Phil Smith
| Posted: Sun Jun 01, 2008 8:35 pm Post subject: OT: HTPC Refresh Rate Options For Plasma TV |
I'm getting nowhere with the AVS retards. I should have posted here to begin with. Let me know if you know anything about this (reply on this forum please!): http://www.avsforum.com/avs-vb/showthread.php?t=1035075
MikeEby
| Posted: Sun Jun 01, 2008 8:51 pm Post subject: |
Your set is probably Plug and Pray. Have your tried just connecting it to see what happens?
Phil Smith
| Posted: Sun Jun 01, 2008 9:06 pm Post subject: |
I'm afraid to! I don't know if feeding it more bandwidth than it can handle will hurt it or not.
MikeEby
| Posted: Sun Jun 01, 2008 9:12 pm Post subject: |
Plug and play is what the jibber jabber about the EDID was in the guys post. If your worried have it set to 800X600@HZ60 then fire it up, its under warranty.
| Posted: Sun Jun 01, 2008 9:15 pm Post subject: |
Phil, have you tried some things and had problems? Why don't you just fire it up and see what happens? I'd do that first. Like Mike says, EDID might provide all the available resolutions and refresh rates the set will handle for you.
What are you worried about? It'll handle 1080p/60 - just don't go over that for starters. Besides, like Mike says, it's under warranty.
Anyway, if EDID fails, I'd try 1920x1080 @ 59.94 (standard 1080p timing) first and see what that looks like. Then, you could also try standard 1080i, or at worst, standard 720p/60. The last thing I'd try would be the 720p/72 - it would be a rare consumer display that would be capable of syncing to a non-standard refresh.
Hopefully, it has a "pixel-perfect" or "computer" mode so you can map the video signal pixel-for-pixel to the panel. Otherwise, you get to search for the "magic" combination - the perfect active/porch combination to eliminate overscan like so many CE displays have built-in.
Phil Smith
| Posted: Sun Jun 01, 2008 9:22 pm Post subject: |
| MikeEby wrote: | Plug and play is what the jibber jabber about the EDID was in the guys post. If your worried have it set to 800X600@HZ60 then fire it up, its under warranty.
Mike |
I've fed it 1080p and 720p @60Hz with no problems. I assumed that HAD to be within it's limitations. But video isn't as smooth as it might be at 72Hz, so I'd like to try it. But I'd like to know ahead of time if it's ok.
The thing weighs 125 pounds, so even if such damage would be covered by warranty, I don't want to have to move it. It's heavy!
| Posted: Sun Jun 01, 2008 9:29 pm Post subject: |
Um..try 1080 24p.
It's a digital device.
You're confusing everyone with all this talk of interlacing and bandwidth, that's why you are getting no answers.
Phil Smith
| ecrabb wrote: | Phil, have you tried some things and had problems? Why don't you just fire it up and see what happens? I'd do that first. Like Mike says, EDID might provide all the available resolutions and refresh rates the set will handle for you.
SC |
Ok, I failed to catch the mention of EDID. So EDID might prevent it accepting anything but standard TV resolutions and refresh rates?
I tried 1080i@60Hz. It didn't display the lines interlaced. For some reason, it displayed each set of lines without spaces on the top half of the screen. The bottom half was a psychedelic light show.
| Quote: |
Hopefully, it has a "pixel-perfect" or "computer" mode so you can map the video signal pixel-for-pixel to the panel. Otherwise, you get to search for the "magic" combination - the perfect active/porch combination to eliminate overscan like so many CE displays have built-in. |
I'm not sure about that, but I don't think it does. It's very much a budget model. I'll have to check the manual.
Phil Smith
| Posted: Sun Jun 01, 2008 9:33 pm Post subject: |
| Mark_A_W wrote: | Um..try 1080 24p.
You're confusing everyone with all this talk of interlacing and bandwidth, that's why you are getting no answers. |
Ok, I've seen mention of running 1080p@24 but don't understand it. Shouldn't that flicker like crazy?
The electronics of a digital display would still have bandwidth limitations, correct?
Phil Smith
| Posted: Sun Jun 01, 2008 9:36 pm Post subject: |
Oh, by the way, my plasma is an *interlaced* display, even though it has 1920x1080 pixels. Apparently this is due to limited bandwidth.
