| Posted: Sun May 25, 2008 11:15 am Post subject: Speaker upgrade??? |
It's about time to replace my speakers in my small theater. I've never been into the audio end of things so go easy on me.
These will not be used for music unless it's part of a movie. They will be strictly for theater. Are there any special considerations to take into acct. when looking for theater only speakers? The only requirements I have for now is the main L and R speakers must fit within the area that the built in cabinetry provides. The opening for these are
18W X 28T x 12D. I can deal with just about any center channel speaker that works well with the mains. I plan to upgrade my reciever to the Pioneer VSX-94TXH. I will deal with the surrounds at a later date.
Is there a difference between a HT main and a music main?
_________________ Chip
| Posted: Sun May 25, 2008 12:19 pm Post subject: |
With speakers it all personal preference, what you may think sounds too bright some one else might say they sound detailed. The only way to know is to audition them, preferably in your own theater. Most high end shops will let you take them home to try out, I did this with my Phase technology speakers 10 years ago and I still have them. For center speaker make sure it matches the L/R's well. Now you have me wanting to do the Upgrade thing too!!!
| Posted: Sun May 25, 2008 2:22 pm Post subject: |
Frankly I've found speakers for HT to be far less critical than for 2 channel music use. I'd match the LCRs if at all possible, and listen to dialoge clarity over anything else. Usually the soundtracks to any movie are massively processed, which is why I've heard some really cheap speakers sound great for HT use and some higher end ones sound not so good.
| Posted: Sun May 25, 2008 3:25 pm Post subject: |
When you say "match the LCR's" do you mean three identical speakers or match the spec of the center to the L and R's?
Am I correct in thinking that for HT use, the center channel is the most critical. It seems that (in my theater) my attention is always focussed on the sound from the center.
I never crank the system much above 25%. It drives the wife crazy. My mains have 12 inch drivers as such, I've never felt the need for a sub. But the mains are 30 years old and I'd like more detailed /refined sound.
| Posted: Sun May 25, 2008 3:42 pm Post subject: |
Yes, common thought is to make all three front speakers identical to match timbres and frequency response. I've always wondered how close a left and right 8" 2 way speaker is compared to the same company's two 4" and a tweeter center channel speaker really is.
I have identical EAW 12" 2 way speakers across the front.
| Posted: Sun May 25, 2008 6:08 pm Post subject: |
stef, the mains aren't going to help for the sub channel if you're not specifically 'diverting' that channel to the fronts. Otherwise you just won't get any LFE, or only the little bit they left in the mix on the fronts (not very much, IME).
mike calcott
| Posted: Sun May 25, 2008 10:34 pm Post subject: |
Be cautious using oversized drivers in a small area, as this can cause standing wave cancelation. You are better using 8'' or even 6'' woofers and a good sub, which will result in a cleaner less muddy sound with cleaner dynamics. Since the centre channel is mainly for voice, large woofers are not required, a centre speaker with 4'' or 6'' drivers are better suited for this purpose. Make sure the output and impedence match on all speakers.
_________________ Old dog learning new tricks
| Posted: Mon May 26, 2008 5:08 am Post subject: |
Chip,
Has the Ampro destroyed your ability to see the different sections of the forum?
Since you seem to be pretty handy at making things, you should go check out HTguide and the DIY options.
Heywood Jablome
| Posted: Mon May 26, 2008 12:23 pm Post subject: |
| Spanky Ham wrote: | Chip,
Since you seem to be pretty handy at making things, you should go check out HTguide and the DIY options. |
Chip is currently a one-armed paper hanger. I don't think he's up to DIY speakers.
Chipper: I've got a line on a cheap set of KG4s like the ones you borrowed from me, with cabs in near mint condition but needing a replacement K8 woofer or two. And, I've got a spare KG4 to offer up woofage. CL Boston, $75 asking, probably throw him $50.
