Goto page Previous  1, 2, 3 ... 47, 48, 49 ... 57, 58, 59  Next
PostLink    Posted: Tue Jan 24, 2012 10:15 pm    Post subject: Reply with quote
dvh99 wrote:
you did replace both u1 and u12 and lifted the wire from the yoke connector out of the pcb where the 24v goes to?
yes of course, the board ran for a few hours with no problems other than the "tails" on the test pattern ( and that was only on short retrace).
that's the frustrating part, god dam thing worked at first and then failed on me later.
dvh99 wrote:
only other thing that is different is that i have the uc3709 drivers.
well the clare part shows an operating voltage of 4.5 to 35VDC, It seems unlikely that 24VDC would have slowly killed it.
http://search.digikey.com/scripts/DkSearch/dksus.dll?WT.z_header=search_go&lang=en&site=us&keywords=CLA360-ND&x=17&y=12
I'll check again tonight, but I am fairly certain I pulled +24VDC direct from pin 17 on the mobo connector. I'll post a pic later.
My original parts list not including the SBYV-27 rectifiers
Quantity Part Number Description Customer Reference Backorder Quantity Unit Price Extended Price
2 CMF10120D-ND SIC MOSFET N-CH 1200V 24A TO247 0 46.88000 $93.76
10 PPC6.8BCT-ND RES 6.8 OHM .50W 5% MF FUSIBLE 0 0.28200 $2.82
2 CLA360-ND IC GATE DVR 4A INV 8-DIP 0 2.03000 $4.06
10 PPC10.0KXCT-ND RES 10.0K OHM METAL FILM .50W 1% 0 0.15800 $1.58
PostLink    Posted: Wed Jan 25, 2012 4:02 am    Post subject: Reply with quote
ok, spent some time talking to my friend at work about this, admittedly he has not studied the circuit but there are some issues he brought up I thought worthwhile discussing. I mentioned to him that I thought maybe one of my drivers had failed and the fact that Dennis's were still working, only difference is Dennis used a 40V rated driver vs. 35. He said that even though you might be giving a 35V driver only 24 volts there is a possibility of a backwave or reflection from the MOSFET that is much higher. These transients shows up as spikes and are hard to see even on a scope.
So I said wouldn't there have to be a Diode in the cicruit somewhere to protect the driver? Then it occurred ot me that there was, the GTO was acting as a clamp for both the Drive and the gate voltage right? Scott pointed out back in July
You need to short the gto and add a diode to clamp the drive so it swings from about -0.7V up to +19V or so. You need to do this with all three of mosfet drive circuits. The sbyv27 parts should work fine.
However even though the drive had been clamped the gate is not. Could we be getting voltage spikes back through the driver across R2/C15 and R3/C9?
The uc3709 drivers claim
"With inverting logic, these units feature complete TTL compatibility at the inputs with an output stage that can swing over 30 V.
The Clare's I used don't give a range, but simply say
• Logic Input Withstands Negative Swing of up to 5V
I realize I might be totally blowing smoke out of my you know what but I'm looking for a reason this board failed. I mean there might be a reason why the UC3709 driver costs over 3 times as much as the Clare right?
The UC3709 family of power drivers is an effective low-cost solution to the problem of providing fast turn-on and off for the capacitive gates of power MOSFETs. Made with a high-speed Schottky process, these devices will provide up to 1.5 A of either source or sink current from a totem--pole output stage configured for minimal cross-conduction current spike.
SOoooo, could the Clare driver be failing and if it is failing is there something we need to add to this circuit?
 Filesize:  77.94 KB
 Viewed:  1684 Time(s)
PostLink    Posted: Wed Jan 25, 2012 4:13 am    Post subject: Reply with quote
second problem, the HDM shorts out Q3 under 30KHz which isn't a problem since we're removing Q3 anyway. however it also shorts out C10 and C11.
So with this modification at low scan rates c10 and C11 are shorted but now we're also missing C4 and C5 in the core. Now we're down to a pair of 1KV rated caps in a 1600 volt peak to peak circuit. Is that even safe?
 Filesize:  56.46 KB
 Viewed:  1682 Time(s)
 Filesize:  97.87 KB
PostLink    Posted: Wed Jan 25, 2012 5:02 am    Post subject: Reply with quote
Drags, when you turn it on is a source connected or is there no source? And when it worked before the cap change was a source connected?
I'm wondering if this mod only works for the higher frequencies?
