My new Barco Cine8 - questions to the specialists...
Goto page 1, 2, 3  Next
capa
Posted: Sat May 24, 2008 2:50 pm    Post subject: My new Barco Cine8 - questions to the specialists...
Hi all.
just got my new Cine8 LimoPro mounted with the help of two friends Smile
Has 4400 hours on the tubes, first hand, installed and adjusted by a Barco technician back in 2002.
The former owner had it installed in quite an expensive setup, Vigatec Dune F, Stewart TEK130 Screen
and I would like to sort out some details before I put this projector into action again.
Not sure if I should have split all my questions into several topics here or if the holistic approach
is better... I'll give it a shot...
My previous setup was with a BD801s and my HTPC only.
1. Alignment/ Adjustment
1.1 Dimensions based on Barco's Lens.exe
This time I have built on the settings which Barco's adjustment tool (Lens.exe) provided.
From your experience: Are those values reliable? Or would you suggest taking a closer
look at the image size on the tube surface instead?
2. Settings for my HTPC
2.1 Which resolution?
For the standard DVD content coming from my MediaPortal what would
be the optimal resolution (PAL standard) which I should feed to my PJ?
Have Powerstrip installed already and have a graphics card which supports user defined resolutions.
The BD801 needed sync on green (negative). Is this the same with the Cine8?
2.2 Which graphics card?
At the moment I'm running an MSI StarForce FX5200LE which does support user defined resolutions through
Powerstrip but is quite noisy. From your experience: Which brands do support Powerstrip best? ATI? And are
there any passive cooled cards available from those manufacturers? (Need something with AGP bus...)
3. Blu Ray Content/ PlayStation 3
I'm totally new to HD content. A colleague of mine has suggested that I should try a PS3 to be able to view
Blu Ray content since the PS3 is one of the least expensive Blu Ray players available at the moment and the
picture produced would look really great (he does not own a PJ though).
3.1 Connection
3.1.1 HD Fury - an option for me?
During research I came across the HD fury adapter.
Would it make sense to hook the PS3 to port 3 of the Barco via a HD fury adapter?
3.1.2 Cables needed to connect HD fury to Cine8
I've got 10 meters between (future) PS3 and my Cine8, so I need a HDMI to DVI cable
to get to the HD fury which is connected directly to port 3 to hook up to the PS3?
Those cables are available in almost any price range. What quality would be reasonable
in this case based on your experience?
3.2 Possible resolution on Cine8
As far as I understood the Cine8 has problems with 1080p in as-delivered condition.
The Mike Parker mod would be able to solve that "problem"? Correct?
So at first I'd be limited to 1080i, right?
Does the PS3 allow to send the signal at 1080i instead of 1080p?
(Never even had a chance to take a closer look at a PS3 so far....)
4. Scaler
This has been one of the most confusing parts on my journey through that new technology...
Would a scaler contribute to my new setup and which one fits my needs?
I do not intend to buy one right away but I would like to know if it would help me...
4.1 Confusion caused with scaler and LimoPro option...
As far as I understood the LiMo Pro option is capable of doing line-doubling and -quadrupling.
Doesn't this interfere with a scaler like the Vigatec that fed this PJ before?
4.2 Will a scaler be useful for standard DVD content?
I used to watch just DVDs from my HTPC. Based on your real-world experience: Does a scaler
really enhance the image through doubling, quadrupling and other techniques?
4.3 Which one?
Even though this might start a battle... There are so many brands out there, what would you
suggest in my case? I had the opportunity to get a Key Digital HD Leeza a few days ago
but still was not sure if this really fits my needs so I decided to wait for your replies first before
I decide to buy anything in this area....
Have a DVDO iScan VP 50 SDI in my Ebay watchlist as well as an DVDO iScan VP20.
I'm really confused by that big variety... Hope you can shed light upon this for me...
Hope this long post does not scare the most of you away and it makes sense somehow
and you can understand my English... Wink
I really appreciate your input.
Best regards
Carsten
Posted: Sat May 24, 2008 3:19 pm    Post subject:
I do not own a Barco but for setting up screen size I would do it by forst maximizing the raster on the tube face, more phosphor means brighter pic and better resolution.
the HD fury will be great since moome I do not think made a HDMI/DVI card unless you go with a crad by Greg Eisemann do a search for him On AVS forums. he specializes in Barco mods.