MikeEby
| Posted: Sun Jun 01, 2008 10:18 pm Post subject: |
| Phil Smith wrote: | | Mark_A_W wrote: | Um..try 1080 24p.
The electronics of a digital display would still have bandwidth limitations, correct? |
I don't think so, your still thinking phosphors as in CRT's, digital is a different game they can turn on and off faster than a CRT can be rescanned.
| Posted: Sun Jun 01, 2008 10:20 pm Post subject: |
No, 24p will not flicker. Unlike a CRT display, which scans and refreshes according to the input signal, in a panel-based display, then panel and panel driver have their own native resolution and refresh. The display merely reformats any input signal to match the display. For instance, most digital displays have a 60hz native refresh - meaning the panel is updated 60 times per second, regardless of what you feed it. Some of the newer displays can handle 24p, meaning it will simply accept the input, but will judder because it's a 60hz display. Higher-end displays will actually re-sync the panel drive to match an even multiple of 24hz - as in 48hz or 72hz.
As for your particular display, it may be that if you feed it a 24p signal, that the display will automatically synch to an even multiple refresh... if you're lucky. If not, it will simply add 3/2 pulldown to display at 60hz, in which case there will probably be no advantage to running 24p.
Again, the display isn't technically interlaced. Only a scanning CRT is truly interlaced. From what I remember Dave saying, it sounded like Hitachi was doing some sort of pseudo-interlacing alternating-line update scheme. Since it may or MAY NOT be like interlacing, I wouldn't focus on that as far thinking about what sort of signal you want to input. I'd just do some tests - preferably with some motion tests and some resolution charts like on BD DVE, and see what looks best. Who knows, 1080/24p may look the best. 1080i/59.94 may look the best. 720p/59.94 may look the best (though I doubt it). Hell, until you try some stuff, it may not even handle anything besides those resolutions. It may not synch to ANY resolution at 72hz (that would be my suspicion) - it would be a rare CE display indeed that would synch to 72hz. Not even any consumer RPTV's I'm aware of would have synched to 72hz.
| Posted: Sun Jun 01, 2008 10:44 pm Post subject: |
You're spoiled. Welcome to the world of consumer electronics. Now where did you put that G-70
_________________ Chip
Phil Smith
| Posted: Sun Jun 01, 2008 11:18 pm Post subject: |
| MikeEby wrote: | | Phil Smith wrote: | | Mark_A_W wrote: | Um..try 1080 24p.
Mike |
Different model CRT PJs with identical tubes have different bandwidth. That obviously has to be due to the electronics, not the tubes. I assumed the same thing could be true of digital displays, and really, there is probably some differences. How else do you explain my plasma being 1080i? I doubt the display panel has anything to do with it.
Phil Smith
| Posted: Sun Jun 01, 2008 11:19 pm Post subject: |
| ecrabb wrote: | | Again, the display isn't technically interlaced. Only a scanning CRT is truly interlaced. From what I remember Dave saying, it sounded like Hitachi was doing some sort of pseudo-interlacing alternating-line update scheme. |
Well, everyone that sells it advertises it as 1080i. Maybe it's not true 1080i, but that's what everyone refers to it as.
| Quote: | | Since it may or MAY NOT be like interlacing, I wouldn't focus on that as far thinking about what sort of signal you want to input. I'd just do some tests - preferably with some motion tests and some resolution charts like on BD DVE, and see what looks best. Who knows, 1080/24p may look the best. 1080i/59.94 may look the best. 720p/59.94 may look the best (though I doubt it). Hell, until you try some stuff, it may not even handle anything besides those resolutions. |
I've tried everything you mentioned except 1080/24p and 720/72p. I settled on 720/60p because my FFDShow sharpen filter was working pretty hard (high cpu cycles) at 1080/60p, plus I couldn't see any difference between the two.
1080i didn't work. Read my previous comments on that.
| Quote: | It may not synch to ANY resolution at 72hz (that would be my suspicion) - it would be a rare CE display indeed that would synch to 72hz. Not even any consumer RPTV's I'm aware of would have synched to 72hz.
SC |
I didn't know that!
Phil Smith
| Posted: Sun Jun 01, 2008 11:23 pm Post subject: |
| stefuel wrote: | You're spoiled. Welcome to the world of consumer electronics. Now where did you put that G-70  |
You're right! I am spoiled and didn't even realize it. With all of the HDMI and other challenges CRT PJ owners have to endure, there are still a LOT of advantages to CRT.
