CxTurbo
Joined: 13 Oct 2008 Posts: 425 Location: Ontario, Canada
Link Posted: Mon Oct 14, 2013 2:25 pm Post subject: |
Nash,
Any thoughts on adding a radial Wima film cap in parallel to the decoupling caps in the CLM versus replacing the ceramics entirely?
I was also thinking of doing the same in the VIM as there are various decoupling caps shown that could benefit as well as adding some power filtering to the IC's directly.
There are also a number of other IC's that we replaced on other boards on the VIM, albeit in SMD packages. I know the VIM is pickier with IC changes from reading so what say you on the TL0's etc that exist on the VIM?
When you added Clarity Caps to JB's HVPS did he notice any improvement?
I just got a two channel scope as well. Maybe now someday I can start to work on the issues I have with all those VDM's I killed LOL!
Lastly, I am still having an issue similar to what you had where vertical and angled lines become jagged every so often. Getting worse on brighter lines white especially. This is the only thing driving me nuts now. Any thoughts on where this is originating othe the the Stig board on the back sink? I have yet to do my CLM at all. I have started on the VIM but got as far as installing the 3 IC's mentioned.
These mods we have discussed here have brought life back to the old girl and they have improved the resolution of the image greatly. However I think I am going to have to resort to floor mounting my machine as the tented ceiling in my theater will not allow me to mount the projector close enough the get full raster usage.
James
_________________ Paradigm Studio 100's,Studio 20's,CC-690, Paradigm DSP-3400 V1 SUB
Pioneer Elite SC-35 AVR
Pioneer Elite BDP-05FD Bluray
3x Bryston 3B's
URC Complete Control Medius TX-1000 Remote
HTPC (LGA775 Q6600, 8GB DDR2, 7TB Storage) Mediaportal
Lumagen MINI 3D
Moome FULLHD-EXT V2
Audioquest Cable Top to Bottom
9501LC
Link Posted: Mon Oct 14, 2013 2:57 pm Post subject: |
Hi James, I have been actually researching parts, caps in particular for the CLM. Panasonic makes new SMD OsCon hybrid cap i was going to add on top of the ceramics already there or do as I did before and remove them and add the OsCons, these are very low ESR caps and form previous experimentation I love OsCons for filtering. these are B1 and B2 case sizes, there are I think 4 SMD's between some closely placed chips where they wont fit. I am iffy on the Ceramics to be removed, they do filter out high frequency but might have a piezo effect, this is what I learned form some readings on companies application notes.
Justin has not really gotten to do much analysis as he has a few other things he was working on, the dreaded faint line on the vim.
With the squiggly lines pulsing every few seconds it is the timing to the Marquee the H-sync has to be larger than 1us, any lower you get those squigglies.
I am looking at using those SMD Oscons on the Vim as well. now these are the box type SMD not the cans.
CxTurbo
Link Posted: Mon Oct 14, 2013 3:14 pm Post subject: |
Is that timing something I can adjust?
Great news on the other stuff. I will keep my pants on for the time being. Although I might just do the Panasonic's like we discussed earlier.
James
3x Bryston 3B's
Lumagen MINI 3D
Moome FULLHD-EXT V2
9501LC
CxTurbo
Link Posted: Mon Oct 14, 2013 3:36 pm Post subject: |
yes I do. I will have to look into it then.
3x Bryston 3B's
Lumagen MINI 3D
Moome FULLHD-EXT V2
9501LC
CxTurbo
Link Posted: Mon Oct 14, 2013 8:37 pm Post subject: |
Nothing in the manual that indicates how to increase the H frequency.
I assume that I need to do this in the custom timing menu and adjust the H frequency above 1MHz?
3x Bryston 3B's
Lumagen MINI 3D
Moome FULLHD-EXT V2
9501LC
CxTurbo
Link Posted: Mon Oct 14, 2013 9:41 pm Post subject: |
Maybe Craig will have some insight.
Thanks Nash.
3x Bryston 3B's
Lumagen MINI 3D
Moome FULLHD-EXT V2
9501LC
Link Posted: Wed Oct 30, 2013 9:16 pm Post subject: |
Jorge, Back to your VDM POOGEing( Progressive Optimization Of Generic Electronics)
For the 150uh do you think 190-220 would be ok? I have a bunch of those value, they are 220uh but I measured a few and most are about 180-190uh.
