IFB-HD: Sony HDMI/Component input card with Gamma and IR remote
Upgrade your Sony projector by adding a HDMI/Component input with gamma correction and infrared remote control!
The IFB-HD allows you easily add digital devices such as HD-DVD/Blu-Ray players, PS3, X360 Elite, Satellite/Cable HDTV set-top boxes, and HTPCs with HDMI graphic cards (to name a few) to your Sony projector. Simply plug the IFB-HD into your Sony, your DVI/HDMI device into the IFB-HD, and watch! Installation takes 5 minutes.
HDMI input resolutions: 640x480 up to 1600x1200 (PC), and 480p up to 1080p at 60Hz (Video). (Any resolution and refresh rate up to 165Mhz pixel clock is supported).
DTV mode support (480p, 576p, 720p, 1080i, 1080p) for 50 and 60Hz
Supports both 16-235 and 0-255 colour range and auto selects correct value
BT601 (component) and BT709 (HDTV) colour space transform support with auto mode detect for correct colour space
High precision > 200Mhz 10bit DAC
High speed > 500Mhz output buffer
PC plug and play
HDMI 1.1/1.2 compliant as well as HDCP 1.0/1.1 compliant
HDMI/Component input auto-switching with user selectable priority setting
IR remote control input select
Gamma correction adjustment - variable
Low power consumption when disabled
FAQ
What unique features does this card offer?
TWO INPUTS: HDMI Female 100% digital, Component YCbCr analog (3 Female RCA connectors).
Auto-switches between inputs with user selectable priority setting).
Infrared remote control for switching between between the inputs.
Variable Gamma correction for absolutely perfect shadow details.
Are there any advantages to using this HDMI solution instead of a DVI based solution?
HDMI supports input cables up to 15 meter (50') long while most DVI solutions require an external power supply for lengths over 5 meters (16').
No crushed blacks (a problem on some some sources when using DVI). Reason: HDMI supports RGB 4:4:4 along with YCrCb 4:4:4 and YCrCb 4:2:2 colour spaces. DVI supports RGB 4:4:4 colour spaces. All source material is YCrCb and some sources do not correctly convert this to RGB causing a black crush problem where some of the darker picture information is lost. Sources that do this are rare, but still exist (the Toshiba HD DVD players being the most notable).
HDMI 1.1/1.2 and HDCP 1.0/1.1 compliant. (DVI is HDCP 1.0 compliant).
What's this gamma correction add-on card? What does it do? Why would I need it? Can't I just bump up my brightness?
For a complete explanation of Gamma Correction, please see this thread.
May card doesn't seem to work at all!
There are 3 jumpers on the card (J1, J2, J3) that must be set correctly depending on the type of Sony projector you have. See the PDF manual below for the correct jumper settings for your projector.
On my G90 the picture fluctuates from dark to light and does not stablize
You need to go into the service menu and change your clamp settings from Auto to H/P (H/C also works for some so feel free to experiment on which setting works for you). On the remote do the following: Normal, enter, enter, up, down, enter, enter...SERVICE MENU... INPUT SETTING... CLAMP. Change CLAMP from AUTO to HP.
On my G90 at 1080p, I get a signal that's VERY dark, and shifted to the left
See last issue. The clamp settings must be changed in the G90 service menu.
Manuals
The IFB-HD user user manual/data sheet can be found here. (v1.2, 0.1mb PDF)
DRM: Digital Restrictions Management - technology to restrict what you can do with media you purchase
AACS: Advanced Access Content System - the DRM infection used for both Blu-ray and HD-DVD
BD+: An addition to AACS for Blu-ray discs, that provides additional restrictions to what you can do
HDCP: High-bandwidth Digital Content Protection - Encryption of data over digital connections
HDMI: High Definition Multimedia Interface - A digital connection found on most new HDTV's, all HDCP compliant
DVI: Digital Visual Interface - Precursor to HDMI, found on many older HDTV's.
ICT: Image Constraint Token - Downsamples HD output to standard resolution when hooked up over analog (component) cables
DAC: Digital to Analog Converter
Pictures
Gamma adjustment module and remote control:
(The remote is not really intended for every day use of course - simply program the IR codes into your user friendly existing programmable remote).
