scheimpflug
Posted: Sun Aug 17, 2008 10:07 am    Post subject: scheimpflug
How much better is the focus of a PJ with scheimpflug over a PJ without? Does it make that much difference?
Gino
Posted: Sun Aug 17, 2008 10:53 am    Post subject:
I'd say you'd be very lucky to have a lens that was mounted in such a way that it gave perfect focus from corner to corner, edge to edge on your screen. Scheimpflug allows you to get this so focus is uniform.
Posted: Sun Aug 17, 2008 11:23 am    Post subject:
This has all to do with being able to follow manufacturers instructions and use tools. NEC for example, gives very exacting mounting instructions. If you follow those instructions to the letter, you will get perfect mechanical focus. Most of the time, following the manufacturers specifications does not allow for maximum raster useage which is a whole other arguement. Some here feel that manufacturers instructions are for the "ignorant" to follow. Choose your poison wisely. You have to live with it. That's all I have to say on the subject for fear of entering a pissing contest with those who are obviously smarter than me Wink
winduptoy
Posted: Sun Aug 17, 2008 11:26 am    Post subject:
Most lenses are f:1.1 or so. Depth of field is razor thin. The tiny DOF is a big reason reason why physical placement of the screen and PJ are so critical. (Graham Johnson's CRT Setup DVD shows how you will give your measuring tape quite a workout.) Scheimpflug allows you to shift the plane of focus until it falls exactly on the screen plane.
Posted: Sun Aug 17, 2008 4:10 pm    Post subject:
Other than the shallow depth of field, it's not really an issue of lenses. But since the DOF is very shallow, that means you have to have a 100% perfect mechanical setup so the tubes are perfectly parallel to the screen. And with toed-in red & blue, I'm not sure it's even possible to have perfect mechanical setup on all 3 tubes. So the scheimpflug adjustment is pretty much a requirement for any lenses.
jkruger
Posted: Sun Aug 17, 2008 4:51 pm    Post subject:
I was amazed at how much better focus I was able to get with continuous sheimpflug adjustment, the 12xx sets I had before the 1209s only had shims with which to adjust and being able to get it just right makes a big difference.
Posted: Sun Aug 17, 2008 6:57 pm    Post subject:
You can find more info on Scheimpflug here..
http://en.wikipedia.org/wiki/Scheimpflug_principle
Same principle is used in a view camera.
http://www.trenholm.org/hmmerk/FVCADNDM.pdf
Gino
Posted: Mon Aug 18, 2008 2:16 am    Post subject:
That was the point I was making. Scheimpflug is important if you want uniform focus.
zGman
Posted: Mon Aug 18, 2008 4:52 am    Post subject:
The only time there is perfect geometry (eg no lens tilt required) would
be on-axis projection, and then only on the green. the red and blue would still
be projecting at an angle.
Consider the typical front ceiling mount setup where the PJ is located with
lenses at or above the top of the screen - lens tilt will be needed to get the
top and bottom equally in focus.
I haven't seen a PJ that doesn't have some provision for this, but many are
static - which makes fine tuning almost impossible.
G
Posted: Mon Aug 18, 2008 6:45 am    Post subject:
So it seems that in theory Scheimpflug improves focus. In practice is the difference visible. Can anyone produce two images with and without Scheimpflug say with a static test pattern??
Posted: Mon Aug 18, 2008 7:35 am    Post subject:
Will it make a difference what we say or photos we present as proof ? Try it for yourself and report back...................
Posted: Mon Aug 18, 2008 8:05 am    Post subject:
Well Tom I am not sure why you post on this forum but for me its because I don't know or don't have the gear to find out. In this case both.
If I had the gear to test this I would test it myself and yes it does matter what forum members recommend. Again perhaps you don't value members input but I do.
timf
Posted: Mon Aug 18, 2008 10:39 am    Post subject:
For your information mate, I've found Tom to be nothing but helpful on questions I've asked and questions asked by others, what you are asking is not an answer to a question but for someone to go to a hell of a lot of trouble to prove to you whether it is worth it.
I believe the point Tom was trying to make is that several people in this thread have already stated that it makes the world of difference if you want uniform focus if you value members input as much as you claim you do then that should be enough.
JustGreg
Posted: Mon Aug 18, 2008 3:13 pm    Post subject:
My flapping is in a horrendous state as evidenced by inconsistent focus that's unique to each color. eg, the blue is tack sharp at the bottom and left top but the other two corners aren't. The other two colors suffer the same poor setup on my part. No amount of mechanical or electronic focus is going to make up for it. There are procedures for flapping adjustment but none of them comes close to the time (and back ache) that a couple (or more) hours of persistent adjustment and swearing can provide.
As has been mentioned, getting a spot on pj mount asbsolutely square to the screen is a critical first step. Without that...all bets are off.
I'm at the point where now that it's down for maintenance I'll reset the plates to factory start points of about 3/4", strap on the back brace, and have another go at it.
Greg
jkruger
Posted: Mon Aug 18, 2008 3:24 pm    Post subject:
I'm at the point where now that it's down for maintenance I'll reset the plates to factory start points of about 3/4", strap on the back brace, and have another got at it.
are all three colors out of focus in the same areas? Sounds like pj alignment if they are.