Aslo did you change the 1n4003 diodes to the soft recovery ones I listed?
I have to try to repair Justins VDM and CVA and want to try your alterations as well.
I ordered the Flyback from the source James listed so have to wait for them. James how long did it take from china?
I also am thinking about those film SMD caps for all the CLM caps for each chip and the VIM as well,
On the CLM I would do a stack of 150nf( they do not have 100nf) 1uf in film and then add the
47uf PosCons.When I did the CLM mod with the 47uf tants there was no issue at all.
And for the Vim the same value with the Film SMD's but add a 4.7uf PosCon SMD's,
and also replace every other tantalum on the CLM and VIM with the same size case but higher
uf value , how much would depend on the location for what ic they are for. I'd go as large as possible
on the input voltage rails but then just a next value up everywhere else. the specs on the PosCons are
great for ESR and Ripple current for a SMD cap. I feel SMD's are the way to go as they keep the intention
of the original PCB layout in mind. Using radial caps adds parasitic capacitance that can affect the circuit
detrimentally but it is not always the case.
PosCon values and the different series they come in.
http://www.mouser.com/catalogviewer/default.aspx?page=3068&highlight=667-6TPU47MSI&catalogculture=en-US&catalog=646
Wish they went higher in voltage and values. I have used Tants of 6.3 volts on the 5 volt rails with no issues, so I wonder how these would fare?
on the 15 volt rails i would not try 16 volt one but the 20vdc ones .
Not sure what surge voltages those rails can produce but 6.3 volts can take a surge up to 7.2 vdc.
barclay66
Link Posted: Wed Oct 30, 2013 10:21 pm Post subject: |
I understand about the 15 volt rails and the 1mH, but for the 5 volt rails you list 150uH so would the 220uH ones I have that measure about 180-190uH work for those rails?
Ok so the film SMD caps would be fine for the 5 volt rails for the chip decoupling caps .
Now what about those PosCon caps they are more like OsCons than tants. And since i put hundreds of hours with the 6.3 volt tants
on another CLM i had with no issues I still wonder if these new style caps would hold up better than tants.
I guess I could try and find out
And are those Shields over those ic's?
nashou
barclay66
Link Posted: Wed Oct 30, 2013 11:02 pm Post subject: |
Nashou66 wrote: | I also noticed you used sockets for the op amps, did that affect the operation at all? |
Nope. Everything works fine. I used high quality sockets.
What You call shields are heat sinks (clips).
The inductors would work fine for the +/-5V rails.
With the PosCons You really will have to try them...
barclay66
Link Posted: Wed Oct 30, 2013 11:14 pm Post subject: |
Link Posted: Thu Oct 31, 2013 12:42 pm Post subject: |
The use of the inductors was very necessary to decrease the high frequency noise from getting into the vert, CVA and Stig amps and vice versa.
There is a ton of noise on the rails, some get's there directly from some of the modules, so in better decoupling the modules, I was able to lower the overall noise on the rails. With the bigger benefit being better performing boards (vert,stig, cva) on the large heatsink, because the high frequency noise that rides on the rails also gets into those amplifiers, and they actually amplify some of it.
I'll take a picture inside of one of my CRT's later (need batteries for my camera) and you'll see why those inductors are needed. Without them, I would not be able to get those super small and tight one pixel lines at the 1920X1440 /60hz resolution (234mhz).
At the higher scan rates, the cleaner the DC is on the amplifiers, the more defined the image will be.
Actually, the noise that is solved from when I put the jumper on the convergence board to ground, is to help suppress the noise that is being transmitted (onto their cables and back onto the rails) by those amplifiers. So with the inductors in place, there's no need for the jumper. Plus with the amplifiers not transmitting that noise anymore, the amplifiers run cooler and there's less noise is in the image.
Yes, the tants are 33uf/16v
CxTurbo
Link Posted: Sat Nov 02, 2013 11:25 pm Post subject: |
My Flybacks only took 2-3 weeks from the day of order to my door. I ordered a bunch of chips from UT Source and one of them held up shipment a bit.
I have not touched much at all on my PJ. So if you are planning on implementing some of these things I will be watching closely.
Jorge Thanks as always for sharing.
You too Mike. Thanks for sharing.
3x Bryston 3B's
Lumagen MINI 3D
Moome FULLHD-EXT V2
9501LC
