JustGreg
Joined: 07 Mar 2006 Posts: 3085 Location: Kenosha, WI
TV/Projector: Marquee 8500
Link Posted: Wed Jul 25, 2007 6:12 pm Post subject: First lens distance to tube face |
Hey Barry...I was just reading about 144/145's fitted to Barco 808's in another thread:
http://www.curtpalme.com/forum/viewtopic.php?p=66248#66248
and got to wondering how close the lens should be to the tube face. The stock flapping distance is around .075". Not having taken on installing mine yet (damn landscaping!) I don't have any good measurements as to where the face of the first lens will end up in relation to the tube face after mounting. I realize the closer the better.
(I probably worded this all wrong but hopefully you know what I'm asking)
Greg
_________________ Greg
Joust
Joined: 05 May 2006 Posts: 2411 Location: Almonte, Ontario, Canada
TV/Projector: Marquee 8501LC
Link Posted: Wed Jul 25, 2007 6:22 pm Post subject: |
the short easy answer is, Close enough to focus.
All Smartassness aside. I'll measure tonight if i get a chance.
I'm not entirely sure. I did All my measuring of the stock HD8 and made teh adapters and spacers to emulate those. Testing proved it all worked.
It will be good to have some measurements. We probably will end up with a better idea of min and max throw and screen size.
might have to dig out my bench projector now. My real one is mounted on the ceiling and I'm not about to move it.
JustGreg
Link Posted: Wed Jul 25, 2007 6:57 pm Post subject: |
| Joust wrote: | the short easy answer is, Close enough to focus.
might have to dig out my bench projector now. My real one is mounted on the ceiling and I'm not about to move it. |
Unless it's info you really need to sell your products better don't go lugging anything around just for me. I just thought you might know offhand how close the lens face would be to the tube face.
Let me put it this way then...is there a "too" close? Obviously touching isn't a good thing.
Thanks for the quick reply!
Greg
Joust
Link Posted: Wed Jul 25, 2007 7:39 pm Post subject: |
hellifiknow.
I'll measure where it is now. both throw and width and raster width on the tube face.
JustGreg
Link Posted: Wed Jul 25, 2007 10:09 pm Post subject: |
| Joust wrote: | hellifiknow.
I'll measure where it is now. both throw and width and raster width on the tube face. |
Thank ya kindly sir.
zGman
Link Posted: Tue Jul 31, 2007 4:53 am Post subject: HD-144 lens |
Measuring for a HD-8 is counterproductive...
Measurement of a NEC housing made for the 144 lens
showed that they would allow the lens to almost touch
the tube face (less than 0.010 inches (~ 0.2mm) clearance)
The larger the screen, the closer the focus point to the tube face.
HD 145's will focus a few mm further out for a given screen size.
HD-144 have a considerably smaller input opening than the 145's,
consequently they are best suited for smaller screens (consider
what happens to the entrance angle as the distance to the tube
face decreases - less light can be collected and corners will be dim)
Cheers,
Galen
JustGreg
Link Posted: Tue Jul 31, 2007 4:32 pm Post subject: Re: HD-144 lens |
| zGman wrote: | Hi,
Cheers,
Galen |
Hmmmm. It appears I'm going to have to determine for my own application the optimal distance to produce the best overall focus and light capture. Oy my aching back. (The pj is ceiling mounted).
One good thing about not getting started on this project yet is the BOC screen I built hasn't been painted yet. I'm going to grab a sheet of the laminate discussed in the screen thread and then paint the BOC and do an A/B. (My screen frame is suspended via 4 point magnetics so changeout should be fast and easy).
Thanks for the info Galen!
Greg
zGman
Link Posted: Wed Aug 01, 2007 2:41 am Post subject: |
Hi Greg,
I am not quite certain if my information is really answering your
question, and this issue seems to come up pretty often. I
will try a little more and maybe make some sense. (?)
For a given throw distance, there is one point in the adjustment
range where the lens will focus. The focus adjustment moves
the entire lens body relative to the tube face. As the throw distance
increases, the screen size increases, and the lens will focus at a point
closer to the tube face. Other than setting the throw distance,
you have no control over this focus point. If the lens runs out
of travel before reaching focus, then the throw is too long.
Whether or not the adaptor or housing can be modded
is another story, depending on the range of adjustment.
The construction of the lens adaptors basically sets the range of travel
for the main(center) focus. If the lens cannot travel close enough to
the tube face it will not focus. This should not be a problem for HD-145
lenses. However, for HD-144's, the mounting of the lens in the adaptor
is more critical, but only for a for a larger screen (over 87" wide)
However, the size of your raster will determine the maximum
screen width for a given throw distance. For any lens, there is a
drop-off in output as you move away from optical centerline -
this can be as much as 60% less light at the corners for 16:9.
and even less for a 4:3 set-up. So, your raster size is a trade off
on any CRT, with any lens. Good reasons not to go too small
of course, and vice versa.....
The issue of the reduced input opening on the 144's is separate
from focusing - but it does relate to the use of larger screens.
Again, because the lens needs to be closer to the tube at longer
throw distance. If the lens is closer to the tube the entrance angle
is steeper. therefore of the cone of light emitted by a point on
the phosphor, beyond the radius of the lens opening, a smaller
percentage can make it into the lens.
Personally I would not recommend a 144 beyond 87", but have been
pleased with 145's at 96" wide. That being said - no doubt there
are people happy with their 144's at 100" wide...hohoho!!!!
Hope that helps,
Galen
