dark picture on startup barco1209s
SPL800
PostLink    Posted: Mon Oct 28, 2019 10:19 am    Post subject: dark picture on startup barco1209s Reply with quote
i have a new issue with my barco1209s.
at start up the picture is dark. only after a few minutes it comes more brightness picture and perfect like i used to have.
why is that?
HaydnG90
PostLink    Posted: Mon Oct 28, 2019 1:49 pm    Post subject: Re: dark picture on startup barco1209s Reply with quote
why is that?
Total guess, but probably and aging electrical component like a capacitor taking time to reach fully functional spec.
PostLink    Posted: Mon Oct 28, 2019 1:58 pm    Post subject: Reply with quote
BAd G2 board, bad video board are possibilities. I've got spares for cheap if you need them.
SPL800
PostLink    Posted: Mon Oct 28, 2019 5:18 pm    Post subject: . Reply with quote
Hi curt
I have all the spare parts that you sold me.
Including G2 and video board
Do you recommend to already change them? Or maybe the problem will go away in time. (Didnít use the Barco for a long time)
Shay from Israel
PostLink    Posted: Tue Oct 29, 2019 2:54 am    Post subject: Reply with quote
Run it for a while, then start changing boards if it doesn't go away.
SPL800
PostLink    Posted: Sun Jan 19, 2020 11:00 am    Post subject: Reply with quote
the problem doesn't go away.
with which board is recommended to start G2/video?
PostLink    Posted: Sun Jan 19, 2020 3:37 pm    Post subject: Reply with quote
Either one. With a fault like that, the problem could be on any one of multiple boards.
SPL800
PostLink    Posted: Tue Jan 21, 2020 1:52 pm    Post subject: . Reply with quote
is it simple to replace the G2 board?
be happy if anyone could send link For instruction or tips on how to...
PostLink    Posted: Tue Jan 21, 2020 2:49 pm    Post subject: Reply with quote
All barco boards simply pull out. Check the FAQ/Tech tips section on the main site for more info.
SPL800
PostLink    Posted: Thu Feb 06, 2020 10:47 am    Post subject: . Reply with quote
problem solved.
the RGB board was replaced and the punchy picture that i used to have as returned.
As i used to say "LONG LIVE CRT"...
Laughing Laughing Laughing
Hulio
PostLink    Posted: Thu Feb 06, 2020 2:13 pm    Post subject: Reply with quote
Nice, enjoy 😉
HaydnG90
PostLink    Posted: Thu Feb 06, 2020 5:17 pm    Post subject: Reply with quote
Thats what I love about CRT. The design is modular and most boards are easily accessible for swapping out even in situ when ceiling mounted.
SPL800
PostLink    Posted: Thu Feb 06, 2020 9:37 pm    Post subject: Reply with quote
And above all I had to replace the HV splitter also. It generated an electric leak off 35KV like a lightning inside the projector. Didnít believe this animal would survive that. And it did!