For a scaler I only have Used Lumagens and they are very respected in the CRT world, especially since they have now added color gammut controls to their Vision series, it also has 11 point Gamma controls.
the PS 3 has been a good player for most, but if you can fine A LG BH100 or LG BH200 i think you'll be pleasantly suprised. There has been a region hack found for both sd and BD disc's. look at the Dual formatt players forum on AVS also for more info, its in the sticky's.
LG BH100 AVS thread, middle of region free talks
LG BH200 Sticky
I think it could do 1080p but 1080i is what most say to run an 8 incher at I run 1080p@48 on my marquee 8500 ad love it.
Hope i helped out a bit.
Posted: Sat May 24, 2008 5:39 pm    Post subject: Re: My new Barco Cine8 - questions to the specialists...
Never use the install programs. Look in the lenses. SEe the bottom of this page :http://www.curtpalme.com/TubeCondition_PoorInstall.shtm
I don't find it worth the hassle to have different resolutions for HD and SD. So I use 1080i for everything.
Since you're thinking of adding a PS3 I would use that for everything and ditch the HTPC. You won't go back to the HTPC for playing SD content, and you likely will not play much SD content anyway once you see HD.
It accepts positive sync.
Use the PS3. Smile
Correct. It's what I use and it also replaced my HTPC for SD content. The scaling is very good.
3.1 Connection
Use port 5 for a Cine8. I use a HDFury with an RTC2200 as follows:
PS3 -> HDMI to DVI cable (included) -> HDfury plugged into -> RTC2200 -> long VGA to 5BNC cable.
RTC2200 is for gamma boost and cable driver. The HDfury is an excellent HDMI/DVI to RGB converter. Get the Advanced Kit just in case.
See above. Use your existing RGBHV cable. If you don't have one then you can use a longer HDMI cable too. See the sticky threads here: http://www.curtpalme.com/forum/viewforum.php?f=13
It'll do 1080p/60, you just will likely prefer 1080i/60 like the rest of us with Cine8 level projectors.
Yes, the PS3 supports 480i, 480p, 720p, 1080i, and 1080p.
4. Scaler
Skip the scaler. You don't need one. Especially if you don't know why you'd need one.
The only thing that the scaler will (or could give you) if you buy a good one is advanced gamma management, 72hz instead of 60, and a few other things. They're a hard sell these days since all sources you'd want to use (other than VCRs or other low end items) scale very nicely. Skip it for now. Maybe in a year or two if you notice and know why you'd want one, then start thinking about it.
Don't use the built in LIMO or LIDO scaler in the Barco. It's not very good.
That's all your HTPC does as well. Skip it for now.
4.3 Which one?
Skip it. Use the scaler in the PS3.
If you absolutely must watch older content like VCR or laserdisc then use the built-in LIMO/LIDO scaler in the Barco. It's not great but then, the content is going to look very bad anyway that it really doesn't matter.
Good luck!
Posted: Sat May 24, 2008 10:29 pm    Post subject:
One minor addition to what Kal and Athanasios said about ignoring the Barco Lens recommended mounting and maximazing rasters... The only problem with maximizing rasters at this point in the projector's tubes' life, is that you will probably see the wear the tubes almost certainly have. With 4400 hours on the clock, that's enough to show wear pretty badly in whites and grays. Depending on how it was previously installed, you might be able to shorten the throw, or you might have to use it where it is if you don't want obvious brighter/bluer bands on the sides of the image.
I agree with Kal and Athanasios that you just start out with a good Blu-ray player and see how you like the scaling from one of those players. I love my PS3, but there is a downside. You won't get advanced audio unless you have a newer HDMI-based AVR or processor. One of our pickier members - Dave/Person99 - bought one of the LG players and really likes it.
https://www.curtpalme.com/forum_archived/viewtopic.php@t=10423.html
On 1080i/p, you'll get different opinions. It really depends on your sources, the projector, and your viewing distance. Kal and some others advocate 1080i, as do I in a lot of cases. But, since I got my G70 installed (a comparable projector to yours) and saw 1080p on it, I'm BLOWN AWAY. Consider how close I sit, though - about 1.2x screen widths. 1080i might look excellent a little further away from the screen.
Start slow, learn, and figure out what you like and don't like. You don't have to do it all at once. Congrats on getting an excellent projector!
