HDMI TO RGB ANALOG VS. DIGITAL
ROFLmaker
Posted: Fri Jun 06, 2008 8:33 pm    Post subject:
Sorry for all the broken up posts but last thing... With that 3RCA->VGA cable..Is it still high def?
ROFLmaker
Posted: Fri Jun 06, 2008 9:10 pm    Post subject:
Also will this still be high def?
CRT_Ben
Posted: Fri Jun 06, 2008 9:16 pm    Post subject:
1. Yes it will work with your TV.
2. Yes it will still be high definition.
3. Just order the part...it'll be less than $10 shipped!
Person99
Posted: Fri Jun 06, 2008 9:53 pm    Post subject:
ROFLmaker wrote:
Ok thanks everyone for your help I'll post back how it looks but one last thing I want to verify: VGA and RGB are interchangeable I know that they are the same plug but they are cross compatible in terms of signal and such?
Did you do what I said and find the menu option on your display where you set the input type for Input 1 and/or Input 2 as RGB or YUV? If you found that and can put it in "YUV" mode, then the cable Ben linked to above will work for you.
VGA is a connector, not a signal type. RGB, YPbPr, YUV are signal types. All of those signal types my be passed on a VGA connector. It is up to the source and display to have the types in sync.
Posted: Fri Jun 06, 2008 10:10 pm    Post subject:
The "VGA" term is really confusing because it has several meanings. Some people use "VGA connector" to refer to a DE-15/HD-15 (also called d-sub 15) connector. That's the connector that's on most notebook computers (until more recently).
Then, as if that isn't confusing enough, VGA is also used it to refer to the computer resolution of 640x480 pixels (S-VGA is 800x600 and XGA is 1024x768).
So, to clarify, your plasma has an HD-15 connector (sometimes called a VGA connector) that can accept either RGB or component (YUV/YPbPr). Not all displays with a "VGA connector" can do that - yours can. That's why Dave is asking you if you configured it in the menu - you have to tell the display what kind of signal you're feeding it - RGB or component.
ROFLmaker
Posted: Fri Jun 06, 2008 11:04 pm    Post subject:
On the remote if i go to input 1 (which is a VGA connector/port) I can hit a button that will take it from RGB to YUV. and as I hit the button it displays "RGB" or "YUV" correspondingly.
Person99
Posted: Fri Jun 06, 2008 11:46 pm    Post subject:
Buy the cable, hook it up, hit the YUV button--f*ck***' done! $10 and your off!
ROFLmaker
Posted: Sat Jun 07, 2008 12:23 am    Post subject:
THANK GOD!!!!! Thanks to all for your help and guidance!
ROFLmaker
Posted: Fri Jun 20, 2008 3:24 am    Post subject: Thanks
Hey you guys. Thank you so much for ya'll's help. The TV, phenomenal. And everything worked out. Still need to get a computer for the setup that will handle gaming but as of now... Its great!!!!!!
