Sony D-50 Line Doubler
John S
Posted: Sat Jun 28, 2008 2:12 am    Post subject: Sony D-50 Line Doubler
Hey, New guy here. I'm trying to determine if my D-50 has a line doubler card installed already,but am having no luck. Anyone have a service manual or wiring diagram that may show where this card would be mounted and where it connects to the projector. Any info would be greatly appreciated.
John
jantje112
Posted: Sat Jun 28, 2008 2:34 pm    Post subject:
If it's not installed it's not an option in the menu's. If you remove the cover of the d50 standing behind it, it's the boards mounted at the left at the side of the d50.
John S
Posted: Sun Jun 29, 2008 12:47 am    Post subject:
So if it was not installed at the factory there is no possibility of upgrading this projector withthe line doubler?
Posted: Sun Jun 29, 2008 1:46 am    Post subject:
You can install one yourself, in fact Curt may still be selling the one that I traded him.
John S
Posted: Sun Jun 29, 2008 1:54 am    Post subject:
I saw the one Curt is selling on e-bay, that is what got me thinking about it in the first place. I am still not certain if I have one already, and if not where would the connections be made. I have no wiring diagram to go by.
Posted: Sun Jun 29, 2008 2:36 am    Post subject:
I'm not sure where it would be in the D50, hopefully someone will post a picture. However if it doesn't show up in the menu you either don't have one installed or the installed one is dead/disconnected.
Axatax
Posted: Sun Jun 29, 2008 3:44 pm    Post subject:
The Sony DI is *ancient*. Look into a used iScan Ultra instead (less ancient).
John S
Posted: Sun Jun 29, 2008 4:40 pm    Post subject:
Is there a specific location in the menu, or will it be listed as a line doubler?
John S
Posted: Sun Jun 29, 2008 4:43 pm    Post subject:
I have not heard of this unit. I take it this is compatible with the Sony D-50. Is instalation difficult?
Axatax
Posted: Sun Jun 29, 2008 4:58 pm    Post subject:
If the Sony DI is installed and functioning, there will be a separate top menu option labeled "IDTV".
The iScan Ultra is a stand-alone DI based on the very capable Sil504. For deinterlacing 480i sources (doubling) it will be roughly equivilent to a VP30 without the ABT102 card.
http://www.anchorbaytech.com/support/faq/ultra.php
Bruce 09
Posted: Sun Jun 29, 2008 5:21 pm    Post subject:
The last thing I would put into a D50 IS THAT DOUBLER! And if you do have one get rid of it .
What are your sources VHS tapes ?
1080i is the sweet spot for that projector .
You can easily get all native (relatively native Smile ) 1080i signals into that projector all you need is a HD FURY .
If you need to line double your sources you need to have a yard sale .
Bruce
John S
Posted: Sun Jun 29, 2008 5:33 pm    Post subject:
My sources are mostly dvd. I may switch to hd cable once I can get this thing fine tuned a little better. I am totaly new to this and have not had the time to do alot of tweeking.
Bruce 09
Posted: Sun Jun 29, 2008 5:48 pm    Post subject:
Perfect ! Then you can go to Walmart and get a venturer HD dvd player for 69 bucks, it will play those outdated cheap easy to find HD DVD's . And as a bonus it will upscale your dvd's to 1080i and look better than 90% of all Video processors or upscaling players .
Then you take the 200 bucks for the line doubler and buy this ( a Moome DVI input card - recent EDID chip upgrad ($100)) (Videogon) G70 ad. http://cgi.videogon.com/cgi-bin/cl.pl?projcrta&1219860619&class&3&4&
Or one of these, Just plug it directly into the projector http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10114&cs_id=1011402&p_id=4561&seq=1&format=1#largeimage
John S
Posted: Sun Jun 29, 2008 5:58 pm    Post subject:
Am I wrong or did I see an ad for a Moome card that was/is made as a replacement for the A input card on the Sony? Would this work as well? And would I need to get an hdmi cable to the projector (this would not be easy).
Bruce 09
Posted: Sun Jun 29, 2008 6:03 pm    Post subject:
OK I'll bite, where did you see the ad, the link I provided ? Why would it be hard to get a hdmi cable to the projector .
Bruce
John S
Posted: Sun Jun 29, 2008 7:34 pm    Post subject:
Bruce
I saw the ad on this forum in the market place section. The way read it this would work on all Sony's, but I could be wrong. I have a finished ceiling and wasn't smart enough to run an hdmi cable at the time (doh!). It wouldn't be impossible, but certainly not easy.
Bruce 09
Posted: Sun Jun 29, 2008 8:22 pm    Post subject:
John S wrote:
Bruce
You would be surprised how much you can do with a fish tape. The ad on Videogon I linked has a sony dvi card that will work on yours.
Bruce
Axatax
Posted: Sun Jun 29, 2008 8:57 pm    Post subject:
Some D50's have hardwired RGB inputs in place of a standard IFB slot, so no, not all D50's will be compatible with the Moome card.
John S
Posted: Sun Jun 29, 2008 9:23 pm    Post subject:
There appears to be a smaller connection location on the back that looks like it is removable with just 2 screws. Are there pros and cons to both the Moome card and the HD-FURY?
ginger123456
Posted: Sat Jul 05, 2008 8:11 am    Post subject:
Hi John S as you quoted your pj has an A input board not an IFB input board, I think the d50q type pj has an ifb40 which can be replaced with a moome card, the d50 htu version does not which i presume is your model, the only way to fit the moome is through a pc1271 switcher.
Hope this helps
ginger
