BG808 and 1080p
Spotmatic
Posted: Tue Aug 05, 2008 1:56 pm    Post subject:
Corleone88 wrote:
Sorry Wink .
But I don' t which value(s) for the H-Phase is(are) incorrect.
Could you tell me which interval of values is ok ?
Just try to change the H-phase (left or right), you will quickly see if this is the cause or not. I cannot give any values, not even rough ones as I don't have your projector Smile
Spotmatic
Posted: Tue Aug 05, 2008 1:58 pm    Post subject:
In case I was not clear: modifying the H-phase is a visual process. Just look what happens to the picture while you are changing the H-phase (to the left or to the right).
Ile
Posted: Tue Aug 05, 2008 2:12 pm    Post subject:
"correct" Hphase value debend about your sources porch settings (=blank pixels before/after picture), so it's needed to adjust separetly for every memory block. You need to select Hphase from menu and lower contrast to 10 and raise brightness to 80, so you can see raster behind picture when you look to crt face through lenses. Then adjust Hphase so that picture is in the middle of raster or little left from center.
Or you can leave Hsift to 50 and use Powerstrip for adjusting porch settings so that picture is in the middle of raster. If you have set blankings near picture edges, you have to set those to min before adjustment.
Posted: Tue Aug 05, 2008 3:46 pm    Post subject:
Corleone88 wrote:
Sorry Wink .
There are also no "correct" or "incorrect" values for H-phase (or for any other setting in the projector really). It all depends on how you have it setup, what sources you're using, what resolutions you're running etc.
I often get asked what the correct gains and cutoffs are for setting greyscale on a certain model of projector and it's always the same answer too: If there was only ONE correct value to use, the manufacturer wouldn't have given you a way to adjust it! H-phase is a 0-100 value. If it was always "incorrect" to have a value or range of values for this setting, Barco simply wouldn't allow you to adjust that far.
KAl
