Lumagen Vision DVI, can handle an 1080p/24 input, read ;)
armstrr
Posted: Sun May 18, 2008 1:29 pm    Post subject:
so the DVI will accept 1080p24, but it won't output 1080p60 or 72 or 75 etc, correct?
Electeohome marquee 9500lc, lumagen hdp, 9' da lite high power screen denon 2809ci paradigm speakers home made dual stacked subs
Person99
Posted: Mon May 19, 2008 12:25 pm    Post subject:
Correct. It will output 720p/72 (actually a little higher resolution than that also) and 1080i/72, but not 1080p/<anything>.
The HDP will do 96 Hz refresh rates within its bandwidth capabilities (such as 1080i/96).
Posted: Mon May 19, 2008 12:29 pm    Post subject:
Right I have a newer HDQ and run 800p@72 for scope movies but I think the older DVI will do the same.
Posted: Mon May 19, 2008 12:30 pm    Post subject:
Dave Are you sure you cant output 1080p@48 like I do with the HDQ? The DVI should do that?
Person99
Posted: Mon May 19, 2008 12:35 pm    Post subject:
It depends upon the horizontal resolution. 1920x800/72 is getting REALLY close to the limit of the DVI, it might be over it, I'm not sure, I'll have to check.
As an aside, I'm just curious, obviously 1920x800 is the active image area for 2.40:1 releases, however, many scope movies on disc have ARs less than that, down to and below 2.35:1. Do you run 1920x817/72 for 2.35:1 movies or just scale those down to 1880x800 and side mask or scale to 1920x800 and side mask? Do you use the Lumagen or the projector to mask off the side areas (just curious as I like to know what people are there are doing Smile).
Person99
Posted: Mon May 19, 2008 12:37 pm    Post subject:
On the DVI's menu, it has the same behavior as the HDQ and HDP in that if you enter the output resolution as 1080, it asks you interlaced or progressive. If you select progressive, it comes back with something like "invalid value". I think I've tried doing it with lower refresh rates, but couldn't get it to do it. I think the software basically has code to stop the DVI from doing 1080p output.
energeezer
Posted: Tue Jun 17, 2008 9:50 pm    Post subject:
Has anyone else been able to get the DVI to accept 1080p/24 input?
If so, were you able to scale to 1920 X 800/60 or 1920 X800/48 from that 1080p/24 input?
Steve
Posted: Tue Jun 17, 2008 11:00 pm    Post subject:
I do 1920x800p with no side masking. just straight 1920x800p@72 on my HDQ. pans a silky smooth. but doing 2.35 is a lot more dim than 16x9 screen material, this is why i cant wait to blend, full phosphor usage. I cant wait mid June is here and the TV-ones should be in soon!!!!!
energeezer
Posted: Tue Jun 24, 2008 7:11 pm    Post subject:
Smile).
Did you try 1920X800/72? Did it work?
Posted: Tue Jun 24, 2008 7:56 pm    Post subject:
Smile).
Is this for Dave or me?
energeezer
Posted: Tue Jun 24, 2008 11:38 pm    Post subject:
That was for Dave since I understand you have an HDQ.