Just talking out my arse too Wink
dvh99
PostLink    Posted: Wed Jan 25, 2012 9:18 am    Post subject: Reply with quote
there is an isolation transformer between the fet and the driver.
the fets work just fine at lower frequencies, though i haven`t tried anything below 1280*720*60hz.
you got the 24v at p17 right at the pins, why not at the daughterboard like i did?
did you get the24v after r154 or before (thus straight from the lvps), the 22ohm fusible (check that resistor first, it might be blown)?
the caps don`t see the full voltage swing but half of it but it`s still close to their max allowed voltage, the 2n2 i put in has a 2kv rating and has the same lead spacing as the holes on the pcb.
it`s a good idea to use 2kv rated i guess.
why did you get 6r8 fusibles btw?
edit: these are much cheaper and 1% and 50ppm.
http://www.farnell.com/datasheets/483924.pdf
http://www2.mouser.com/ProductDetail/Cree-Inc/CMF10120D/?qs=D3QG1iK7FqhcMqyHiZ68bA%3d%3d
prices of the fets have dropped substantially.
22usd a piece.
PostLink    Posted: Wed Jan 25, 2012 6:29 pm    Post subject: Reply with quote
Drags, when you turn it on is a source connected or is there no source? And when it worked before the cap change was a source connected? I'm wondering if this mod only works for the higher frequencies?
Just talking out my arse too Wink Nashou
First time it worked fine both with and without a source signal.
thanks for replying Dennis
well 2 reasons. I didn't want the DB captured on the HDM and therefore not easily removed for cleaning or replacement at a later date. Second reason is the traces on the back of the HDM leading to the DB are very thin. I had some concern about overloading a trace.
straight from the Mobo connector P12 - pin 17. I would have smelled a blown fusible, I have the nose of a bloodhound but I'll check
ok, now you tell us Razz
it's simply what the Digikey search engine produced under metal film precision resistor parameter. Fusible didn't seem like a problem or a bad idea / extra safety precaution?
prices of the fets have dropped substantially. 22usd a piece.
Well some good news at least Thumbs Up
PostLink    Posted: Wed Jan 25, 2012 6:50 pm    Post subject: Reply with quote
Cree was mentioned on CNBC as a great stock to buy, its been up since you started this project Drags! They maybe reading your posts here Wink
Nashou!!!
dvh99
PostLink    Posted: Wed Jan 25, 2012 7:56 pm    Post subject: Reply with quote
my daughterboard isn`t captured either, the 24 volt trace goes to a resistor and that`s where i get the 24v.
i have over 100 hours on the projector since i installed the fets so no worries of overstressing a trace Smile.
PostLink    Posted: Sat Jan 28, 2012 4:00 am    Post subject: Reply with quote
so it looks as I suspected, bad driver. U1 is shorted between pins 4 and 5, measuring basically no resistance
pin 4 - channel B Logic input
pin 5 - Channel B Output - Sources or sinks current to turn-on or turn-off a discrete MOSFET or IGBT
http://www.clare.com/home/pdfs.nsf/www/IXD_604.pdf/$file/IXD_604.pdf
So I'm having a hard time believing that pin 17 as a direct source from LVPS could have caused this. I see there's a small decoupling cap for noise and R154 fusible which is safer for the circuit in case of a serious failure or short but to actually damage the driver by grabbing the supply before that point? Either the driver Dennis used is a lot more robust or I just got a defective one? I'm leaning towards the latter as the weird raster anomaly I had right at the start might have been crosstalk or the internal voltage leakage from the driver right off the bat.
I'm going to order the better UC3709 driver , some 2KV rated Poly's in 2n2 and 3n8, and move the yellow wire to after the R154 fusible resistor. Anything else? Confused
 Filesize:  37.71 KB
 Viewed:  1582 Time(s)
 Filesize:  78.79 KB
PostLink    Posted: Sat Jan 28, 2012 4:19 am    Post subject: Reply with quote
Drags come off the other side of the r22 so you have that extra safety of the fuse.
dvh99
PostLink    Posted: Sat Jan 28, 2012 4:28 am    Post subject: Reply with quote
make sure the lead spacing of the caps is the same as on the hdm pcb and get polypropylene caps.
wima evox rifa epcos vishay, all are fine.
dvh99
PostLink    Posted: Sat Jan 28, 2012 4:30 am    Post subject: Reply with quote
r154 soll das sein.
