papalek
| Posted: Mon May 26, 2008 5:07 pm Post subject: AmPro 3600 problem |
The 3600 I sold my sister has quit working. When you turn it on it comes up like it should as far as HV "crackel" and normal start. But there is no picture. If you look into the lenses you will see a vertical band in the center of all three tubes. The band is not bright enough to burn the tubes but it is very distinguished. Unpluging the video feed to the tube changes nothing. Adjusting the G2 for the tube does not make it any brighter or dimmer. Nothing changes the band of light and the remote says "RGB1 CHANNEL3" as it normally does. Pressing help or test on the remote does no good. The PJ is getting a signal because the frequency counter registers the frequency as it is changing slightly just like mine does.
I have almost a complete set of back up boards to try and swap out except the RGB input board and the focus board.
_________________ My current list of PJ's AmPro 1 1/2-4600,4200, 1/2-3600,2600.
I do love my AmPro's
| Posted: Mon May 26, 2008 6:54 pm Post subject: |
First question. You say adjusting the G2 doesn't make the line any brighter, does it produce a full raster though? If no then you say it has a vertical line. Is it in the center of the tubes? A vertical line would run top to bottom which means loss of Horz sweep. If this is what you mean then I would first swap the Horz output board. If no go then try the Horz supply and drive. If its a line from left to right then its loss of vert sweep, then try vert deflection. Info you gave is not real clear though. Also remember voltage supply problems can cause these issues also.
papalek
| Posted: Mon May 26, 2008 7:13 pm Post subject: |
All the voltage LED's are lit on the LVPS. Th line is about a 1/4 inch wide Vertical. It is in the center of the tubes,on all three. The G2 makes NO changes, brighter ,darker highth,width or any changes at all.
| Posted: Mon May 26, 2008 7:20 pm Post subject: |
Id try Horz output first.
Robert A. Hill
Joined: 19 May 2006 Posts: 182 Location: Simpsonville, SC
| Posted: Mon May 26, 2008 11:03 pm Post subject: |
Does increasing the blanking make any difference at all?
tse
| Posted: Mon May 26, 2008 11:39 pm Post subject: |
Time to break out the DVM. A good place to check for horizontal sweep is the transistor pass assy that is bolted to the side of the chassis near the horiz output bd. The center lead of the big transistors should be +40 to +150V depending on the frequency. 15KHz is near +40V, 64KHz will be near +100V. The left lead should be about 20% less than the center lead voltage. Ground the DVM - lead to the chassis. Be careful and don't short anything out with the probe tips.
Scott
Thomas Jefferson
| Posted: Tue May 27, 2008 12:02 am Post subject: |
I've had bad H output boards cause exactly that problem. ONe of the transistors/MOSFETs on the heatsinks short out, and sometimes take the driver chip out with it.
| Posted: Tue May 27, 2008 12:57 am Post subject: |
Hmmmm. I thought component level discussion was a big no-no. So I was told.
| Posted: Tue May 27, 2008 1:09 am Post subject: |
Yeah, but finding all of the bad parts isn't as easy as it seems. Miss one and you blow the whole thing up again..
| Posted: Tue May 27, 2008 1:15 am Post subject: |
| Curt Palme wrote: | Yeah, but finding all of the bad parts isn't as easy as it seems. Miss one and you blow the whole thing up again.. |
I know Curt but you told me about the component level discussions with the understanding of helping to locate the board then send it to you for repair, correct? That was the rule of the site.
tse
| Posted: Tue May 27, 2008 2:14 am Post subject: |
Curt is right about fixing H sweep problems. Alot of times you have to test/fix all three of the H defl bds together.
This problem might not be a sweep problem. The sweep fail circuit could be acting up, the G-2 circuits could have a problem, or there could be something wrong with the G-1/blanking circuits on the CRT cards.
Scott
Thomas Jefferson
| Posted: Tue May 27, 2008 2:23 am Post subject: |
| tse wrote: | Curt is right about fixing H sweep problems. Alot of times you have to test/fix all three of the H defl bds together.
Scott |
Exactly. Which is why I suggested that since Papalek says he has all the boards to try, then start changing boards, starting with the horz output and see what happens, if no go then try horz drive and supply. Or all 3 at once. If still no go then proceed from there. Having him replace mosfets and ics and probing with power on would be a big problem since he is not a tech.
| Posted: Tue May 27, 2008 2:47 am Post subject: |
Guys
Dont get me wrong here. I would be all for component level discussions. But when I am specifically told that component level discussions are not allowed, then when I comment on it about someone else, the same person gives further info as to say this is an exception to the rule. My thoughts are WTF, then why an exception here after I was told no.
You guys want to do component level, that's fine with me and I'll join right in. I'd even be glad to go over and help Paul with this if he needs a hand since he's only 45 minutes from me.
| Posted: Tue May 27, 2008 3:03 am Post subject: |
Well of course I'd prefer that all repairs be sent to me.
I didn't really make an exception here, other than it's quite possible that more stuff will get blown up in the process of troubleshooting. I spent a day here once going through 3600 H output boards, and they are not as easy as they look, so be forewarned... I blew quite a few parts up in order to figure it all out.
papalek
| Posted: Tue May 27, 2008 9:02 am Post subject: |
I will test the out puts as tse suggested but I will NOT do board level repair. I will swap out the boards with the working ones that I have. I am just surprised that the CPU is not reporting any problems.
papalek
| Posted: Tue May 27, 2008 9:06 am Post subject: |
And macgyver655, This is not even 45 minutes from you. It is at my sisters house which is in Finklea. It is on your side of Loris that is almost halfway between you and me.
| Posted: Tue May 27, 2008 12:31 pm Post subject: |
| papalek wrote: | And macgyver655, This is not even 45 minutes from you. It is at my sisters house which is in Finklea. It is on your side of Loris that is almost halfway between you and me.  |
No Problem. Just let me know if you need a hand.
papalek
| Posted: Tue May 27, 2008 2:18 pm Post subject: |
| macgyver655 wrote: | | papalek wrote: | And macgyver655, This is not even 45 minutes from you. It is at my sisters house which is in Finklea. It is on your side of Loris that is almost halfway between you and me.  |
No Problem. Just let me know if you need a hand.  |
Hey now Saturday she is having a big birthday bash, she is turning 38. We are barbecuing a whole hog. Yard games and plenty of beer.
| Posted: Tue May 27, 2008 3:34 pm Post subject: |
| papalek wrote: | | macgyver655 wrote: | | papalek wrote: | And macgyver655, This is not even 45 minutes from you. It is at my sisters house which is in Finklea. It is on your side of Loris that is almost halfway between you and me.  |
Hey now Saturday she is having a big birthday bash, she is turning 38. We are barbecuing a whole hog. Yard games and plenty of beer.  |
Hey, that sounds like an invitation. Unfortunately I already have plans this weekend. I'm launching my new toy in the deep blue sea. Want to start doing some ocean fishing. So if I stop posting , I probably ended up being shark bait.
papalek
| Posted: Tue May 27, 2008 3:58 pm Post subject: |
The girlfriend and I have been wanting to take one of them deep sea fishing charters.
