gregstv
Link Posted: Tue Jun 06, 2017 1:10 pm Post subject: |
A few from the 4k player
322.55 KB |
8129 Time(s) |
244.05 KB |
8129 Time(s) |
231.51 KB |
8129 Time(s) |
234.45 KB |
8129 Time(s) |
258.2 KB |
8129 Time(s) |
190.58 KB |
8129 Time(s) |
219.93 KB |
8129 Time(s) |
257.72 KB |
8129 Time(s) |
Link Posted: Tue Jun 06, 2017 1:14 pm Post subject: |
Is that a 4K disk and if so, which one?
gregstv
Link Posted: Tue Jun 06, 2017 1:19 pm Post subject: |
Yes 4k disk. The shallows and the great wall
gregstv
Link Posted: Tue Jun 06, 2017 1:28 pm Post subject: |
A few more from the great wall
269.08 KB |
8120 Time(s) |
239.66 KB |
8120 Time(s) |
254.17 KB |
8120 Time(s) |
198.6 KB |
8120 Time(s) |
ElTopo
Link Posted: Tue Jun 06, 2017 6:07 pm Post subject: |
Which 4K Player ?
gregstv
Link Posted: Tue Jun 06, 2017 7:34 pm Post subject: |
Panasonic.
gregstv
Link Posted: Tue Jun 06, 2017 7:40 pm Post subject: |
These are from the Barco 919 with lots of mods. It looks really nice in person. The camera doesn't do it justice.
ElTopo
Link Posted: Tue Jun 06, 2017 8:25 pm Post subject: |
Panasonic UB900 ? into what HDMI card ?
gregstv
Link Posted: Tue Jun 06, 2017 8:41 pm Post subject: |
I am sending 1080p@24 into a DVDO VP50. 1080p@48 out into a moome internal.
The DVDO is only used for frame rate doubling. All other settings are at zero.
ElTopo
Link Posted: Tue Jun 06, 2017 9:04 pm Post subject: |
Is this the internal moome HDMI 1.4 card ?
I ask because my Pana UB900 into the Moome ext V3 does show a pic with wrong color(s) and black crush.
The Samsung K8500 and Oppo203 worked fine instead.
gregstv
Link Posted: Tue Jun 06, 2017 11:27 pm Post subject: |
Yes it's is 1.4 from what I understand. I have an external V3 and it is no where as good as the internal moome. No
Link Posted: Wed Jun 07, 2017 12:36 am Post subject: |
gregstv wrote: | Yes it's is 1.4 from what I understand. I have an external V3 and it is no where as good as the internal moome. No |
So how does the internal moome compare to Port 5?
What would you say about the Panasonic v Cambridge player at the same resolution?
gregstv
Link Posted: Wed Jun 07, 2017 2:21 am Post subject: |
I prefer 4k when I can get the disk in 4k. As for Blu-ray there is not much between them. I think the audio is better on the Cambridge but I am running analog out to the Onkyo and HDMI with the Panasonic.
ElTopo
Link Posted: Wed Jun 07, 2017 9:15 am Post subject: |
What have you modded within your BR919 ?
gregstv
Link Posted: Wed Jun 07, 2017 11:16 am Post subject: |
Lots, port 3 switching circuit, new OP amps on switcher and driver boards. Os-Con caps on all low voltage rails. Ferrite indicators on OP amp rails. Opa chip upgrade on neck board. Extra filtering on amps. Metal cage on back of neck boards. All coax's changed to semi ridged and SMP connectors used on switcher. Also coax on the moome to switcher. All other boards have been re-capped. Result is a very clean and sharp picture.
Link Posted: Thu Jun 08, 2017 2:04 am Post subject: |
Link Posted: Sat Jun 10, 2017 2:53 am Post subject: |
03 VIM with same setup settings (not calibrated - rough setup).
Link Posted: Mon Jun 12, 2017 7:58 am Post subject: |
Well, finally finished the 03 VIM last fix and loving it for a true and flat 200Mhz video chain. Above a huge improvement on my screen, I've noticed the files size of my camera shots that were normally around 2MB are now up to 5MB on the same scenes. And I've still not touched the setup. But using a different camera this time also
thewolfman
Link Posted: Wed Jun 14, 2017 4:01 am Post subject: |
I think these look especially good. Make notes what you did so not to forget. But this is just me talking, I know very little about imagery, but think they look good regardless.
Link Posted: Wed Jun 14, 2017 11:53 am Post subject: |
thewolfman wrote: | I think these look especially good. Make notes what you did so not to forget. But this is just me talking, I know very little about imagery, but think they look good regardless. |
They are different for sure. I'll do some more later this evening. These (below) are quickies