PostLink    Posted: Sat Jan 28, 2012 6:16 am    Post subject: Reply with quote
r154 soll das sein.
Yeah I meant the 22ohm resistor 154 Wink
lol
Nashou!!!
PostLink    Posted: Sat Jan 28, 2012 7:40 pm    Post subject: Reply with quote
just want to be sure this is the right driver
http://www.mouser.com/Search/ProductDetail.aspx?R=UC3709Nvirtualkey59500000virtualkey595-UC3709N
dvh99
PostLink    Posted: Sat Jan 28, 2012 8:16 pm    Post subject: Reply with quote
da.
PostLink    Posted: Mon Jan 30, 2012 6:04 pm    Post subject: Reply with quote
I've ordered the new parts but I'm still bothered by why the driver or drivers failed?In looking closer at the application sheets The Clare part can handle up to 4amps of peak current while the Texas Instruments 3709n is 1.5A max, about a third. So if there was any kickback from the Cree FET the Clare part should have been better suited.
I'm thinking it has to be a supply side issue, but there again both parts can handle voltage swings of 4.5 to 40 volts. The DC supply from the LVPS is regulated so that's practically impossible.
Last possible issue some kind of AC component to the power, I pulled 24VDC basically right off the Mobo where as Dennis grabbed it after the first de-coupling cap and 22ohm fusible resistor. Also, the first 2 de-coupling caps at U1 on the older board has a small MLCC of 500pf and 10uf /50V aluminum can vs. 2.2Uf Mylar + 47uf Alum. can on the newer boards.
Is it possible an AC component on the 24vdc line damaged the Clare drivers?
dvh99
PostLink    Posted: Wed Feb 29, 2012 7:58 am    Post subject: Reply with quote
did you try the new drivers dragan?
http://www.infineon.com/dgdl/IPD65R660CFD2.5_.pdf?folderId=db3a3043163797a6011637d4e912003c&fileId=db3a30432e0bea21012e14dccc656df9
to take this all a little further i`m going to replace the mtp5n40 switching mosfet too.
this new device has lower input and output capacitance as well as a lower rds on, and should be a direct replacement
i`m hoping this will get the h-linearity better at the higher sweeping frequencies.
PostLink    Posted: Wed Feb 29, 2012 8:28 pm    Post subject: Reply with quote
yup, 2 weeks ago. No joy, module is still broken.
I should have known it wasn't the driver, the Clare had 3X the amperage rating of the Texas Inst. chip. So whatever failed at this point is likely to be one somewhere else on the board. It won't be easy to find as it's not a direct short that the CLM would see when it first powers up the LVPS . the machine starts, then turns off the HV
I've poked around and have not had any luck but I'm suspecting either the horizontal width regulator circuit, simply because that can be rather flaky , OR something else that shares the +24VDC line which, if it was operating marginally and ready to die, might have been killed by pulses from the new drivers at U1 and U12?
just guessing here, this is a REALLY complex board and well beyond my ability to truly troubleshoot. I could probably do it, but to gamble another complete Saturday and Sunday and then maybe still not have it working would be hard to swallow.
Any advice or help greatly appreciated at this point. Sad
dvh99
PostLink    Posted: Sat Mar 03, 2012 7:40 am    Post subject: Reply with quote
you could start by measuring the voltage at the gate of the fets and work from there.
there should also be some test points on the hdm which could tell you more if you have the docs.
these new fets put less stress on the circuitry.
good luck hunting.
i took my entire projector apart yesterday because of some inexplainable errors i got (top and bottom bow messed up, black horizontal stripes in the picture, this affected the internal menu`s)so i cleaned the top motherboard and its connectors for the hdm and fgm and soldered the connectors for the video module and clm on the backplane and gave it a good cleaning (again by just pouring alcohol in the holes and inserting cards in the connectors).
now all is well again so if you have some errors you can`t explain and which happen randomly take a look at the backplane.
PostLink    Posted: Tue Apr 03, 2012 3:44 am    Post subject: Reply with quote
Hey guys, Panasonic came out with a new ultra low ESR long life cap, the FR series.
http://www.panasonic.com/industrial/includes/pdf/EEU-FR_introductionsheet_2010-10-05.pdf
http://industrial.panasonic.com/www-data/pdf/ABA0000/ABA0000CE132.pdf
I think I'll be using these in some other Projects since I have all the caps for my marquee's in stock(FC FM series)
Page 48 of 59