Axatax
Posted: Sun May 25, 2008 12:20 am    Post subject:
Compare your existing SD DVD setup carefully with the PS3. The PS3 is a fine BDP, but I wouldn't ditch my 2900 SDI/VP50 combo for SD use. The PS3 scaling is fine, but the MPEG decoding and deinterlacing is abhorrent. The HD-DVD players had this licked.
Posted: Sun May 25, 2008 6:30 pm    Post subject:
I'd never give up the HTPC. You have zero control if you're using blackbox equipment, unless you spend gobs of money. It seems ridiculous to pay a thousand bucks for a thing to add a gamma boost when you can do that, plus have a big library of content, plus do image post processing, plus play multiple kinds of content in multiple resolutions, plus have specific control over said resolutions and timings, plus use it as a DVR, plus have direct control over audio routing and post processing, plus... etc. And all of that for under $1500 even WITH a bluray drive and enough storage to queue up ten BD movies.
If you have the time and knowledge to use an HTPC, use an HTPC. Doing anything else is like cutting your legs off because it's too much trouble to walk.
Posted: Sun May 25, 2008 6:40 pm    Post subject:
Using your metaphor, I like to think of the HTPC as more like having to do a little light arthroscopic knee surgery every damn time I want to go for a walk, along with accepting the occasional complete amputation, fitting and installation of a prosthetic leg. I also never really completely trust the legs and just hope they continue working while I'm walking.
With the "black box" legs, I just get up out of the chair and start walking. They're not fast, powerful, or configurable, but they always work.
Wink
Posted: Mon May 26, 2008 1:25 am    Post subject: Re: My new Barco Cine8 - questions to the specialists...
Carsten
Hi Carsten, nice projector
For a good curent video card on the AGP bus check this out:
http://www.sapphiretech.com/us/products/products_overview.php?gpid=227&grp=2
it's not passively cooled, but its the fastest card on the AGP bus right now that works with powerstrip.
A lesser ATi card may work for you too if you don't want to spend that much.
WTS
Posted: Mon May 26, 2008 1:12 pm    Post subject:
The cine8 will accept either positive or negative syncs when using the RGBHV inputs.
Walter
Person99
Posted: Tue May 27, 2008 3:06 pm    Post subject:
It seems to me that you don't understand the other options that are available.
Person99
Posted: Tue May 27, 2008 3:07 pm    Post subject:
I fail to see why they are not fast, powerful, or configurable.
jask
Posted: Tue May 27, 2008 7:35 pm    Post subject:
MORE fast,powerful, or configurable....and flexible, easily and less expensivly upgraded, can run open source or proprietary software, can easily be used to play,store compile or edit various content,codecs,software games, etc.
These both have a place in home theater but the motiavated HTPC user has a LOT of options. want to upgrade your player to HD? BR? install better Audio? play back PAL material? digital and/or analog path? make dynamic room audio adjustments etc etc
Person99
Posted: Tue May 27, 2008 7:55 pm    Post subject:
How do you deinterlace and frame rate convert the 5C protected 1080i content from StarzHD with your HTPC?
A Lumagen for <$1000 will do this pretty much flawlessly. As soon as the HTPC does this as well and as cheap and as stable, it might have a place in a theater. Until then, it is just a toy for hobbyists that prefer headaches over watching movies. Smile
Basically, from all the pros and cons and everything else I've read and played around myself only leads me to one conclusions: An HTPC is really only a thieves tool. The only real reason to have one is to steal. If you're not stealing they are less functional, more problematic, and more expensive than other options.
MikeEby
Posted: Tue May 27, 2008 8:09 pm    Post subject:
Dave,
Not everyone that owns an HTPC is a thief, I own about 50 BR and HD-DVD disk, never ripped a disk in my life, my time is better spent, I am sure Phil would agree with me too. For me it was a cheap way at the time to play HD-DVD's and BR from the same box plus I get 1080p @ 72 Hz and analog audio and video out, SO THERE! Smile
Edit: There is one other thing a NEC doesn't seem to like standard 1080p timings, this would require an external scaler another $1000 to add to the tab + the cost of a Moome or Fury which is technically an illegal device.
Person99
Posted: Tue May 27, 2008 8:43 pm    Post subject:
MikeEby wrote:
Dave,
True, it was a bit of hyperbole.
