Last Order for Red C elements Marquee, STEP5: FINAL Shipment
Goto page Previous  1, 2, 3 ... , 11, 12, 13  Next
Posted: Wed Sep 17, 2008 6:25 pm    Post subject:
Only one left to pick up, Tbx (Thomas) his in in customs.
Even though this was a lot of work it made me proud to be part of this world wide Community of us CRT lovers. A few years a go I never would have thought I would get this involved in something with such a widespread global following. It has been great and a excellent learning experience and I hope we all stay together and keep this great Hobby I have become obsessed with alive for years ahead.
This effort went from the USA,Canada,Italy,Australia,Netherlands,Sweden,Switzerland,Denmark and Germany!!! Now that is Effin cool !
Arno P
Posted: Wed Oct 01, 2008 3:00 pm    Post subject:
Everyone got is Red C?
Today I received my glycol (and some neckboard IC's)....so...ready to start Wink
Any pics from anyone that placed the Red C (of the 24 pcs order)?
 Filesize:  57.12 KB
 Viewed:  8518 Time(s)
"Obviously you're not a golfer"
NewbieDAN
Posted: Wed Oct 01, 2008 3:22 pm    Post subject:
Installed the week I got them.
[/img]
Arno P
Posted: Wed Oct 01, 2008 3:26 pm    Post subject:
How long did you let rtv dry before filling?
And....no damaged bellows?
Posted: Wed Oct 01, 2008 3:38 pm    Post subject:
that green looks wierd, is it a Sony spec. piece from a G90?
Posted: Wed Oct 01, 2008 3:48 pm    Post subject:
Arno thats a barco LC housning differnet than our Marquee's
Arno P
Posted: Wed Oct 01, 2008 3:51 pm    Post subject:
Oops Mr. Green Embarassed Laughing
Cgaia
Posted: Wed Oct 01, 2008 4:15 pm    Post subject:
I finally got them after lot of problems with italian customs.
Many thanks to Athanasios and Arno for their efforts!!!
Ciao
Claudio
CRT Enthusiast
Owner of Marquee 8500AC and 9501LC
Posted: Wed Oct 01, 2008 4:19 pm    Post subject:
Customs Sucks !!!
Thank you Claudio !
Arno P
Posted: Wed Oct 01, 2008 5:01 pm    Post subject:
Ciao
Claudio
Italian, Dutch....both terrible customs (but perhaps they got a good reason for it Mr. Green Wink )
NewbieDAN
Posted: Thu Oct 02, 2008 5:56 am    Post subject:
Nice eye......I couldn't get hold of any Marquee spec Green elements well not for under $350 anyway Shocked I managed to track down an element from a Sony 1292 for nix through the generosity of one of our local Aussie forum members, not quite as close to primary like the marquee ones...but better than the clear's that are originally fitted. I'm not sure how the G90's tint compares to the 1292 as there is no information avaliable, unlike the measurements of the G90's.
r.bauer
Posted: Thu Oct 02, 2008 6:44 am    Post subject:
The 1292 uses the proper green C-element. The G90 is the only projector that uses a different green C-element.
NewbieDAN
Posted: Thu Oct 02, 2008 7:33 am    Post subject:
Well there you go Thumbs Up
Posted: Fri Oct 03, 2008 6:43 am    Post subject:
So thats it there are no more Red and Green C elements anywhere right!!
Posted: Fri Oct 03, 2008 11:00 am    Post subject:
VDC has them but not sure if they will sell them unless they install them.
TbX
Posted: Fri Oct 03, 2008 9:49 pm    Post subject:
finally, I have finished arguing with customs and the c-elements is at home Smile
//TbX
Arno P
Posted: Sat Oct 04, 2008 11:15 am    Post subject:
//TbX
No Thanks...enjoy Wink
Started on mine today....
 Filesize:  56.36 KB
 Viewed:  8345 Time(s)
 Filesize:  47.39 KB
 Filesize:  46.53 KB
Posted: Sat Oct 04, 2008 12:07 pm    Post subject:
Arno, I found a better way to take out the old C-elements. Look on the side's of the back LC housing and see the pivot pins, they are threaded inside. Take one of the srews you took out of the front housing and screw it into that pin and pull the pin out on both sides . Then remove the back LC housing, you'll have to remove the plastic cover too, the ones i was working on are bare tubes so not sure if you need to remove anything else but i dont think so. Then you have to remove the metal gasket, this is tight fit so if your allen key's "L" is not "short" enough you may have to cut it down to fit between the housing and screws. remove that and its now easier to push the Bellow through the hole and now you are able to use a blade to help in removing the C-element.
Arno P
Posted: Sat Oct 04, 2008 12:17 pm    Post subject:
Arno, I found a better way to take out the old C-elements. Look on the side's of the back LC housing and see the pivot pins, they are threaded inside. Take one of the srews you took out of the front housing and screw it into that pin and pull the pin out on both sides . Then remove the back LC housing, you'll have to remove the plasic cover too, the ones i was working on are bare tubes so not sure if you need to remove anything else but i dont think so. Then you have to remove the metal gasket, this is tight fit so if your allen key's "L" is not "short" enough you may have to cut it down to fit between the housing and screws. remove that and its now easier to push the Bellow through the hole and now you are able to use a blade to help in removing the C-element.
And maybe...I found an even easier way... Mr. Green
 Filesize:  53.14 KB
 Viewed:  8335 Time(s)
Posted: Sat Oct 04, 2008 1:08 pm    Post subject:
Is that a fish tank Pump?!?!!!!! Very Happy
Page 12 of 13