They'll even fit nicely in the openings, altho I can't predict the reinforcement or cancellation of having a freestanding speaker with a passive radiator in a boxed-in shelf.
http://www.klipsch.com/products/discontinued/details/kg-4.aspx
KG 4 Specifications
frequency response 38Hz-20kHz±3dB
power handling 100 watts maximum continuous (500 watts peak)
sensitivity 94dB @ 1watt/1meter
nominal impedance 6 ohms
tweeter K-74-K 1" (2.54cm) Phenolic dome compression driver
high frequency horn 90°x40° Exponential Horn
woofer Two K-8-K 8" (20.32cm) Poly ICG cone active / KD-12 12" (30.48cm) Fiber-composite cone passive
enclosure material Medium density fiberboard construction (MDF)
enclosure type Bass reflex via passive radiator
dimensions 24.25" (61.6cm) x 15.75" (40cm) x 10.75" (27.3cm)
weight 40 lbs. (18.2kg)
finishes Walnut Oil, Oak Oil, Finished Black
built from 1985
built until 1992
_________________ "Those countries which lag behind in industry, in the application of mechanics and technical chemistry, in the careful selection and utilization of natural products, where the respect for such activities does not permeate all classes of society, will unfailingly decline in prosperity. They will sink faster when neighbor states, with an energetic exchange between science and industry, go forward with renewed vitality."
Heywood Jablome
| Posted: Mon May 26, 2008 12:45 pm Post subject: |
Forgot to mention... I've already been in contact with the KG4 guy and have offered to come'n'look today.
| Posted: Mon May 26, 2008 2:23 pm Post subject: |
Nope, but I always seem to get quicker HT related questions answered here. I ain't ascared of building my own but would not know where to accuire the bare components and design the correct crossovers. I do have the equipment to build the cabinets and have actually thought about what I'd build if I did my own (cabinet wise). In my situation, I would guess that a front vented cabinet for the mains would be in order. That being the case, if what Curt says is true, then the center would have to match. I do love woodworking and can build cabinets that would match the quality of anything commercially available.
Oh ya, the only thing that my AmPro has destroyed is the myth and my desire to upgrade
| Posted: Mon May 26, 2008 2:36 pm Post subject: |
| mike calcott wrote: | | Be cautious using oversized drivers in a small area, as this can cause standing wave cancelation. |
I do somewhat agree with the rest of your post, but please explain the above. I thought I was pretty well versed with standing waves, but this one stumps me. I thought standing waves had to do with resonances, room dimensions and frequency? How can the size of a driver/speaker affect standing waves?
Heywood Jablome
| Posted: Mon May 26, 2008 2:48 pm Post subject: |
If you go the way of the KG4-as-mains, I've also got two crossovers, mid-high horns, and passives to go toward building a timbre-matched center.
I, myself, am still seeking a set of ugly Heresies to match my Cornwalls or La Scalas (still have not decided which to keep.)
| Posted: Mon May 26, 2008 2:53 pm Post subject: |
Whenever I see the word 'Heresey', my brain equates it to 'Heretic' and I giggle inside..
| Posted: Mon May 26, 2008 4:48 pm Post subject: |
Heh heh... and whenever I see "Cornwall", I think "Cornhole" ... and I giggle inside.
jask
| Posted: Mon May 26, 2008 5:04 pm Post subject: |
whenever I see the word BLOWS......
| Posted: Mon May 26, 2008 5:05 pm Post subject: |
| jask wrote: | | whenever I see the word BLOWS...... |
Funny, the Kamloops bathroom walls say exactly the opposite...
(just kidding!)
| Posted: Mon May 26, 2008 8:12 pm Post subject: |
All that is really funny but when I hear the word "t*ts" I think of............ahhh..........t*ts
| Posted: Tue May 27, 2008 8:11 am Post subject: |
| Curt Palme wrote: | | mike calcott wrote: | | Be cautious using oversized drivers in a small area, as this can cause standing wave cancelation. |
I do somewhat agree with the rest of your post, but please explain the above. I thought I was pretty well versed with standing waves, but this one stumps me. I thought standing waves had to do with resonances, room dimensions and frequency? How can the size of a driver/speaker affect standing waves? |
It's complete rubbish as far as I am concerned Curt.
I have four 15" woofers in a small room
mike calcott
| Posted: Tue May 27, 2008 11:30 am Post subject: |
My reference to speaker size in relationship with room size refers only to the main front speakers, not subwoofers.
Many speaker manufacturers produce speakers with multiple mid size speakers rather than the 15" woofer 8" midrange and 4" or horn tweeter. the The larger woofers produce ultra low frequency's which result in a longer distance to dissipate.
| Description: |
 Download |
| Filename: |
Standing waves are commonly set up in rooms by low frequency sounds with long wavelengths.doc |
| Filesize: |
20.5 KB |
| Downloaded: |
325 Time(s) |
