if you think your htpc plays .ts files smoothly...
benareeno
PostLink    Posted: Wed Aug 22, 2007 4:28 pm    Post subject: if you think your htpc plays .ts files smoothly... Reply with quote
then tell me exactly what your config is...
Oddly enough, overlay works fine for smoothness...but vmr9 is the only way I want to watch video, and more often than not the downloaded movies have issues with it. Micro stutters...the odd audio hiccup (milliseconds) etc. Nothing crazy, but it drives me crazy!!
Perhaps I should go XBOX 360 at this point...but no chance for 48Hz as far as I know.
Maybe I should disable onboard video and try one of the new ATI cards??
Talk to me people...
Ben
PostLink    Posted: Wed Aug 22, 2007 6:23 pm    Post subject: Reply with quote
What onboard video card are you running?
Mark AW will blow the ATi horn at you shortly I'll bet. Acording to him the new ATi cards are great with vmr9. I'm in the market for a new card as my on board GeForce 6150 won't do 1080P off the HD-DVD smoothly. Keep us updated. Thumbs Up
kschmit2
PostLink    Posted: Wed Aug 22, 2007 7:10 pm    Post subject: Reply with quote
My Geforce 6800 played TS files with either h.264 contents or MPEG-2 contents absolutely smoothly.
h.264 contents in PAFF mode was properly slowed down from its original rate of 25.00 fps for movies to 23.976 fps (this is an offline process not involving re-encoding the contents), and then played back at 1920x1080i95.904
MPEG-2 contents is played in realtime with inverse telecine (IVTC) applied to it.
Playback software: Media Player Classic Home Cinema Edition using either VMR9 in Direct3D Fullscreen mode, or EVR in Direct3D fullscreen mode.
Codec for h.264: CoreAVC 1.3
Codec for MPEG-2: Dscaler5 Video Decoder with IVTC mod (to play back 1080i60 files as proper 1080p23.976).
I have since moved to an ATI HD 2600XT card, and everything that worked with the Geforce works just as fine with the ATI card (though given the sheer amount of complaints about the ATI cards, I'm well aware that I have been more than lucky so far).
Everything (incl. Blu-ray and HD DVD) is perfectly smooth. No judder, no stutters. Just like the best external scalers.
Hardware:
ATI A64 X2 4600+ (2.4 GHz) (Socket 939)
2 GB DDR
Mainboard for the Geforce 6800 (AGP) was an ASUS A8V,
Mainboard for the ATI HD 2600XT (PCI-E) is an ASUS A8N32-SLI Deluxe
OS: the Geforce System was run under both XP and Vista Ultimate (32 bit), the ATI system is now Vista only.
PostLink    Posted: Wed Aug 22, 2007 7:44 pm    Post subject: Reply with quote
What onboard video do you have? I have probably a 3-year old IBM machine with a Radeon 9800 AGP, I think in it... It plays the .ts files I pull off my HDTivo in TheaterTek perfectly. I can't tell the difference between the HTPC at 1080i and the HD Tivo at 1080i. There is a signal timing difference, but to me, they look almost identical. Does TT use VMR9?
benareeno
PostLink    Posted: Wed Aug 22, 2007 8:00 pm    Post subject: Reply with quote
TT uses VMR9 because I tell it to...I am not a fan of overlay at all. THe colors look weird.
THe mobo has onboard NVidia 6150GPU, got very good reviews...and for pic quality, I have no issues at all. I think it looks great!
cpu is never used overly high either...I just can't get certain movies/scenes to play smooth....different Nvidia drivers are better, but nothing has cured this thing. And yes, when I switch to overlay it's all fine and dandy.
Ben
Joust
TV/Projector: Marquee 8501LC
PostLink    Posted: Thu Aug 23, 2007 12:09 am    Post subject: Reply with quote
I can sure vouch for that. I have Ben's PC here. watched a movie made of multiple .ts files. sounds and video got out of sync every 5min.
picture stutters a lot.
other than that, which is major and pissed off the wife quite a bit, its perfect.
PostLink    Posted: Thu Aug 23, 2007 1:20 am    Post subject: Reply with quote
Ben
That's the problem I'm having with the 6150. I was watching the departed last week and tried 1080P it stuttured too much so I went back to 720P.
PostLink    Posted: Thu Aug 23, 2007 1:42 am    Post subject: Reply with quote
I haven't used my HTPC in over a year.
