Is there a way to flip video horizontally
Joust
TV/Projector: Marquee 8501LC
Posted: Tue Jun 24, 2008 3:11 am    Post subject:
since this is doing very low res, I'd go with the old PC solution.
is this the board? http://www.quarterarcade.com/GamePicture.aspx?c=&g=5762&o=0&m=0
that board design has not changed much is a very long time. I have a few of these boards. Tenage mutant ninja turtles uses the same board.
i have a few for sale if you want different ones Smile
with JAMMA, its plug and chug.
buaku
Posted: Tue Jun 24, 2008 3:42 am    Post subject:
That's the board! The JAMMA output is no problem. I had a hell of a time figuring out the output for the 2nd RGB out on there.
Then it took some work to find a video encoder that would play nice with the board.
Funny you mention TMNT, cause I was telling people I thought you could convert a 6 player Xmen into a 4 player, but it turns out I was thinking you could convert a 4 player TMNT into a 2 player I think. All that needed to be done was some sort of reset to make the board recognize the change.
You wouldn't happen to have any X-men 6-player manuals would you? All I can find is the 4-player version.
Joust
Posted: Tue Jun 24, 2008 12:29 pm    Post subject:
no, I don't have a manual. go to newsgroup rec.games.video.arcade.collecting
http://groups.google.com/group/rec.games.video.arcade.collecting/topics
it could be that the board is the same for 4 player. I don't know.
for TMNT, I think they use the same board for two player.
this is for the 4 player version.
http://www.mikesarcade.com/cgi-bin/spies.cgi?action=url&type=pinout&page=XMen.txt
buaku
Posted: Wed Jun 25, 2008 12:20 am    Post subject:
The 6 and 4 player boards are pretty different. I don't think the swap works there.
I'll see if there's anything good in the newsgroups. Thanks!
cdivaio
Posted: Mon Dec 09, 2013 9:01 pm    Post subject: X-men
I have the same board and want to use two 4:3 monitors side by side. Any luck with the mirroring?
buaku
Posted: Mon Dec 09, 2013 11:20 pm    Post subject:
The best I was able to do was run it into my PC with two video capture cards and use either MPC or VLC to flip the image in software.
Basically I started up two instances of MPC and put them side by side and just flipped the one image in the MPC settings. I did this all on one monitor too.
Not quite as nice as having two monitors side by side, but it worked. Plus the issue with two monitors is the bezels that put a lot of space between the two pictures.
I'm pretty sure I used a JROK converter to get the image into something the capture card could understand.
I could never get good answers out of the people selling the various video devices that would make me want to spend that kind of money on something that may or may not work. I was never sure if they would accept the signal coming from the arcade board.
cdivaio
Posted: Tue Dec 10, 2013 12:34 am    Post subject:
Well it's cool that you got it working. Especially on one monitor. The cheapest device I've found is just under $400.
cdivaio
Posted: Tue Dec 10, 2013 1:04 am    Post subject:
Is what you did something I could do with a net book? Or do you I need to install hardware? I wouldn't mind the gap. I'd like to use the net book to flip just one of the screens.
noos@xp37+
Posted: Tue Dec 10, 2013 7:31 am    Post subject:
I have the Aurora Dido Pro here. Barely used, even with some optional cables. Bought it for splitscreen 2-4 HD (!)channel stuff and picture in picture. Never happend. Great scaling engine, rotaion, mirroring, deinterlacing....
If you are interested drop me a PM.
cdivaio
Posted: Tue Dec 10, 2013 4:31 pm    Post subject:
I need to post one more time in order to PM
cdivaio
Here we go!
noos@xp37+
Posted: Tue Dec 10, 2013 5:30 pm    Post subject:
no pm so far.....
buaku
Posted: Wed Dec 11, 2013 3:21 am    Post subject:
If you just want to use the netbook for one screen I don't see why a USB capture card wouldn't work.
I have a Startech SVID2USB2 and it seems to work fine. It works for normal TV type stuff at least. I didn't have it at the time I was messing with the X-men board though.
You'll also need another device to convert from the arcade board signal to a regular TV signal. I used the JROK encoder for that. That was about 100 bucks I think for all the bells and whistles.
buaku
Posted: Wed Dec 11, 2013 3:27 am    Post subject:
I remember looking into one of their devices. I was never sure if it would be able to handle the output from the arcade board though since it's usually some oddball resolution.
noos@xp37+
Posted: Thu Dec 12, 2013 6:58 am    Post subject:
I tested the Dido pro with tons of classic material, including the 240p test disc and nearly all classic consoles. I can say it has one of the best scaling engines out there, but every special use should be tested before. If anyone gives me resolutions and refresh rates, I can generate them and shoot them into the Dido.
buaku
Posted: Fri Dec 13, 2013 2:32 am    Post subject:
According to this page....
http://www.arcade-museum.com/monitor.html#R
I'm guessing these are the specs.
Code:
                   STANDARD RESOLUTION
          HORIZONTAL                    VERTICAL
Scan Frequency: 15.72 KHz    Scan Frequency: 60.0 Hz
   Scan Period: 63.6 µSec       Scan Period: 16.7 mSec
  Active Video: 46.9 µSec      Active Video: 15.3 mSec
   Video Delay: 11.9 µSec       Video Delay:  1.2 mSec
    Sync Pulse:  4.7 µSec        Sync Pulse:  0.2 mSec
     Scan Line: 456 Pixels           Screen: 262 Lines
    Resolution: 336 Pixels       Resolution: 240 Lines
    Clock Freq: 7.16 MHz
And here's info about x-men
http://www.arcade-museum.com/game_detail.php?game_id=10496
noos@xp37+
Posted: Sat Dec 14, 2013 5:50 pm    Post subject:
Hello,
I will test it when I have time left. But it looks very similar to plain 240p60hz. Anyone an opinion? Barclay66?
noos@xp37+
Posted: Fri Feb 28, 2014 5:20 pm    Post subject:
So late, but I did tests it in a setup. The Dido Pro accepts and works with this resolution. Anyone who needs one, let me know....
