| Author |
Joined: 12 Jan 2007 Posts: 12824 Location: West Seneca NY
Link Posted: Wed Jun 27, 2012 6:35 pm Post subject: |
Well at the end of this month all the pics of my work will be gone. Apples Gallery is ending and now I need to host the pics somewhere else. I wanted to some how use my own Computer as a web host for the pics but not sure how to do it. I have the latest mac mini server which has 2 HD's so I planed to use one for that exclusively. But for the next few months bare with me . I will hopefully get everything worked out and have links to the pics.
| Back to top |
Bodi79
Link Posted: Thu Jun 28, 2012 6:03 am Post subject: |
@Athanasios
How much space do you need, cause i can set you up with space on one of my domains.
Cheers
Ronald
| Back to top |
Link Posted: Thu Jun 28, 2012 12:17 pm Post subject: |
| Bodi79 wrote: | @Athanasios
Cheers
Ronald |
Not sure, there are a lot of pics from this thread. Also id like to use it for screen shots I would start taking again at some point for the always fun Screen Shot war thread.
How would it work? Would i have access to upload pics to it? I never set up a web page before so its all new to me.
| Back to top |
| Back to top |
Link Posted: Sun Jul 01, 2012 7:24 pm Post subject: |
so finally got around to doing / testing the larger heatsink on the HMD for those cases where the horizontal deflection starts to Oscillate. I wanted to see how much of an improvement there was i temp. reduction. I never did figure out what went wrong with my Cree FET modified HDM or why it failed during testing, but this was something I always intended to do since this issue popped up on AVS for Ralpharch. Since then it has been posted by at least 3 or 4 other people.
http://www.avsforum.com/t/1266475/marquee-with-intermittent-horizontal-scan-problem
It always seems to crop up in situations where 2 or more of the following situations exist
1) ceiling mounted configuration
2) high scan rates
3) picture set to "short retrace".
4) warm ambient temps (summer-time viewing)
What I did, and what i'm pretty sure VDC did as well, was to modify the focus amp sink and swap it over to the HDM. One of the 5 small fins needed to be milled off to clear some board top components. However the increase in overall surface area is significant and more importantly, the new fins are directly in the air-flow of the belly fan ( like they are on the FCM). I also applied new insulating tape since the tape needs to actually make a 90 degree turn at the top and go horizontally over the perpendicular fin for 3 or 4mm. This is because the tall FET's on the HDM actually touch the top of the factory heatsink and the FCM sink didn't have the tape extend as far.
I used Silicone coated KApton tape with a dielectric rupture strength of 7000 volts+ Dielectric Silicone paste as an added thermal conductor and electrical insulator. Here are the before /after temp's in different room conditions 64Khz horizontal sweep.
1) original 07P HDM factory heat-sink
start (ambient) 79F / Finish 148F = + 69 degree's
2) with new larger heat-sink
test 1
ambient 86F / Finish 134F = + 48 degrees
test 2
ambient 79 / finish 126 = + 47 degree's
So according to my calc's the new heatsink is shedding heat faster and reaching a steady state temp. that is 32% cooler than the original Electrohome factory version. the only issue I see with this modification is
a) you need a milling machine to modify the FCM sink
and
b) you need a bad FCM or maybe an old m8000 FCM donor board ot cannibalize the heat sink from. I'm sure the correct extrusion could be sourced as "new" but there would be a minimum order. Probably a 10 foot section is what most places want to sell + oversize shipping rates. however if your seeing this issue you have an option now
| Description: |
| Filesize: |
69.02 KB |
| Viewed: |
1185 Time(s) |
| Description: |
| Filesize: |
78 KB |
| Viewed: |
1185 Time(s) |
_________________ MARQUEE HD MODS: Bring your Marquee CRT projector (or clone) back up to spec and offer even greater performance!
| Back to top |
Link Posted: Sun Jul 01, 2012 7:52 pm Post subject: |
I'm curious. Are you measuring the temp of the heat sink itself or the components attached to it?
| Back to top |
| Back to top |
Phoenixed
Link Posted: Sun Jul 01, 2012 9:10 pm Post subject: |
Still playing with my hdms?