Loving the stand alone players much better. Especially via HDMI.
Anywho, a stand alone Toshiba HD DVD player will smoke a 360.
Cliffy
PostLink    Posted: Thu Aug 23, 2007 1:48 am    Post subject: Reply with quote
Oh yeah! Well ok I belive you. Now walk softly and carry 12 big guns. Wink
I use mine for lots of stuff besides just HD-DVD playback and I don't own a scaller so it work out well for me. Plus I have a Logitech G25 steering wheel on order and I wana get a good racing game to go with it.
So it seems a GeForce 8800 will be on order for me soon too. ( Lets see there's a birthday and Christmas is comming...)
PostLink    Posted: Thu Aug 23, 2007 2:00 am    Post subject: Reply with quote
Oh hell ya, it's a good gaming system and great for .ts playback, but as an HD DVD player, it is SOFT compared to HDMI from the Toshiba's. Even the HDMI versions of the 360 exhibit the same flaw. They are soft.
On top of that, the 1080P timings are broken so you cannot properly display 1080P with any CRT natively from a 360.
I actually prefer the output of the PS3 to be extremely superior to the 360. It's sharper, I've never had a problem with it, and it's ranks in the top of BD players.
Cant wait until the game selection gets good. Thumbs Up
Cliffy
Clarence
PostLink    Posted: Thu Aug 23, 2007 2:34 am    Post subject: Reply with quote
I concur. BD on PS3 is much better than HDDVD from the XBox360. I was hoping the softness was due to component, so I upgraded to the Elite for HDMI. A little better, but still nowhere close to PS3.
Cliff, do you think the XBox HDDVD drive was sharp on your PC?
Mark_A_W
PostLink    Posted: Thu Aug 23, 2007 3:17 am    Post subject: Reply with quote
Reclock.
And yes, my 2600XT works fine. VMR9 is perfect.
benareeno
PostLink    Posted: Thu Aug 23, 2007 5:09 am    Post subject: Reply with quote
I think I will buy a 2600XT or perhaps a 8600GT and see if that helps me out....
I had tried reclock on this pc...but maybe I'm not using it now. I'll have to look closer.
I have a Toshiba HD-DVD drive...but it doesn't allow me to play .ts files from harddrives Smile
I really love the idea of HTPC...gamma correction, 48 Hz, streaming movies....but man, it just kicks me in the balls more often than not.
Is there a step by step, click by click, checkbox by checkbox setup for Zoomplayer with reclock and Dscaler?? I think this should be my setup at this point, but I just can't get it all to work. Seems I have to get this that and the other thing, and the other thing usually stumps me and I go back to TheaterTek.
Ben
benareeno
PostLink    Posted: Thu Aug 23, 2007 5:10 am    Post subject: Reply with quote
And Mark, I absolutely apologize for those items never being shipped.
I have no legs to stand on...I just couldn't get it done or something...perhaps I have a disease, I'm not sure.
Ben
benareeno
PostLink    Posted: Thu Aug 23, 2007 5:17 am    Post subject: Reply with quote
And yes...while it can be bad, and sometimes a non-issue....Barry was watching Uncle Buck, which is by far the worst offender I have downloaded in terms of stuttering.
PostLink    Posted: Thu Aug 23, 2007 11:55 pm    Post subject: Reply with quote
Cliffy
Ahhh yes I think we got confueseded, I'm just running the XBOX HD-DVD drive on my HTPC. I use my HTPC to game.
I never could stand playing games with controllers. It's mouse/keyboard for me and the ocasional steering wheel.
PostLink    Posted: Fri Aug 24, 2007 12:35 am    Post subject: Reply with quote
Oh yeah. It's fine on the PC for the most part other than the occasional stutter. I just hate having to navigate the menu's on HD with the mouse. It sucks.
Cliffy
PostLink    Posted: Fri Aug 24, 2007 12:36 am    Post subject: Reply with quote
Cliffy
Oh, hell yeah. I'll take a mouse and keyboard over a game pad for first person anyday........ Very Happy
PostLink    Posted: Sun Sep 09, 2007 12:09 am    Post subject: Reply with quote
"Steering wheel". Pshaw.
PostLink    Posted: Sun Sep 09, 2007 4:48 pm    Post subject: Reply with quote
You know I could probably build that with spare parts I have laying around. I'd have to make the screen projection with my 1252 though.
I don't think my neighbours would apreciate the noise from the hydraulics.
