schmoe
Link Posted: Fri Apr 04, 2008 7:20 am Post subject: |
beun wrote: | That does it, left shift here we go. |
I thought we were trying to fix the "blue bands" issue, not left shift. Did I miss something?
beun
TX_VTX
Link Posted: Fri Apr 04, 2008 8:33 pm Post subject: |
Do you want me to send the card and TC1500 box/power chord back?
I cant wait until I see the new version
beun
TX_VTX
Link Posted: Sun Apr 06, 2008 12:50 am Post subject: |
the banding was what I was saying was worse. I dont know what the shift stuff is. I can post pics if you need me to later tonight or tomorrow.
aworldnervelink
Link Posted: Mon Apr 07, 2008 2:15 pm Post subject: |
I just wanted to jump onto this thread... I have a PRO-720HD with HDFury and I'm experiencing the rolling blacks problem. Once a new version of the TC is available that fixes the blue banding issue I will happily purchase one!
beun
Link Posted: Fri Apr 11, 2008 4:42 pm Post subject: |
Let me give everyone an update on the progress as it has been a while ago. I have been focussing on additonal features and fixing all the errors. The final TC1500 will therefore have the following features provided I can all squeeze it into the case.
1) Adjustable gamma correction on the RGB input
2) Format independent shift over a whole line, this will fix the left shift issue
3) Automatic selection of SD/HD color space based upon line frequency
The status is as follows, I have finished the schematic for the adjustable gamma and I have a working simulation for horizontal picture shift. I am working on the final schematic and component selection for this shift function. The automatic color space selection is already implemented.
I also have to fess up to a fatal design flaw in the few prototypes I have sent out. I put a capacitor with too low of a working voltage in the power supply which means that they will all fail after a while in continous use. I will send everyone that already received one a free replacement of the final version.
Kim
schmoe
Link Posted: Fri Apr 11, 2008 4:50 pm Post subject: |
Thanks for the update, Kim, and especially your honesty.
One question: what did you ever decide about using the tri-level sync that you mentioned a while back? Does the TC1500 need it for the Pioneers (and others?) or not?
Thanks.
beun
TX_VTX
Link Posted: Mon Apr 14, 2008 1:24 am Post subject: |
Thanks for the update.. I look forward to it and will post results as soon as I get it. I am waiting on this guy before I think about getting a PS3 and thus Blue ray. If all goes well with my upconverting DVD player I will go rent a PS3 and post my results of that as well.
beun
andygiddings
Link Posted: Thu Apr 17, 2008 1:30 pm Post subject: |
TX_VTX
I have a PS3 as well as HD-DVD and FIOS TV (ok so I'm a geek). So far I've not seen anything with these different setups (Pioneer RPTV, HD Fury with or without TC1500) to indicate that the source is causing any issue. They all work fine on component and exhibit the same issue when using HDMI through the Fury. I've also tried the Vision FC4 and that had the same problem as the HDFury and TC1500 combined, albeit with a slightly softer picture,
Andy
beun
Link Posted: Sun Apr 20, 2008 4:42 am Post subject: |
Let me give you guys another update, I have been working on the board layout for a few days now and I have to say it is squeezing to get it in its form factor. To give me some more routing room I have now converted the board to 4 layers. The few who have already seen it may have noticed it is a double board stack at this moment and I may have to go to a triple stack in the end.
Kim
Joined: 08 Mar 2006 Posts: 26021 Location: Toronto, Ontario, Canada
Link Posted: Sun Apr 20, 2008 6:59 am Post subject: |
Are you having problem's with your connection to the forum? I was on friday night.
Can you give us a feature's update too Kim?
beun
TX_VTX
Link Posted: Mon Apr 21, 2008 3:47 pm Post subject: |
cool thanks for the update
and I just got a PS3 so I will be testing it when the unit arrives.
Not trying to push at all, but any idea how long it will take you?
beun
beun
beun
James_Aguirre
Joined: 20 Apr 2008 Posts: 11 Location: United States
Link Posted: Fri May 02, 2008 3:49 am Post subject: |
Well I am anxious to get mine, so I hope your testing will show they are ready for production.
_________________ James Aguirre
