Ashfallen
| Posted: Sun May 04, 2008 6:04 am Post subject: Ampro 4000G newbie, need help (or an offer for parts) |
Hi.
Yesterday I bought, through Ebay, 5 Ampro 4000Gs and a large number of assorted parts for them, many of which appear to be unopened in their boxes/packets. I paid A$511 for all this, and if I can get at least one of the things working, I'll consider it a bargain. If not, I'll take offers on the parts. (I live in Brisbane, Australia, if anyone's thinking of making me an offer. I would like to get it working, it's a interesting project idea, but I'm not committed to it and if someone more keen wants the parts, well, you can have 'em for what I paid plus any shipping etc costs, and I'll go implement Plan B.)
I'd also trade parts for in-person help and tuition, if anyone reading this is in Brisbane.
Anyway. Included in the deal was an operating manual and a technical manual, and I have skimmed through both. I consider myself familiar with electronics and computers at an expert-user level (ie, I can generally figure out what does what, and replace a dud part with a working version of the same part). I've put together and upgraded several dozen computers over the last twenty years; I'm not afraid of a screwdriver.
Once my friend and I got the things home (I hadn't expected them to be anywhere near so huge and heavy!), I designated the best-looking of the 5, with the cleanest interior, to be the "recipient". My plan is to pull any dud parts out of it, and replace them with hopefully-working parts from the others. However, so far, so bad. I've hit a major snag immediately, and I'm hoping someone here might be able and willing to help me.
According to the operating manual, I should plug in a remote to the "HOST" RS232 socket, plug a power lead into the projector, turn on the rocker switch, and it should spin up the power supply fan, turn on the (external) power supply LED and (internal) fuse LEDs, and show an "INITIALIZING" message on the remote.
However, the remote LCD lights up but shows no message, three of the CR9 lights turn on, the fans do not spin up, the rear panel LED and fuse LEDs do not turn on, and nothing further occurs.
I've unscrewed the fuse panel and checked that all of the fuses are intact. I've tried several of the remotes, to no avail. I've swapped out three of the AC/DC power switching units, to no avail.
The CR9 light status, looking at it from above with the CRT lenses to my left and the back panel to my right, are as follows:
1 - off
2 - steady red
3 - steady red
4 - off
5 - off
6 - off
7 - faint flicker red
8 - steady red
9 - off
10 - off
According to the manual, this indicates a "1[sup]2[/sup]C" fault, which I believe is a CPU fault. I've swapped out two CPU boards so far, and all have displayed the same behavior. Could this be a CPU battery issue? Is it just a 760mAH/3.6V lithium battery like any other, and will replacing it with one potentially solve the problem?
Why would the fuse LEDs stay dark, the fans not spin up, and the rear panel LED stay dark?
Any suggestions are welcome, please. Offers for it all are welcome too. I want to get it working, or get rid of it to someone who will make use of the huge numbers of parts. I'm not strongly committed to either course of action.
jantje112
| Posted: Sun May 04, 2008 9:38 am Post subject: |
Probably fitted with the sd146a tubes. It's ES focessed. The projector should deliver a good image, afterall it's 9" and LC. Repair one, keep one for parts and sell the rest for parts. What lenses does it use?
| Posted: Sun May 04, 2008 11:46 am Post subject: |
First guess is it sounds like a remote address or baud rate problem. Refer to Chapter 10, around page 89 to check and/or change settings on the CPU board to match the remote.
| Posted: Sun May 04, 2008 11:59 am Post subject: |
Was #8 led lit with all the cpu boards you tried. Do you remember which cpu was the original to the projector your testing. If one of the cpu's happens to have different firmware you may get that I2C fault. Other wise there maybe a communication problem with another board in the projector. I know on the newer cpu boards you can turn off the I2C test with one of the switches on the cpu board. Not sure on the older board. Even with the fault though you should still have read out on the remote which is why I think it maybe a remote address problem. You can use a volt meter to test the battery on the cpu board. Still not sure if a dead battery would cause no remote screen though. Good luck.
| Posted: Sun May 04, 2008 1:23 pm Post subject: |
I think it's a remote address issue also. I can't remember the dip switch settings for the 4000G but it should say in the manual. They were probably all from one installation and controlled in a host/slave configuration. If so, it's a simple dip switch change.
