woofer's, in close proximity to one another, add up in efficiency and the result is close to that of the tweeter so it is not nessisary to pad the tweeter down.
So... being 3 db more efficient means that you only need half the power for the same output but because you're providing a 16 ohm load to an amplifier that is usually rated into 8 ohms, you theoretically only have half the power potental.
You should be able to produce the same SPL but without stressing the AV receiver's supply!
You would of course be needing a sub woofer (i use 2 :-)
The baffles were cut from oak veneered plywood (i hate oak but you can get any trim imaginable in it).
You don't have to spend large to get good sound!
I'll post some pictures if your interested.
| tri_joel wrote: | I received the speaker parts from parts express yesterday. I have to say that after initial inspection that they have a quality look and feel to them. I may be some dumb, but I ain't plumb dumb - so I will hold out on a real review until after after I have them put together and sound coming out of them.
Anyone ever built their own speakers? I'm nervous about putting the crossovers together. It looks pretty straight forward. Hope I don't mess it up too much. |
tri_joel
| Posted: Sun Sep 28, 2008 1:01 pm Post subject: |
Thanks esl 57! I would love to see pics.
I separated all of the parts for the crossovers, and found that they shipped (4) 20 uF polys instead of one 80uF for the woofers (I'm doing a WTMW for the l/r fronts). I'm guessing these need to be in parallel vice series, or does it matter?
| Posted: Sun Sep 28, 2008 1:21 pm Post subject: |
Yes. Capacitors add when they're in parallel. Resistors add when they're in series.
It definitely matters! 4 20uF's in series would be 5uF, not 80!
tri_joel
| Posted: Sun Sep 28, 2008 5:17 pm Post subject: |
Cool, thanks. I'm heading out to the shop now to start building the enclosures.
esl_57
| Posted: Sun Sep 28, 2008 5:47 pm Post subject: |
80uf on the woofer??
It probably goes across the woofer so it's likely at leased a 12db / octave filter. How many components are in the low pass section (attached to the woofer)?
WTMW... is this a 3 way system with 2 woofers?
I'll size some shots and post them in a couple days.
| tri_joel wrote: | Thanks esl 57! I would love to see pics.
I separated all of the parts for the crossovers, and found that they shipped (4) 20 uF polys instead of one 80uF for the woofers (I'm doing a WTMW for the l/r fronts). I'm guessing these need to be in parallel vice series, or does it matter? |