I sold my G70 along with my house. I have another in storage though. I just need a house to put it in.
| Posted: Sun Jun 01, 2008 11:44 pm Post subject: |
| Quote: | | I've tried everything you mentioned except 1080/24p and 720/72p. I settled on 720/60p because my FFDShow sharpen filter was working pretty hard (high cpu cycles) at 1080/60p, plus I couldn't see any difference between the two. |
Wow. If you couldn't tell any difference between 1080p and 720p, that's really bad. Wait, what were you using to evalute the difference? Not just SD DVD, I hope. If so, SD is going to be well below any other res you might try - so, you probably wouldn't see much difference. It depends on how good the scaler in thet set is, but for SD DVD, you might even be able to feed the set 480p. There may be no benefit to going any higher than that. Running 480p would take less horsepower to apply filters, too.
| Phil Smith wrote: | | 1080i didn't work. Read my previous comments on that. |
I would rephrase that to say, "The variant of 1080i that I got with the setting I used on the video card and drivers I'm using didn't work."
I say that because I can practically guarantee you that display will synch to and display standard 1080i. If you couldn't get it to work, it could have been the settings you used, the video card, the drivers, or a combination of all those.
I had an older Nvidia card that simply would not display 1080i - no way, no how.
Phil Smith
| Posted: Sun Jun 01, 2008 11:55 pm Post subject: |
You guys are helping me a lot! I never was into video until I bought a G70 6 or 7 years ago. Being very content with my G70, I've paid little attention to anything else. Hence my total ignorance about everything.
Quick update on my TV's performance. I haven't had much time to play around with it, but here's what I think of it so far:
The motion problems I saw at Circuit City, and especially at Best Buy, are something I see very little of on my plasma. Turns out it was just a demo loop problem. Speaking of bad demo loops (I don't think I've seen a good one yet), there's really no excuse for them. Certain HD material looks fantastic on my plasma. Common sense says that only this type of material should be used when creating demo loops. But that's not the case! I was in Wallmart today and made a quick glance at their HDTVs. There was SD video playing, and not even particularly good SD!
We should go into the demo loop business. These stores have no clue how to properly display HDTVs. No wonder HD has been so slow to catch on...
While my TV looks very nice at times, most of the time it's not very impressive. While there is occasional weirdness that I have no idea what it is or why it happens, the main problem is the low contrast ratio. My TV supposedly has a 10K:1 ratio, but it's pretty hard to believe that's true.
I've found that I get the best picture (not good, but best) by cranking up the brightness. If I run the brightness at lower levels, it not only crushes the blacks, but it crushes all of the colors as well. Bottom line: it doesn't have near enough contrast ratio. There's nothing that can be done to make it look good. You can't get even half way decent blacks without crushing the sh*t out of everything. The scenes that do manage to look good are always very bright scenes, where the lower ire poor performance isn't as noticeable.
Phil Smith
| Posted: Mon Jun 02, 2008 12:06 am Post subject: |
| ecrabb wrote: | | Wow. If you couldn't tell any difference between 1080p and 720p, that's really bad. Wait, what were you using to evalute the difference? Not just SD DVD, I hope. If so, SD is going to be well below any other res you might try - so, you probably wouldn't see much difference. It depends on how good the scaler in thet set is, but for SD DVD, you might even be able to feed the set 480p. There may be no benefit to going any higher than that. Running 480p would take less horsepower to apply filters, too. |
It was upscaled SD DVD. I failed to mention that. I don't have any HD sources other than HDTV at the moment.
Part of my sharpen scheme that's different than most people is, I upscale, then sharpen. It makes a noticeable difference. For that reason, I need the HTPC to upscale. The refresh rate also has an impact. I might have enough CPU cycles to pull off 1080/24p. I'll have to give it a try.
| Quote: |
SC |
That's a good point, and you may be right, but the exact same 1080i settings worked with my G70. Not sure if that has any relevance or not.
| Posted: Mon Jun 02, 2008 2:10 am Post subject: |
It should display 24p as 24p....that's the whole point.
Otherwise it will accept STANDARD 1080i 60hz and convert to 1080p 60hz.
I assume you are using HDMI.