_________________ Chip
| Posted: Sun May 04, 2008 1:56 pm Post subject: |
Your first thing to check is the memory battery on the CPU board. Guaranteed it's flat. Should read above 3.5 volts. If it's under 3, the set will do all sorts of strange stuff, including the blank remote screen w/no powerup. Usually the set will then also go into 'executive' mode, and you need to enter '909, code' to unlock it again.
Since you have 5 sets, check the layout of the registration board, and if they are the same between all 5 sets, swap out CPU boards if you find one with a good memory battery. If not, I have memory batteries here, or google 'keeper II' and you should find someone that has them. Ampro made about 5 versions of the 2000/4000 chassis, the CPU boards will not interchange between models and work correctly. But until you get 'Ampro 4000' showing on the remote at main power turnon, you're not getting anywhere with these sets.
Important: If you do board swaps, label the boards so you know which one came out of one chassis. Ampro did enough circuit changes back then that you might cause operational issues if you swap boards at random. That messed me up too many times while working on sets here.
I might be interested in some of the HD10 lenses that are on those sets, as I'm out.
| Posted: Sun May 04, 2008 2:03 pm Post subject: |
BTW, can you link to that auction so we know what you have? I can't find it in the completed listings on eBay.
| Posted: Sun May 04, 2008 5:36 pm Post subject: |
Welcome to the Ampro 4000. Keep ALL the spare part's. You're gonna need them.
They throw a good picture once setup. It's keeping them running that's the challenge. I've had issue's with mine in the two year's I've owned it. Usualy R22 resistor on the neck card's and HVPS ( high voltage power supply's ). I did have a registration board issue too.
First however you'll have to get it up and running. Good luck.
| Posted: Sun May 04, 2008 6:05 pm Post subject: |
| Curt Palme wrote: | | BTW, can you link to that auction so we know what you have? I can't find it in the completed listings on eBay. |
You were looking in the personals
Ashfallen
| Posted: Mon May 05, 2008 12:09 am Post subject: |
TomW,
thanks for the links.
jantje112,
I haven't got anywhere near lens or focus issues yet.
macgyver655, steufel,
both remote and CPU board are set to 9600 baud.
Curt,
I'll try the other boards, although all are of the same age, so unless by chance one battery had decayed early and been replaced while the projector was still in use, I don't like my chances. I'll check the local electronics stores for a lithium battery with the same V and mAH. Should 909-Code get the projector to power up without the CPU battery? (I'll try it anyway.)
I'm thinking I should sort and label everything, and index it all. This will make keeping track of what has been tried with what easier, as well as selling it off if it comes to that, if I can't get it working. The auction listing was very much a "job lot".
Here's the auction number: 270232423930
| Posted: Mon May 05, 2008 1:06 am Post subject: |
| Ashfallen wrote: | TomW,
jantje112,
Curt,
Here's the auction number: 270232423930 |
If you have the manual you must also make sure the address is correct along with the baud rate. If you have extra remotes, try them as well. With the projector plugged in, the remote connected and the rocker switch set to on, the remote should say "AmPro 4000G" on the LCD of the remote. As Curt said, the battery on the CPU is probably flat. They are easily checked with a digital multimeter.
| Posted: Mon May 05, 2008 1:45 am Post subject: |
The baud rate is only 1 part in the communication chain of remote to cpu. If they were used in a network system many other things have to be looked at. Rotary switches 1 and 2 must be at 0, Dip switch 4, switch 2 must be on and you must check the position of jumpers LK1 and LK2 on the cpu board. This is all explained in the manual. If you dont check all these items, including opening up the remote to check those switches, you will never get it to communicate, no matter how many batteries you throw at it. You must read chap 10 very carefully and apply what you need.
| Posted: Mon May 05, 2008 2:58 am Post subject: |
I was just looking over your first post here where you indicate which leds are lit on the cpu board. Either you numbered them wrong or there is another problem. Leds are 1-10 from left to right looking straight at the card. Normally, 8 and 9 should be on steady and 4 should be flashing. Recheck the leds lit according to number sequence and post back.
| Posted: Mon May 05, 2008 11:11 am Post subject: |
| macgyver655 wrote: | | I was just looking over your first post here where you indicate which leds are lit on the cpu board. Either you numbered them wrong or there is another problem. Leds are 1-10 from left to right looking straight at the card. Normally, 8 and 9 should be on steady and 4 should be flashing. Recheck the leds lit according to number sequence and post back. |
macgyve, check the first post again. He's below the equator and looks at everything backwards
He's listing them, looking from the back side of the board. All led's are correct but #3 which is on but should not be. Find out what #3 led means. I don't have a 2000/4000 manual anymore and can't help here.
