linux2
Link Posted: Sat Apr 16, 2011 3:50 am Post subject: WTB NEC 9PG+ Tubes & Lenses / Parts |
Does anyone happen to have any NEC 9PG+ tubes and lenses? My tubes have about 6K hours on them (lenses + chassis the same) and it's really starting to show. The tubes are getting some burn in and the focus and color around the edges is getting all messed up. I really like my NEC and I would like to get some newer tubes and lenses. Possibly if anyone has a parts NEC 9PG+ that would be cool as well. I could swap over some parts and have one good working unit (as I think the neck board for the blue is having issues, but I can't be sure).
Let me know if anyone has anything. I'm near boston and will drive quite a ways if someone has something for the right price
Thanks!
Link Posted: Sat Apr 16, 2011 4:19 am Post subject: |
Hello
Put WTB in front of your title, it will make your post more effective, otherwise it looks like you are selling.
linux2
Link Posted: Sat Apr 16, 2011 4:26 am Post subject: |
Ahh of course. Thanks for that Tim. It's too late for me here. I should be sleeping instead of fiddling with my CRT projector
Link Posted: Sun Apr 17, 2011 6:56 am Post subject: |
Why do you want to buy lenses, they are not getting old
Link Posted: Sun Apr 17, 2011 2:14 pm Post subject: |
I have at least one perfect set of tubes (the red is brand new in the box) for $300 for the set plus probably $50 in shipping in original NEC boxes.
linux2
Link Posted: Tue Apr 19, 2011 12:31 am Post subject: |
Hi Curt,
That is very tempting, but I just managed to pick up an Electrohome Marquee 8000 with only 450 hours on the whole unit for only $100. I am still tempted to grab those tubes, but I have to figure out what is wrong with my NEC. My NEC compared to my electrohome really has a terrible picture. The Electrohome is about 5 times brighter it seems and is nice and sharp in the corners. I think there must be something else wrong with my NEC that I don't know about. I did mention in another forum post that it seems to click every once and a while. I know once the whole image flickered and I saw a spark on the back of the blue tube. Clearly not a good sign. I also noticed then when I put the contrast or brightness above 50 nothing really changes. Perhaps the problem lies in my power supply? Maybe you con provide some insight. I did the full hardware convergence on your site at least 4 times now just to be sure I got everything right and I'm sure I did. Also the astigmatism I could never get quite right. It was either the corners were correct or the center was. I'm lost. Any input is appreciated. Maybe you have a power supply as well or other parts that might correct the problem?
Thanks again!
P.S. I still need an ECP 4100 LVPS if you have one. It's a 1994 ECP 4100. 5+v light on the back of the unit is out so I would think that should fix it.
Link Posted: Tue Apr 19, 2011 5:36 am Post subject: |
Linux2, It is very interesting what you wrote, because I have a PG xtra and I had a marquee7500, and I personally did not find the 7500 way much better... (in the NEC there is 3600hrs in the marquee was ~5700) Above 720p the marquee was slightly shaprer, but under 720p it was unnoticable for me (with stock HD-8s). the marquee has better contrast. The most interesting is that I found my PG xtra brighter than that marquee. If you turn up the contrast on a marquee the spot size is getting bigger and bigger, and you cannot refocus well is the picture is very bright, but on a NEC if you turn up everything it is just as sharp as at low brightness.
Link Posted: Tue Apr 19, 2011 6:16 am Post subject: |
gjaky wrote: | Linux2, It is very interesting what you wrote, because I have a PG xtra and I had a marquee7500, and I personally did not find the 7500 way much better... (in the NEC there is 3600hrs in the marquee was ~5700) Above 720p the marquee was slightly shaprer, but under 720p it was unnoticable for me (with stock HD-8s). the marquee has better contrast. The most interesting is that I found my PG xtra brighter than that marquee.
If you turn up the contrast on a marquee the spot size is getting bigger and bigger, and you cannot refocus well is the picture is very bright, but on a NEC if you turn up everything it is just as sharp as at low brightness. |
That's when you need frankenyokes