I'm curious to see if the HTPC's day will come back. It used to be that people got HTPCs for excellent DVD playback. You used to have to buy a $1500+ scaler, a DVD player, and have it SDI modded. That was about $2500+ for excellent DVD playback. An HTPC at $1500 was a bargain!
These days, it is not a bargain, it is a hassle and costs more. Consider this, you use your theater primarily for movies. Your sources are:
- Cable
- DVD
- Blu-ray
- HD DVD (maybe)
You want something like 1080p/72 output. These are your options:
HTPC:
- use the HTPC for DVD, BD, and HD DVD playback. Get very good playback for about $1500.
- You have no way to get 1080p/72 from your cable box
- You have no way to archive the HD movies from your cable box (such as Star Wars, The Incredibles, etc--movies not yet available any other way in HD).
So, the HTPC costs you $1500 and cannot do everything.
Scaler (to accomplish the same thing as above):
- LG BH100 BD/HD DVD player
- Oppo 970 DVD player
- Lumagen HDP
Those three total about $1150 these days and you have playback just as good as the HTPC for BD, HD DVD, and DVD plus, you get to deinterlace and frame rate convert your cable--something the HTPC cannot do.
So, unless you want to steal content, why spend $350 more for more headaches and not even get the ability to deinterlace and frame rate convert that broadcast of The Incredibles in HD?!?!? That is crazy!
But, let's go ahead and put that $350 to good use! Buy a Mitsu 2K D-VHS machine and a JVC D-VHS machine. Now you can archive all those 5C protected movies AND use your scaler to deinterlace and frame rate convert them.
You just spent the same $1500 and got CONSIDERABLY more movie watching functionality!!!! This is why I like to point out the current shortcomings of HTPCs. They had their place at one time and if you have one, they make some sense provided you don't mind the headaches. These days, they just don't make much sense and they make no sense if acquiring it new. Unless, of course, you want to steal--then you get extra functionality that you can't get the other way.
As an aside, I've never been to Phil's where he did not have to reboot the HTPC. I've never had to reboot my DVD player or Lumagen to get them to function properly!!!
Posted: Tue May 27, 2008 9:08 pm    Post subject:
I use a HTPC,
My main reason was cost, my entire Blu-ray HD-DVD machine cost me less than $600 in parts total. The HTPC also makes sense for me because I use it as my main PC. I don't have cable and have no interest in it so that is one problem I don't have to deal with. I also like having the capibility to run a front-end that intergrates my music, pictures, SD-DVD collection, and recorded Tv shows (ATSC OTA) all into one clean easy to use interface.
Sure the HTPC has problems and can be buggy but for me I feel the benifits outweigh the negatives. I'm wondering why Phil was having trouble with his HTPC always having to reboot to fix problems, once I have my machine setup right it will run day in and day out without any problems. Usually it will run for weeks at a time without a reboot.
Erik
Posted: Tue May 27, 2008 9:10 pm    Post subject:
Why in God's name would you spend $1500 on an HTPC? I'm hard-pressed to find a way to spend $1000 on a 4gb quad-core monster with a great 3D card, let alone a machine that needs few of the most expensive specs for the previous!
Oh, and if timeshifting rented movies makes me a thief, then consider me guilty. If storing the media I already own on a PC so I can access it without swapping disks around makes me a thief, then consider me guilty. If having the ability to game, play demos and other real time content, and control lighting and audio automatically makes me a thief, then consider me guilty. Otherwise, consider the maxim: Better to keep your mouth shut and be thought a fool than to open it and remove all doubt.
Axatax
Posted: Tue May 27, 2008 10:05 pm    Post subject:
The software players also can't touch the decoding and deinterlacing performance of dedicated hardware, as Secrets has proven time and again in their testing.
The VPxx and Lumagens (and most other modern outboard processors) consistently ace the entire testing battery (100 point scale), while the software players hover in the 20-60 point ranges. FFDshow won't help you here.
You get what you pay for.
Posted: Tue May 27, 2008 10:18 pm    Post subject:
I'd love to see some actual frame-on-frame, uncompressed screenshots. None ever seem to be forthcoming.
Axatax
Posted: Tue May 27, 2008 10:35 pm    Post subject:
By your tone, I gather you disagree. Secrets has an open testing methodology which can be repeated by anyone who is willing to understand and digest the process.
How do you propose comparing static screenshots of deinterlacing performance (which is tied to motion)?
Page 1 of 3