July 12, 2007: IFB-HD cards being tested before being sent out to customers:
Link Posted: Mon Jun 11, 2007 8:42 pm Post subject:
A few corrections Kal:
2. HDMI supports both BT601 (component) and BT709 (HDTV) color space, so no black crash on some HD sources.
I believe this means "black crush" and the black crush issues are not due to color space. They are due to incorrect YCrCb -> RGB conversions (DVI only supports RGB 4:4:4 whereas HDMI supports that plus YCrCb 4:4:4 and YCrCb 4:2:2) in the source. All source material is YCrCb and some sources do not correctly convert this to RGB. These are rare today but still exist (the Toshiba HD DVD players being the most notable).
3. HDMI processes the image at 10 or 12 bits deep while DVI is limited to 8 bit.
The processing bit depth and the bit depth of the image are two completely different things. DVI is limited to 8-bit for the image whereas HDMI can do 8, 10 or 12 bit (this difference is irrelevant since every single source there is is only 8-bit).
As far as processing bit depth, since sources must convert the 8-bit YCrCb to 8-bit RGB for DVI connections, the processing bit depth may be 8, 10, or more in the source. Most are 10 which is sufficient.
4. The SIL907B's chip's DAC found on most DVI solutions is only 8bit (effective number of bits) while external 10bit DAC used on Moome's HDMI will have higher performance.
As far as the DAC, according to John and the Sil907B specs, it performs at 10 bits (yes effective bits). _________________ Dave
Link Posted: Tue Jun 12, 2007 2:18 am Post subject:
Has a price been determined, with the optional gamma card? _________________ In the real world, I am alan halvorson, King of the Wild Frontier and Swell Guy.
Link Posted: Tue Jun 12, 2007 5:27 am Post subject:
sorry, this should Kal mis-understanding. he will correct this later.
yes, but as my working experience, i have worked for DVD chip company before. some DVD have problem when convert YCbCr to RGB. HDMI can use YCBCR path and no problem. see this
i have 907B datasheet here, it is 10bit design, but 8 bit guaranteed.
any way, thanks for person99 correct some incorrect information.
Joined: 06 Mar 2006 Posts: 16793 Location: Ottawa, Canada
Link Posted: Mon Jun 25, 2007 3:53 pm Post subject:
Advanced model will be offered as well. Here's a complete price breakdown:
IFB-HD Basic Model: $310 USD
IFB-HD Advanced Model (with gamma circuit): $385 USD
IFB-HD High End Model (with gamma circuit and IR remote): $435 USD
Priority worldwide shipping included!
Hoping to get pre-orders going soon.
Units will start shipping in July (likely late July).
Link Posted: Sat Jul 28, 2007 5:04 am Post subject:
LJG wrote:
Moome:
Has the New Sony card been updated with the same chip as the new Marquee card?
Yes. The Sony IFB-HD and Marquee VIM-HD are the same card. Just a different internal interface.
Kal,
I believe the moome Sony HDMI card has been out since about Jan 2007. Is current batch of July 2007 basic (ignoring add on features like adjustable gamma and remote control) Sony HDMI cards changed from the initial Jan 2007 batch or is the card the same?
Link Posted: Sun Jul 29, 2007 3:42 pm Post subject:
Frank D wrote:
LJG wrote:
Moome:
Kal,
the basic IFB card is V1.332 also, have improved compare to Jan 2007 version!
Joined: 08 Apr 2006 Posts: 11382 Location: Fort Collins, CO
Link Posted: Tue Jul 31, 2007 7:43 pm Post subject:
Some questions:
* Is the "Advanced" model exactly the same as the "High end" model, except it doesn't come with a remote? In other words, can you control an "Advanced" model exactly like a "High End" if you work out the remote codes, or does the "Advanced" model actually have fewer features? (I don't want a $50 remote if I don't need it!)
* Is the gamma correction basically the same as tse's or Kim's gamma boosters, with a single control determining how much to boost the low 0-30 IRE area? A friend thought the "High End" model had 20-point gamma control but I think he's mistaken.
* Does this gamma circuit maintain a constant 0.7 Vpp when you adjust gamma, or does it boost the Vpp when you boost gamma? Kim's/tse's circuit boosts the Vpp and that's a pain -- you need to use something like an Extron box to scale it down so you don't overload your video input circuitry. And that wouldn't be an option with an internal card so I'm hoping this card produces a constant Vpp?
