joshg21
Link Posted: Thu Jan 10, 2008 2:59 pm Post subject: LG GGC-H20L Drive Problem..FOR THE LOVE OF GOD HELP!!!!!!!!! |
I just bought a LG GGC-H20L blu-ray/HD DVD drive and got it installed. My hardware manager correctly shows the drive and shows that the driver is working good. Also I have updated the firmware for the drive to 1.02. When I put in a HD DVD disc or Blu-ray, the DVD-RAM Icon in "My Documents" changes to CD Player! Same thing for Blu-ray. Also the odd thing is that I also have an external Xbox 360 HD DVD drive and it does the same thing. Now both drives will play standard DVDs and music CDs, but no HD DVD or Blu-ray. I really need some help as I have been dicking around with this for the past 2 days. Whatever you got would be a great help.
Link Posted: Thu Jan 10, 2008 5:19 pm Post subject: |
You just bought this drive after every one else's hardships with it? Boy, you are a glutton for punishment.
joshg21
Link Posted: Thu Jan 10, 2008 6:01 pm Post subject: Yah, Yah. |
I heard about everyone's problem but hey I am one for a challenge. I did just find another thread about the UDF 2.5 Driver is needed. I am going to try that over my lunch break and see what happens. I thought that the 2.5 version was on XP, but I just spoke to our IT tech here at my work and he said that version is only native to Vista. Kind of funny that LG says you do not need any extra UDF driver. Way to be LG!
Running XP Pro Service Pack 2
Compaq Asus A8AE-LE Motherboard (Compaq SR1630NX)
PowerDVD Ultra
Connected to SATA150 port on mobo
MSI NX8600GTS 256MB Video Card
2 IDE Seagate 7200 RPM Drives
Striker 7.1 Audio Card
joshg21
Link Posted: Thu Jan 10, 2008 6:09 pm Post subject: Forgot |
Forgot to mention that I have an AMD Athlon 64 X2 4200 2.19GHz.
joshg21
Link Posted: Thu Jan 10, 2008 6:16 pm Post subject: No Go |
I downloaded the UDF link that you sent and when I rebooted I got a message that said "Drivers cause unstable will not load". Pretty much the same problem that other guy had, but this time I still have the same problem with the drive changing to a CD drive.
joshg21
Link Posted: Thu Jan 10, 2008 6:37 pm Post subject: Some Progress |
Ok so the other UDF Driver didn't seem to work so I found another one (http://www.digital-digest.com/articles/Xbox_360_HD_DVD_Windows_page1.html) and now the drive will see the disk, both hd dvd and blu-ray and I can read the file structure, but it is a no go on playing them. When I click to open then PowerDVD loads up and then starts playing a black screen.
nuttall_chris
Joined: 08 Mar 2006 Posts: 832 Location: Ottawa, Ontario, Canada
Link Posted: Thu Jan 10, 2008 6:55 pm Post subject: Re: Some Progress |
joshg21 wrote: | Ok so the other UDF Driver didn't seem to work so I found another one (http://www.digital-digest.com/articles/Xbox_360_HD_DVD_Windows_page1.html) and now the drive will see the disk, both hd dvd and blu-ray and I can read the file structure, but it is a no go on playing them. When I click to open then PowerDVD loads up and then starts playing a black screen. |
Your black screen may be caused my a number of things. What disk are you trying to play, what version of PowerDVD are you running, are you using Anydvd HD, is your entire video chain HDCP compliant?
FYI, I bought this drive a few months ago and have used it in both XP and Vista, other than a couple PowerDVD issues the drive has worked perfectly
Chris.
joshg21
Link Posted: Thu Jan 10, 2008 7:08 pm Post subject: AnyDVD |
I did happen to have a trail version of AnyDVD HD and I did just load it up. Figuring that if I can read the file structure then maybe I would be able to copy the HD DVD & Blu-ray disks. After I loaded it up AnyDVD located both drives and also located The Simpons blu-ray disc in the LG drive and Transformers hd dvd in my 360 hd dvd drive. I was able to begin ripping the blu-ray disc to my hd but I had to go back to work. I am going to check on it after work. I also did try one other thing. I did also have a trial version of PowerDVD 6 with HDDVD support and that is what I tried to use after installing the UDF driver. I am going to reinstall PowerDVD 7 Ultra tonight and see what happens.
Wanman: I just read your woes with the LG and it seems like the very same thing is happening to me, but I do not have the ability to change any memory settings in my bios. I have a stock compaq mobo. I have thought that might be my problem, but given the fact that it is a 939 mobo, I might be hard pressed to find a good one. If you got any suggestions that would be great.
joshg21
Link Posted: Thu Jan 10, 2008 7:20 pm Post subject: HDCP Chain |
My video card is HDCP compliant and so is the drive, but my monitor is not. Just using the VGA input on the back of my LCD tv. My tv manual states that it cannot accept a pc signal over the HDMI connection.
