| Posted: Fri May 09, 2008 12:41 pm Post subject: |
| Quote: | | The filings on the Sony rings seem to come up and curve to the outside of the ring like the north pole was on one side and the south pole was on the other side. My vision is that the electron beam goes down the center and is positioned or shaped by the influence of the surrounding magnetic fields. |
I agree, if you look at the shavings in your pick , the ones on the outer side of the ring, they go outward away from
the ring, so the electron would get pulled toward the ring. So this means that the beam is pulled to the center of the tube by the CPC magnets field, not pushed. Would you agree with this?
Joust
TV/Projector: Marquee 8501LC
| Posted: Fri May 09, 2008 12:53 pm Post subject: |
I would like to see you try what I suggested.
after you sprinkle the filings on the paper. Tap it a few times. the filings will move and further define the magnetic structure inside the rings.
those forces are very weak inside there. if you simple shake them on, they more or less stay where they lie.
i have a 4 pole somewhere. I can try it when i get a chance. but I too am up to my eyebrows in alligators.
| Posted: Fri May 09, 2008 1:58 pm Post subject: |
ok guys, I found the post with how CMJ made the CPC 6 pole magnets he mentions them in a few threads but here is where he describes it with the most detail.
CMJohnson from the frankenyoke thread:
| Quote: | The extra set of rings (which have no color code on them or adjustment screw) are not magnetized. They will do nothing.
I've successfully turned "blank" CPC rings into fully functional 6-pole rings, done first by erasing whatever field may be in them with a
bulk tape eraser, and then applying six pairs of 1/4" diameter supermagnets to the CPC ring pair, spaced evenly, alternating polarity, and letting the mess sit for a while. A day is good. Then remove the magnets without letting them slip toward any other magnets, and you should have a good working set of 6-pole rings.
Collect all the 2-pole (flare only) and 2,4 pole (flare and astig) CPC assemblies you can find. Rebuild them into 2,4,6 pole sets after
remagnetizing the spare flare set to be 6-pole pairs. |
sounds like a simple procedure, i am not sure if those blank rings have any tabs on them so we could move them around the neck. We might have to attach some to them some how? have to look at a set first.
Joust
| Posted: Fri May 09, 2008 4:25 pm Post subject: |
Marquee rings do not have tabs
they have teeth with a rack and pinion type setup.
there is a small registration tab that has a colour code painted on it. Blank ones have no colour.
my only quesiton is:
do the "recording" magnets go on the face of the ring, or on the edge? i think the edge.
| Posted: Fri May 09, 2008 4:42 pm Post subject: |
| Joust wrote: | Marquee rings do not have tabs
do the "recording" magnets go on the face of the ring, or on the edge? i think the edge. |
yeah the older one are the twisting type which is a much nicer design, the new one from VDC are the tab types
you would lay them on to of the flat part of the ring i would imagine..we need CMJ to post here.
Joust
| Posted: Fri May 09, 2008 5:57 pm Post subject: |
Oh. i like the little knobs on the pinion gears.
i would disagree with your approach of laying them on the flats. you would want a pole on the edge IMHO.
Joust
| Posted: Fri May 09, 2008 6:11 pm Post subject: |
OK,
I just scored 10 super magnets.
I'll try it
| Posted: Fri May 09, 2008 6:23 pm Post subject: |
| Joust wrote: | Oh. i like the little knobs on the pinion gears.
i would disagree with your approach of laying them on the flats. you would want a pole on the edge IMHO. |
I dissagree!!! I would think you want the entire mass of that section of ring to be magnetized , I sent CMJ a pm to come explain better but lat time he posted was in april. we'll see.
PS and good luck !!!!
Joust
| Posted: Fri May 09, 2008 6:51 pm Post subject: |
I guess the thing to determine is if the pole of the magnet we want created is prependicular or horizontal to the neck of the tube.
I'm thinking it needs to be perpendicular to the neck to affect the beam. I think i hear you saying you want it horizontal to the neck.
another think CM said was that he set the magnets with alternating polarity. and he used 6 pairs.... I had only 10 magnets.
but I scrounged up two more
| Posted: Fri May 09, 2008 7:12 pm Post subject: |
| Joust wrote: | I guess the thing to determine is if the pole of the magnet we want created is prependicular or horizontal to the neck of the tube.
but I scrounged up two more  |
I concur, you are right i did not see he use 6 pairs i only saw "6". so i guess you would put one on the inside of the ring the other on the out side in the same location. now which polarity should be facing inward? now should it be pushed or pulled?
because if the beam is electrons they are negatively charged so you'd want the same negative polarity to face the beam toward the center if it pushes the beam... the opposite to pull the beam? so which is it or don't you think it matters? I wish Chris would chime in here !!!
Joust
| Posted: Fri May 09, 2008 7:43 pm Post subject: |
something else you missed?
Joust
| Posted: Fri May 09, 2008 7:45 pm Post subject: |
we don't need Chris.
we are Re-pioneering I don't' see other known modders saying too much either.
Joust
| Posted: Fri May 09, 2008 10:28 pm Post subject: |
no and yes.
yes but then alternate them
| Description: |
| Filesize: |
11.07 KB |
| Viewed: |
11118 Time(s) |
| Posted: Fri May 09, 2008 11:08 pm Post subject: |
I've done this. Made 6 pole pairs.
Start with ANY spare pair of CPC rings.
Using a commonly available bulk tape degausser, degauss the rings to remove their current pattern.
The trick to a degausser is that you leave it turned on as you back away slowly from the magnets until you're well out of range of them,
so as to leave no residual magnetic field.
I then took six pairs of 1/4" diameter Neodymium disc magnets and marked them for north and south poles using paint, or even
permanent markers (but it will rub off the plated magnets before too long) and then carefully clamped the rings together with the
magnets, with the magnet pairs arranged evenly in a circle around the rings, and alternating polarity around the circle. So one
side has n-s-n-s-n-s- and the other side has s-n-s-n-s-n- polarities showing.
Once the magnet pairs are clamping the rings and are properly spaced, gently rub the pair around a little on the CPC ring pair,
but GENTLY, and not far. This helps to "persuade" the magnetic domains to assume their new orientation.
It's important to NOT let one pair of magnets get too close to another pair or they'll attract each other.
It's also important to place the magnets where they belong correctly the first time, and NOT try to slide them around the ring into
proper position.
If you do either of those, remove the magnets, demagnetize the CPC rings, and start over.
CJ
| Posted: Fri May 09, 2008 11:15 pm Post subject: |
Hm. Guess I assumed you would place the magnets on the flat sides of the rings, not inside & outside. It does make sense, though.
Joust
| Posted: Sat May 10, 2008 1:17 am Post subject: |
i was imagining on the inside and outside not the flats.
