yonexsp
Link Posted: Mon Nov 26, 2007 9:32 pm Post subject: |
Any idea on the price yet?
dropzone7
Joined: 12 Jun 2007 Posts: 1069 Location: Charlotte, NC
Link Posted: Mon Nov 26, 2007 9:34 pm Post subject: |
yonexsp wrote: | Any idea on the price yet? |
I think I saw mention of $400 on the second post but not sure where that number came from.
yonexsp
Link Posted: Mon Nov 26, 2007 10:01 pm Post subject: |
I hope it is not $400, makes going digital a more likely scenario at that price point.
KennyG
Link Posted: Fri Nov 30, 2007 4:07 am Post subject: |
I am planning to buy the non-remote controlled gamma card...so I am wondering how the dual HDMI inputs will work without remote control. OR will there no longer be a non-remote controlled unit?
greg_mitch
Link Posted: Fri Nov 30, 2007 4:17 am Post subject: |
I will go out on a limb and assume it is impossible to control this with the NEC factory remote since it will be two inputs in one of the NEC input slots?
I am going to have to run two repeaters to my projector now?
dbaisey
Joined: 09 Mar 2006 Posts: 821 Location: Southern Cal LA / Seattle WA
Link Posted: Fri Nov 30, 2007 4:45 am Post subject: |
You can select the slot on the projector but you will need to think 'external switcher' when feeding more then one source to that slot.
Its the same as if you had a RGB switcher. The projector can look at the freq being sent and find it via multi-sync. How you select the source to feed the slot is up to you. If a switch will auto switch to sync of the active source or if it is selected via a remote for the external switcher.
I'm unsure if the Moome card auto switches without a remote or if it needs one to select. Doug
greg_mitch
Link Posted: Fri Nov 30, 2007 4:52 am Post subject: |
yes, that is what I was assuming. The dual inputs will then be of little use.
Most will have an outboard switcher anyway, right?
How about an xg-fullHD lite?
Link Posted: Fri Nov 30, 2007 5:49 pm Post subject: |
KennyG wrote: | I am planning to buy the non-remote controlled gamma card...so I am wondering how the dual HDMI inputs will work without remote control. OR will there no longer be a non-remote controlled unit? |
There will only be one version of the XG-FULLHD. All versions have gamma and remote. Same is true for all of his future products. Creating multiple versions of cards is enormously more work for Moome.
dbaisey wrote: | I'm unsure if the Moome card auto switches without a remote or if it needs one to select. Doug |
I'm 99% sure it will not autoswitch.
jarseneau
Link Posted: Fri Nov 30, 2007 6:57 pm Post subject: |
Kal wrote: | I'm 99% sure it will not autoswitch. |
From the faceplate image at the beginning of the thread I see what looks like a spot for a 'SEL' button. Perhaps that's for locally selecting the active HDMI input?
I'm curious if the card has it's own IR pickup for its remote or if it somehow uses the projector's IR receiver? The reason I ask stems from the way I use a Pronto remote macro to have the projector switch to a specific input when I hit the SAT TV macro button, etc. Right now the projector gets the IR no matter where I point since it has IR windows front and back.
_________________ Jerry
dbaisey
Link Posted: Mon Dec 03, 2007 3:28 am Post subject: |
Kal,
When switching HDMI on this does the card maintain a active handshake or does everything need to be rebooted? Thanks, Doug
Link Posted: Mon Dec 03, 2007 4:03 am Post subject: |
While I can't confirm for sure (hopefully Moome will chime in), I don't see how having to reboot all of the source devices when you swich between HDMI0 and HDMI1 would be an acceptable solution. That doesn't make any sense. I certainly wouldn't accept that as a solution.
Moome's other HDMI solutions with more than 1 input (ex: EXT-HD and MUX-HD) do not require source devices to be rebooted when you switch inputs.
dbaisey
Link Posted: Mon Dec 03, 2007 9:25 am Post subject: |
Thanks Kal. Doug
moome
Link Posted: Mon Dec 03, 2007 1:08 pm Post subject: |
dbaisey wrote: | Kal,
When switching HDMI on this does the card maintain a active handshake or does everything need to be rebooted? Thanks, Doug |
Dear Doug:
you will no need reboot dvd players!
nzryan
Link Posted: Tue Dec 04, 2007 1:01 am Post subject: |
ok,
so what is the max band width - 200mhz? - because of the 200mhz DAC?, does pre - dacs support the full HDMI 1.3 - 340mhz?
moome
Link Posted: Wed Dec 05, 2007 2:50 am Post subject: |
nzryan wrote: | ok,
so what is the max band width - 200mhz? - because of the 200mhz DAC?, does pre - dacs support the full HDMI 1.3 - 340mhz? |
the DAC can running 225MHZ no problem, and current hdmi chip only support 225MHz.
yonexsp
Link Posted: Sun Dec 09, 2007 3:22 am Post subject: |
where do we pre-order?