| Posted: Mon May 05, 2008 1:05 pm Post subject: |
OK wait guys. Before you send him chasing all over the set, there's a good chance that the last owner didn't get into messing with any of the settings you're talking about. I do that sometimes too, thinking maybe someone got into a set and messed with something obscure, but that's never happened. Only one out of about 200 people are knob happy... OK, that sounded wrong.. 1 out of 200 people will get into a set and mess with stuff that they are not supposed to, so a dead display set has some fault caused over time, which is why I recommended checking those batteries. Also, I have had one set develop corrosion in the rotary address switches, so wiggle those around and make sure all 3 are set to 0.
If the set got set to executive mode, the only functions that will work are power and switching the source, and a couple of others. All other buttons are locked out so that the highly paid military executives don't push the RED button.. But the sets will still power up.
Has anyone thought that these might be the only Ampros down under that were ever used in a military installation? How did Ampro infiltrate Australia anyways?
| Posted: Mon May 05, 2008 1:42 pm Post subject: |
1 in 200???............ Now it's confirmed, Curt's officially lost it What planet/forum are you on? How many people have been told "DO NOT TOUCH ANY POTS OR G2 ON A NEC PG" but went ahead and did it anyway. On this forum, I place that figure more like 1 in 10. They just won't admit to it
As far as this thread goes, he has been told about 3-4 times to check the CPU battery. I'm not exactly sure but 909[code] will only work after it powers up.
All as I have suggested is to check the baud and address settings to confirm that they are correct. All as that is, is a physical inspection, no tools required. If he hasn't checked the battery yet it ain't my bad
| Posted: Mon May 05, 2008 2:08 pm Post subject: |
Right. I meant to say, only one in 200 screw up after my verbal flogging..
| Posted: Mon May 05, 2008 2:33 pm Post subject: |
| stefuel wrote: | | macgyver655 wrote: | | I was just looking over your first post here where you indicate which leds are lit on the cpu board. Either you numbered them wrong or there is another problem. Leds are 1-10 from left to right looking straight at the card. Normally, 8 and 9 should be on steady and 4 should be flashing. Recheck the leds lit according to number sequence and post back. |
He's listing them, looking from the back side of the board. All led's are correct but #3 which is on but should not be. Find out what #3 led means. I don't have a 2000/4000 manual anymore and can't help here. |
I thought that also but wanted to make sure he was correct. If he wasn't backwards reading it then he has no +5v. #3, 8 if listed backwards is I2C fault.
Curt, there are only 4 things that will cause no display on an Ampro. Bad remote, bad component on cpu board, maybe battery and incorrect address. Now he states he tried different remotes and cpu boards so we can almost rule them out. As Chip said its been stated to check the battery, so again that needs to be addressed, But if he tried 5 cpu's like he says he has, thats alot of dead batteries. Checking the address is not all over the set. Its right where he is already in a little 2 inch square, that should be checked first in a no display situation and costs nothing. I'd rather him check that first then sticking a soldering iron in there.
If these sets were networked together then the only one with the required address at zero for single display would be the master, and he may not even have that one.
But I will agree that it's a good chance it is the batteries.
Ashfallen
| Posted: Mon May 05, 2008 4:20 pm Post subject: |
Thanks again.
I've only tried three of the CPU boards, I think I have at least seven in total. Didn't get a chance to look at it today, but I think when I do, I'd be best off labelling and listing all of the components I have, to make the whole process easier. The dip switches on the one remote I have so far unscrewed (the one I used for testing) are all set to "off off off off" and the hexadecimal rotary things are all set to 0, 0, 0 on the three boards I looked at. I think this indicates that the projectors were not networked using their own internal networking function. (Or else this was done after they were taken down.)
The guy I bought it from told me that the projectors had originally belonged to the RAAF (Royal Australian Air Force) for use in a flight simulator, and had been sold on to a theme park (Movieworld, according to a label on one of the boxes). He didn't actually say so, and I didn't think to ask, but I think he himself works or worked at the theme park.
I'll borrow a multimeter and check the batteries tomorrow.
FWIW, I've carefully avoided touching any potentiometers. Which isn't to say anyone else did.
