nettwerkjohn
Joined: 08 Mar 2006 Posts: 921 Location: Blenheim, Marlborough, New Zealand
| Posted: Mon Jun 09, 2008 5:28 am Post subject: Ruby issues |
Nope - haven't got any.
Haven't spent half a year getting convergence/geometry/astig right.
Hung it on the ceiling, fed it blu-ray, enjoyed...
And the hour clock is showing 1203 hours (and ticking...)
| Posted: Mon Jun 09, 2008 10:52 am Post subject: |
How many times have you calibrated it in those 1203 hours? I would imagine out of the box wouldn't produce the best color rendition, not once the lamp started aging. Not saying that calibrating is a negative thing (CRTers do it also), but I am curious about your situation.
nettwerkjohn
| Posted: Mon Jun 09, 2008 11:07 am Post subject: |
two calibrations so far - each with a change of location. its due now - as its just been installed in a new dedicated theater...
the bulb hasn't visibly changed brightness as yet...
waiting on the blu-ray dve to tweak it
| Posted: Mon Jun 09, 2008 11:08 am Post subject: |
The lamp's output hasn't change in 1200 hours based on your perception, or based on your measurements?
| Posted: Mon Jun 09, 2008 11:26 am Post subject: |
Impossible! Everyone knows that all digitals explode the moment you turn them on, and then representatives from the manufacturer come to your house and make you eat the pieces!
Person99
| Posted: Mon Jun 09, 2008 12:36 pm Post subject: |
| nettwerkjohn wrote: |
the bulb hasn't visibly changed brightness as yet... |
Because of the way the eye works, it is tough to see the changes in brightness. But, it has dimmed and changed color in the 1200 hours. It is just very hard to see it. With 1200 hours on it now though, it should be fairly stable until its end of life.
_________________ Dave
| Posted: Mon Jun 09, 2008 1:48 pm Post subject: |
| Person99 wrote: | | nettwerkjohn wrote: |
Because of the way the eye works, it is tough to see the changes in brightness. But, it has dimmed and changed color in the 1200 hours. It is just very hard to see it. With 1200 hours on it now though, it should be fairly stable until its end of life. |
From TX to new Zealand, dave can accurately tell the condition of YOUR pj.
W W!!!
_________________ Follow my blog
kal Forum Administrator
| Posted: Mon Jun 09, 2008 3:01 pm Post subject: |
| emdawgz1 wrote: | | Person99 wrote: | | nettwerkjohn wrote: |
W W!!! |
Huh? I don't get it. No he hasn't. He's just stating the facts.
You don't have to SEE a set of tires with 50,000 miles on them in person to know that they're going to be more worn than a set of new ones.
The way digital bulbs dim and change over time is a well known phenomenon. It's impossible for anything else to happen.
Person99
| Posted: Mon Jun 09, 2008 3:22 pm Post subject: |
W W!!! |
No sure why you want to be a f*cking *******, but OK.
Guess what? I can also tell him the rate at which objects fall in New Zealand all the way from TX! Does that f*cking amaze you also?!?!? It should not if you have the most basic grasp of physics. So, unless his bulb lives in another dimension where the laws of physics are suspended, his bulb has to change color temp and output. It is a xenon lamp so it does it more slowly than a UHP, but even Xenons have measurable changes by 1000 hours. So, yes, I can reliably predict that all the way from TX that his 1200 hour bulb has changed color temp and output. Perhaps you should go back and attempt to master high school science--it really is pretty cool.
| Posted: Mon Jun 09, 2008 3:42 pm Post subject: |
| kal wrote: | | emdawgz1 wrote: | | Person99 wrote: | | nettwerkjohn wrote: |
W W!!! |
Kal |
I'm just rattling the "Dave" cage....
I'm sure a bulb dims w/ age. But if networkjohn is happy why shouldn't we believe him?
| Posted: Mon Jun 09, 2008 5:43 pm Post subject: |
| emdawgz1 wrote: | | I'm sure a bulb dims w/ age. But if networkjohn is happy why shouldn't we believe him? |
I'm sure he's happy, but that doesn't mean the bulb/colour isn't changing. To say it isn't changing is simply incorrect.
This is not a knock at networkjohn (as he's in a different league), but most people are perfectly happy with their 27" TVs, DVD, and regular cable TV too. Does this mean that we should not bother with anything bigger or higher resolution HD?
nettwerkjohn
| Posted: Mon Jun 09, 2008 8:35 pm Post subject: |
guys - i'm sure the bulb has changed, but it hasn't been noticeable. the time that i have run a calibration (from sd-dve) i haven't had to change anything - other than to move off my current settings only to move it back.
my understandings of xenons are they change brightness characteristics FAR more than color-temperature in their lifespan, and it should have been at half brightness by 200 hours or thereabouts.
as i don't have a light meter, all i have is my eye.
and dave is right, hd-dvd is falling at exactly the same rate in nz as it is in texas
| Posted: Tue Jun 10, 2008 9:27 am Post subject: |
Yeah, but I didn't ask about color-shiftiness. I asked about the light output. And I am not asking with a negative agenda in mind (knocking the Ruby), but genuinely curious as to how much of the original ANSI lumens have gone.
nettwerkjohn
| Posted: Tue Jun 10, 2008 9:42 am Post subject: |
Wanman - this is its image, on a very dark wall, taken about a week ago. With its iris closed down. Still heaps of brightness - the wall color is judge grey, and has a 11% reflectivity rating, so in effect a gain of .11
nettwerkjohn
| Posted: Tue Jun 10, 2008 10:10 am Post subject: |
just took these, flash on and off, underworld evolution, on the screen (1.5 gain)
you'll have to excuse the framing of the shots, but as i don't have a tripod, one of our surrounds did that duty...
| Posted: Tue Jun 10, 2008 11:36 pm Post subject: |
i'm not familiar with that movie, are the colors suposed to be all whacked out like that? everythings looks green.
nettwerkjohn
| Posted: Tue Jun 10, 2008 11:56 pm Post subject: |
yes - very blue/green all thru the movie. (as its always night). i'll take some from XXX tonight (or Hellboy)
nettwerkjohn
| Posted: Tue Jun 10, 2008 11:58 pm Post subject: |
and, what's up with not being familiar with Underworld? Its got Kate Beckingsale, in leather. And out of leather....
| Posted: Wed Jun 11, 2008 4:54 am Post subject: |
Hey, I can't see the pic's??
| Posted: Wed Jun 11, 2008 4:56 am Post subject: |
Wait they they are. Geeze kate Bekensale looks terible in that red shirt.