_________________ Sony G90
| Back to top |
Link Posted: Sun Jul 01, 2012 9:32 pm Post subject: |
| Phoenixed wrote: | Still playing with my hdms?  | no, one of yours I have working in the test chassis and the other was part of my Cree experiment which didn't work out (still broken)
This is from someone who had problems with Oscillation so the true test will be in his machine, ceiling mounted 9500. looks promising though, been running all day and even though the temp. in the garage has soared the probe is still showing only 126 degree's Fahrenheit ( 52 Celsius ).
At any rate, this approach worked for VDC so it wasn't something I "invented" and it certainly can't do any harm to have more metal there.
| Back to top |
Link Posted: Sun Jul 01, 2012 10:36 pm Post subject: |
So probing the heat sink is telling you the transistors are running cooler?
| Back to top |
dvh99
Link Posted: Mon Jul 02, 2012 2:33 am Post subject: |
nahhh, the cree fets are ok, still no problem after 100+ hrs.
it`s the new heatsink that cools better but still my heatsink stays cool to the touch at 1080p 60hz.
| Back to top |
| Back to top |
danielparker
Link Posted: Mon Jul 02, 2012 10:55 am Post subject: |
| draganm wrote: | | This is from someone who had problems with Oscillation so the true test will be in his machine, ceiling mounted 9500. |
That would be mine
My issue can be seen here: http://www.curtpalme.com/forum/viewtopic.php?t=29339
It will be interesting to see if this resolves it.
Daniel
| Back to top |
dvh99
Link Posted: Mon Jul 02, 2012 3:40 pm Post subject: |
still with that heatsink it doesn`t run nearly as cool as with 2 cree fets, with the fets the heatsink gets luke warm at 1080p.
with this heatsink it still gets too hot to the touch at high scanrates and certainly in the summer.
| Back to top |
Link Posted: Tue Jul 03, 2012 4:07 pm Post subject: |
| dvh99 wrote: | still with that heatsink it doesn`t run nearly as cool as with 2 cree fets, with the fets the heatsink gets luke warm at 1080p.
with this heatsink it still gets too hot to the touch at high scanrates and certainly in the summer. | that's true Dennis, it's better to not make the heat in the first place than to try and get rid of it later.
I still want ot try and repair the HDM i have here. What are the chances that one of the 2 cree FET's I installed was bad. I had that weird scan anomaly from the very beginning, and ASA I switched to short retrace the board died.
What's a good way to check the FET under load. Putting a meter across the supply/gate/drain doesn't show anything unusual, but it could be failing under power.
| Back to top |
dvh99
Link Posted: Tue Jul 03, 2012 4:34 pm Post subject: |
i suspect there is no voltage at the gate to begin with.
i have no idea what could have caused this.
you should get around 20v at the gate if i`m not mistaking.
| Back to top |
Link Posted: Tue Jul 03, 2012 6:11 pm Post subject: |
| dvh99 wrote: | i suspect there is no voltage at the gate to begin with.
you should get around 20v at the gate if i`m not mistaking. | in other words, leave the card cage off, install the board naked in the machine, and probe down to the gate and check for at least 20 volts with machine running? sounds a little scary but at least the high voltage will be off.
| Back to top |
Link Posted: Tue Jul 03, 2012 6:18 pm Post subject: |
Probing these components hot is never a good idea. You are better off soldering small wires to the legs and attach the ends to a piece of cardboard and measure with your DMM there.
Of course to check the 2 mosfet it would be easier to just remove them and test out of circuit with your DMM.
| Back to top |
dvh99
Link Posted: Wed Jul 18, 2012 7:05 pm Post subject: |
just finished my 2nd cree fet mod on a friends hdm (older style heatsink) and no problems at all.
again i used the uc3709n as mosfet drivers and did the job in just over 2 hrs.
| Back to top |
dvh99
Link Posted: Thu Aug 02, 2012 2:45 pm Post subject: |
ok, the hdm mod is not completed yet, at least not to full satisfaction.
after the mod on my own and my friends hdm the left part of the screen (till almost halfway) is darker then the right part.
i have no idea what causes this but it looks like the left part is slewed slower then the right part thus being darker (if that makes any sense)
here is a pic, notice that the darker part covers the entire left square so to say of the picture so the black line that indicates the dark to light transition goes to the top.
any suggestions are welcome.
| Back to top |
