ygi
Link Posted: Sat Feb 23, 2008 9:59 pm Post subject: |
I am planning to be part of the next IFB-HD for my VPH 1252, but I saw this thread and now, i am wondering if it worths the wait for the FUllHD and its 2 HDMI inputs and its HDMI 1.3 angainst 1.2 for IFB-HD ... what brings 1.3 vs 1.2 today, what would you do ?
regards
oliverg
Joined: 15 May 2007 Posts: 800 Location: Melbourne, Australia
Link Posted: Sat Feb 23, 2008 10:19 pm Post subject: |
Its a 1252, if you want to do "Full HD" you would be better off first upgrading to at -least- a 1292 or a G70
_________________ ( R ) G ( G ) 9 ( B ) 0 ( R ) G ( G ) 9 ( B ) 0
ygi
Link Posted: Sat Feb 23, 2008 10:24 pm Post subject: |
kal wrote: | It'll fit anywhere the IFB-HD fit, that is, any IFB slot. So yes, the switchers will work too. The interface is the same, it's just the internals that are different between the IFB-HD and the new IFB-FULLHD.
Kal |
Ok, I've missunderstood then, I was refering to kal's post telling IFB Slots
ygi
barcoed
Joined: 26 Feb 2008 Posts: 65 Location: Cambridgeshire, UK
Link Posted: Tue Feb 26, 2008 3:40 pm Post subject: |
I missed the first round of deposits - am I too late now? If not how can I secure one of these wee beasties?
barcoed
Link Posted: Wed Feb 27, 2008 9:03 am Post subject: |
Ahh. So presumably there will be an announcement at some future time when it is available? And at that point there will be enough to satisfy all the hungry Sony CRT owners out there?
Bruce 09
Joined: 08 Mar 2006 Posts: 747 Location: Kamloops BC, Canada
Link Posted: Wed Apr 09, 2008 3:02 pm Post subject: |
Quote: | COMING SOON! Sony IFB-FULLHD HDMI 1.3 input card with Gamma and IR remote
Specifications
- Fully HDMI 1.3 compliant! Including Deep Color support! A first!
- Higher bandwidth of HDMI 1.3 allows for 1080p/72Hz support and beyond (Maximum under HDMI 1.1/1.2 is 1080p/60Hz)
- Better D/A converters (12bit DAC) and op-amps than in any of his previous designs for the best image quality possible!
- *TWO* HDMI inputs!
- Toslink output, supporting up to 2 channels of PCM (uncompressed) or 8 channels of compressed audio
- Gamma adjustment/correction
- Remote control |
This was quoted mid November ANY updates on this card ?
BUMP
Joe Buckstrap
Link Posted: Mon Jun 16, 2008 5:57 pm Post subject: IFB-FULLHD Input C overriding Input A |
I installed an IFB-FULLHD on a G-90 and Blu-Ray and HD Cable looks great. However, I do have a peculiar problem. I upconvert component DVD signals through a Faroudja VP400 and bring it into the G-90 via 5-wire RGBHV in Input A and I'm not seeing that at all. Instead, everything seems to be processed by the Input C IFB-FULLHD card. Is there a way to turn off this card or disable it short of having to pull it everytime I want to watch a DVD
hlmiii
Link Posted: Mon Jun 16, 2008 6:51 pm Post subject: |
I don't have any help for you. Sorry.
BUT - you have a Sony FullHD Card? For how long? When did they become available?
Thanks.
Link Posted: Mon Jun 16, 2008 7:13 pm Post subject: |
Joe, you should be able to simply switch G90 inputs with your Sony remote or the built-in control panel. Input A when you want to watch DVD, and input C to watch Blu-ray or cable through the IFB-FULLHD card. This is in contrast to switching between Blu-Ray and HD cable, where you're probably using the Moome remote to switch between HDMI and component... right?
hlmiii, he's obviously talking about the IFB-HD (which is still on sale) and not the new FULLHD card which hasn't shipped yet. The new card is what I'm waiting for.
hlmiii
Link Posted: Mon Jun 16, 2008 7:19 pm Post subject: |
Thank you, SC. Wanted to make sure the FULL version had not been released (and then gone away ).
Whew!
Joe Buckstrap
Link Posted: Tue Jun 17, 2008 2:05 am Post subject: Input A and Input C issues |
No I am not mistaken . I am testing a beta version of the FULLHD that I obtained under considerable difficulty. Moome wants me to change a jumper on it to solve this problem. Presently I cannot process Input A signals whilst this card is installed. It interferes with Input A processing. The projector won't switch to Input A. If I manually try to switch to Input A the projector responds with a "not applicable" warning. Anyway, Moome will release the card when these problems are solved. He wants these cards to work correctly for you.
My cable box has an HDMI output, btw. So I have both the cable box and Blu-ray routed through a Yamaha RX-Z11. This receiver has two HDMI outputs that I run to the IFB card. My DVD is component which I run through the Yamaha to a Faroudja VP-400 and on to the G-90's 5-wire RGBHV.
So now you know why the IFB-FULLHD cards haven't been released yet. It would be irresponsible of Moome to ship cards that have known issues.
You'll be much happier with cards without these problems.
Link Posted: Tue Jun 17, 2008 4:10 am Post subject: |
Joe - the input switching problem aside, it's exciting just to know the card is on the way. Thanks for posting.
Like Kal, I am curious. Why didn't you think it was relevant - even important - to mention that you're using pre-release beta hardware... In a post about how to fix a problem you're having with that particular hardware, no less? To be brutally honest, that's downright strange. No offense intended, of course.
I even find interesting your use of the word "peculiar". If I were testing alpha or even beta hardware and found an issue, I likely wouldn't find much "peculiar" about it. I would probably assume it was a bug and simply report the behavior per the beta testing agreement I had with the developer.
I'm also surprised a beta tester wouldn't be under an NDA.
Link Posted: Tue Jun 17, 2008 4:40 am Post subject: |
ecrabb wrote: | Joe - the input switching problem aside, it's exciting just to know the card is on the way. Thanks for posting.
SC |
This is Moome we are talking about...."Bless his Heart".
Like my southern touch?
Joe Buckstrap
Link Posted: Tue Jun 17, 2008 10:30 am Post subject: About the FULL-HD |
It was lousy communication - mostly on my part - that brought me to speak about the card when I should've just kept the discussion of any bugs in-house with Moome. I wasn't even aware how limited the beta testing was, thinking that there might be other testers in this forum. The card exists and this problem I brought up here - which I shouldn't have - will be resolved. Now maybe I should keep my mouth shut before I ruffle some mote feathers. But anyone out there who thinks that the card is just a fantasy are just wrong.
vorlon
Link Posted: Tue Jul 08, 2008 2:55 pm Post subject: |
Hi
Does anyone know how much this new card will cost and when it might become available.
Cheers