JustGreg
Posted: Mon Aug 18, 2008 3:45 pm    Post subject:
Thanks for the reply. Smile
As usual I didn't explain myself clearly. All are out of focus in different areas. I've measured, remeasured, and come to the conclusion that I have the pj mounted as square to the screen as possible so that leaves flapping.
That's all to be a moot point soon anyway as I'm finally going to mount the 145's and plates I got from Barry (Jost Mods) and that will put me back to square one. That's good however. I'll be able to apply the knowledge I've gained since ceiling mounting it over a year ago.
I was more or less just commenting about Tom's advice which is, Have a go at it and see where it gets you. We can try to tell someone how to do Scheimpflug all day long but that's no replacement for just digging in and having a go at it. The OP was, I think, asking if a pj with Scheimpflug is better than one without. I'm not anywhere near as informed as alot of guys here but I would say the more adjustments the better. More confusing...but better.
Greg
jkruger
Posted: Mon Aug 18, 2008 3:46 pm    Post subject:
That is so true. I didnt really understand it either until I started doing it.
Posted: Mon Aug 18, 2008 4:00 pm    Post subject:
Maybe this might help.
http://www.moesrealm.com/hometheater/crt-focus-guide.html
Here's an excerpt from the link...
Note: Mechanical Aim is Not Scheimpflug (Lens Flapping)
Novices confuse the two, but mechanical aim is not the same as lens flapping (aka Scheimpflug). Mechanical aim of the CRT/lens assembly is akin to taking a telescope and physically pointing it at something. Lens flapping adjusts the mounting angle of the end lens without changing the direction the telescope is pointed. Lens flapping doesn't change the direction of aim (well just a little), but compensates for the planes of the screen and phosphor being non-parallel. If the lens were kept parallel to the phosphor surface, it would be impossible to focus throughout the screen at the same time. The flapping places the lens into a plane intermediate between those of the screen and phosphor and that makes global focus possible.
Rough Optical Focus
Now that mechanical aim of the guns has been done, it is time to do an initial, rough optical focus.
Display a crosshatch pattern. Adjust optical focus using the two knobs. The front most knob on the lens controls edge optical focus. The rear most knob adjusts center optical focus. Dial in center focus first. Then adjust the outer (front knob) focus to while watching the corner lines of the crosshatch flare inward and outward. Try to minimize flaring using the outer focus knob. Go back and forth between the two optical focus knobs to get both center in focus and outer edge minimally flared. Use of binoculars aids this process tremendously.
Rough Scheimpflug (Lens Flapping)
Once rough optical focus is completed, you can perform lens flapping. The following is primarily for projectors which have continuously variable lens flapping. For projectors with lens flapping rings, simply set the lens rings per the installation manual specified settings for your projection distance.
Display a focus pattern. Look ONLY at the center of the top edge. Adjust center optical focus to make that edge sharpest. Note the position of the focus knob. Pay attention to the center of the bottom edge. Adjust lens center focus to make the bottom edge sharpest. Is the lens center focus control in the same position as when the top was sharpest? If so, vertical flapping is correct. If not, adjust vertical flapping using a wrench. Note the wrench position when the bottom edge is focused vs top edge. Set the vertical flapping to put the wrench in exactly halfway between the two positions. Horizontal flapping is performed in an analogous fashion paying attention to only the left and right edges.
Now go back and refine center and edge lens focus. Once that is done you should have the lenses in fair optical focus and flapping. Advanced owners may consider the 3 x 5 card technique fine focusing technique presented later in this document for even better optical focus and Scheimpflug.
PJMoore
Posted: Mon Aug 18, 2008 7:42 pm    Post subject:
KM -
I had Sonys that used wedges and rings that had three discrete settings: S, M, and L. These three settings represented a "reasonable" compromise that provided "acceptable" viewing over a wide range of throw distances and throw angles. My Marquee, however, has continuously adjustable lens plates, so no "compromise" is necessary. As a simple matter of optics, it stands to reason that the S, M, and L settings would each be "perfect" at one throw distance and throw angle and that any other throw would have some degree of error that would range from "a little" to "a lot" depending on the situation and how picky the observer is. What chance is there your setup would be one of the "perfect" ones? About zero.
So back to your questions. 1 - continuously variable flapping makes a difference, since the throw distance and throw angle are variables from theater to theater; and 2 - you cannot make a definitive comparison, per se, between continuous and discrete flapping, since any given projector will have one or the other, but no both. Any difference observed would therefore be attributable to multiple factors.
I can tell you this. Mooneyass described a means of making the Sony continuously variable. While not nearly as easy to use as my Marquee, I did notice the overall image was noticably crisper across the entire screen when I used continuous flapping on my Sonys. I quit using the wedges entirely after that ( I have had 5 Sonys).
I hope this addresses your questions. If this is the deciding factor between your choice between projectors to buy, I can tell you that it is just not a good barometer to be using. Brand reliability, parts availability, and Curts pecking order are better "barometers" for picking a CRT projector.
Posted: Mon Aug 18, 2008 8:12 pm    Post subject:
I can't produce the two images, but it is absolutely very visible. I haven't had a chance to do a really good scheimpflug setup on my 8500 and you can clearly see a difference in focus in different areas of the screen, different for each color. If I ever get a chance to tweak up the scheimpflug properly, it will be sharp across the entire screen. (Assuming your zone focus is correct, of course!)
