Link Posted: Thu Jun 15, 2017 1:26 am Post subject: |
A different Blu Ray player, an older version but better quality. It seems to work better with the 03 VIM I think
Link Posted: Fri Jun 16, 2017 9:47 am Post subject: |
Link Posted: Thu Jun 22, 2017 10:00 am Post subject: |
The neck boards are now matched to the 03 VIM...
Link Posted: Sat Jun 24, 2017 1:26 am Post subject: |
Lower the contrast helps with the blooming
Link Posted: Tue Jul 04, 2017 12:17 am Post subject: |
Link Posted: Wed Jul 05, 2017 4:12 am Post subject: |
Link Posted: Wed Jul 05, 2017 1:03 pm Post subject: |
Just switched Vim's
No changes in a awhile on the setup. Figuring out the later changes and thinking I may try a color balance later to see what happens. The screens looks very different, yet the cheap camera is doing better. Still have a ways to go.
Link Posted: Thu Jul 06, 2017 1:36 pm Post subject: |
Link Posted: Fri Jul 07, 2017 1:31 am Post subject: |
Changed the VIM again. Still have not touched anything on setup
Blu Ray Player direct to Moome.
Link Posted: Tue Jul 11, 2017 8:22 am Post subject: |
1080P direct to the Moome
nidi
Link Posted: Tue Jul 11, 2017 5:03 pm Post subject: 5th Element Shots |
Mike, those 5th Element shots still look a little dim to me.
what Contrast, G2 are you running now?
Link Posted: Tue Jul 11, 2017 6:21 pm Post subject: Re: 5th Element Shots |
nidi wrote: | Mike, those 5th Element shots still look a little dim to me.
what Contrast, G2 are you running now? |
Contrast 50. Plus, they are all inside low light ("azziz light") filmed. I run shorts like this to put emphasis on Detail. With my green CRT being defective it blooms on anything above 55, yet still I can get incredible light output on the screen. But because of the defective green CRT, would would see the green blooming as can been seen in a lot of my previous shots.
These neck boards drive very hard and that also makes them perfect for LUG's, because they maintain spot size better then LCP's at higher drive levels. One of the reasons why the G90 was brighter than the Marquee - The LUG tubes!
I have both brightness and detail, and it does so at very high light output, and that's even with the green LCP tube in there.
Brightness, Sharpness and Detail are all cake for this setup, because it does all three very well..
I plan to have a few invites over next month to demo a few things..
nidi
Link Posted: Tue Jul 11, 2017 9:12 pm Post subject: Aziz Light! |
yep, I want to see lots of light on my LUG's.
Link Posted: Fri Jul 14, 2017 10:57 am Post subject: Re: Aziz Light! |
nidi wrote: | yep, I want to see lots of light on my LUG's. |
You will for sure. But I'll assure you that you'll also have an appreciation for not so bright. The shots below are at 50, while I'm comfortable with the contrast at 68.
Link Posted: Sat Jul 15, 2017 7:51 am Post subject: |
Link Posted: Mon Jul 17, 2017 5:03 am Post subject: |
I keep forgetting to re-seat the FG module to get rid of the bow
Link Posted: Tue Jul 18, 2017 2:56 pm Post subject: |
Here we go again.
racerxnet
Link Posted: Mon Jul 24, 2017 8:26 pm Post subject: |
I've always said, screen shots prove absolutely nothing, yet they are the longest running thread on every forum out there. I've asked every modder that's ever posted here to provide data: 'scope traces and frequency response tests for before and after pix, and to my knowledge, no one has ever done it.
Link Posted: Mon Jul 24, 2017 8:37 pm Post subject: |
Curt Palme wrote: | I've always said, screen shots prove absolutely nothing, yet they are the longest running thread on every forum out there. I've asked every modder that's ever posted here to provide data: 'scope traces and frequency response tests for before and after pix, and to my knowledge, no one has ever done it. |
False, I've done that here and here