Link Posted: Thu Jan 10, 2008 7:25 pm Post subject: |
I also had a problem with the SATA implimentation on my motherboard. I ultimately had to use a SATA to USB 2 adaptor to connect the drive. I could see the file structure on the disk's. No problem. I would get to the point where PowerDVD would start then crash, hang, blue screen and sometimes if I started the PC with a disk in the driver it would get stuck in a reboot loop.
So keep that in mind. It may be hardware related too.
Also the newever versions of Power DVD won't play nice with AnyDVD-HD. The version you want is 3319a. It's the lattest one that will play nice with AnyDVD HD.
joshg21
Link Posted: Thu Jan 10, 2008 7:32 pm Post subject: |
Any suggestions for the adpater? I did search minova and found a PowerDVD 7 Ultra 3319a update. Is that what I need?
Link Posted: Thu Jan 10, 2008 7:42 pm Post subject: |
Yes that's the version ,try the software first.
The adaptor I got was a generic IDE133/laptop drive/SATA to USB 2.0.
It looks like this:
joshg21
Link Posted: Thu Jan 10, 2008 7:55 pm Post subject: |
I will give the adapter a try. I am supposed to contact LG tonight. While the adapter comes in I might as well try with LG. I have thought of replacing the mobo with another 939 board and see if that helps. My SATA ports are only 150 and the board was made in 03-04, so it is pretty old. I am interested in seeing if a SATA II would have any better luck? I will give the software another try tonight and report back. Thanks so much for the help.
joshg21
Link Posted: Thu Jan 10, 2008 10:41 pm Post subject: One more quick question |
My current motherboard is a stock Compaq Asus ASAE-LE. It is pretty crap and way restrictive being a compaq and all. So with my xmas money I bought a Foxconn 6150K8MD mobo. I didn't have enough money for a new AM2 or Itel processor and mobo so I stuck with 939 to keep my AMD 64 X2 4200. The Foxconn uses a nVidia Geforce 6150 chipset, a nvidia 6150 Northbridge and a nvidia MCP430 Southbridge. The reason why is I have gotten some other feed back that the chipset on my Asus mobo (ATI Radeon xpress 200 ATI RS482 Northbridge and a SB400 Southbridge. Also the Foxconn has 4 SATA 3.0Gb/s instead of the dead SATA150 that I have on my Asus. I guess my question is do you think that the Asus mobo might be my problem? I already ordered the SATA to USB 2 so if my new mobo does not do the trick at least I will have that.
Link Posted: Thu Jan 10, 2008 10:47 pm Post subject: Re: One more quick question |
joshg21 wrote: | My current motherboard is a stock Compaq Asus ASAE-LE. It is pretty crap and way restrictive being a compaq and all.
I didn't have enough money for a new AM2 or Itel processor and mobo so I stuck with 939 to keep my AMD 64 X2 4200. The Foxconn uses a nVidia Geforce 6150 chipset, a nvidia 6150 Northbridge and a nvidia MCP430 Southbridge. The reason why is I have gotten some other feed back that the chipset on my Asus mobo (ATI Radeon xpress 200 ATI RS482 Northbridge and a SB400 Southbridge. Also the Foxconn has 4 SATA 3.0Gb/s instead of the dead SATA150 that I have on my Asus. I guess my question is do you think that the Asus mobo might be my problem? I already ordered the SATA to USB 2 so if my new mobo does not do the trick at least I will have that. |
Hold on which board are you curently running? The Asus or the Foxcon?
joshg21
Link Posted: Thu Jan 10, 2008 11:14 pm Post subject: |
I am running the stock Compaq board. I just bought the Foxconn and I have not gotten yet. Still running the stock mobo that came with my Compaq SR1630NX PC that I bought several years ago. Now the only stock thing left is the motherboard.
Link Posted: Fri Jan 11, 2008 1:33 am Post subject: |
Ahhh I have some bad new for you....the Foxcon is only one number away from the one I'm running. I have the 6150K8MA-8EKRS and as far as I can tell the only difference between this one and your new 6150K8MD you have one the way is one of the PCI slots has been replaced with a usless (for HTPC ) PCIe 1x slot.
You will definitly need the SATA to USB 2 cable. It's the Nvidia 430 chip set that has givin me nothing but grief. Unfortunatly I can't find another Socket 939 board with 3xPCI and 1 PCIe 16x slot.
Oh and I've had one Foxconn die on me already. Hope you have better luck.
joshg21
Link Posted: Fri Jan 11, 2008 2:00 am Post subject: Well then |
I just cancelled the order for the Foxconn board. Thank god just in time, had not left the warehouse yet and didn't have to pay. Got any recomendations for a good HTPC mobo? Thanks again for all of your help. I know taking your time to answer some guys problems and rants isn't high on your list so I appreciate your help.
