More and more home theater devices are offering user adjustable gamma correction circuitry built in.
Gamma correction is an essential component to reproducing the best possible image possible. Without gamma correction, dark details (ie: shadow detail) in your projected image will lack detail or simply be missing. An adjustable gamma boost is used to restore shadow detail. If you've always found movies too dark or missing detail in dark scenes, you need a gamma boost!
So what does gamma boost actually look like?
This is best shown with real life examples in action:
So what exactly is gamma correction? What does it do? Why would I need it?
Gamma correction is a manipulation to the contrast of the display signal to correct for the fact that the intensity displayed on displays (of any technology) is not linearly related to the input voltage. In other words: Without gamma correction, dark areas in picture will simply look too dark or black. A gamma boost corrects for this by increasing the contrast in the darker areas without affecting the overall black level of the picture.
Can't I just increase the brightness setting on my projector or TV?
No. Your brightness setting should be set such that a true black signal looks black. If you increase your projector's brightness setting you will see more dark area detail but blacks will also look grey. Gamma correction works as it doesn't affect the low end 'true black' signal.
Before and after example of adding a non-linear gamma boost to the signal
In the real world however, it is very difficult to get a perfect flat linear response. Most responses usually end up something like we see below:
This is still considerably better than an uncompensated curve.
DISCLAIMER (Legal mumbo-jumbo because we have to): Any dealings with the third party seller/manufacturer listed here,
including the delivery of and the payment for goods and services, and any other
terms, conditions, warranties or representations associated with such dealings
or promotions, are solely between you and the third party seller/manufacturer.
Curtpalme.com shall not be responsible or liable for any part of any such dealings or promotions.
CURTPALME.COM IS NOT THE SELLER OR MANUFACTURER OF THESE PRODUCTS OR SERVICES.
THE SELLER/MANUFACTURER MAY HAVE PROVIDED A WARRANTY ON THE GOOD(S) PURCHASED.
CURTPALME.COM HAS NOT MADE, AND DOES NOT MAKE, ANY REPRESENTATION, WARRANTY,
PROMISE OR COVENANT, EXPRESS OF IMPLIED, AS TO THE CONDITION, QUALITY,
DURABILITY, CAPABILITY, FUNCTION, PERFORMANCE, OR SUITABILITY OF THE EQUIPMENT,
ITS MERCHANTABILITY OR ITS FITNESS FOR ANY PARTICULAR PURPOSE. BUYER AGREES THAT
CURTPALME.COM SHALL NOT BE LIABLE FOR EITHER SPECIFIC PERFORMANCE OR ANY
LIABILITY, LOSS, TAMPERING, ABUSE, DAMAGE, INCLUDING CONSEQUENTIAL AND
INCIDENTAL DAMAGES, ARISING OUT OF BUYER'S PURCHASE OF THE EQUIPMENT, ANY
DEFECTS IN THE EQUIPMENT, OR FAILURE OF SELLER/MANUFACTURER TO TIMELY DELIVER
THE EQUIPMENT.
