bluemoonhu
Link Posted: Sat Apr 23, 2022 2:38 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
Such the fragile tube!
Download |
Filename: |
QQ图片20220423105001.jpg |
435.92 KB |
Downloaded: |
70 Time(s) |
bluemoonhu
Link Posted: Sat Apr 23, 2022 2:50 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
Hulio wrote: | Are the tubes P16LNG22 ? If yes, I know a cheap set in good shape.
Are you located in Hungary ? |
Yes! I am in China
Hulio
bluemoonhu
Link Posted: Sat Apr 23, 2022 9:44 am Post subject: |
Do you have the RGB driver board of BG 808s ?
Hulio
Link Posted: Sat Apr 23, 2022 6:21 pm Post subject: |
No, sorry. Myself, I use a Barco Cine 9.
bluemoonhu
Link Posted: Sun Apr 24, 2022 2:46 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
Hulio wrote: | No, sorry. Myself, I use a Barco Cine 9. |
very rare machine! Please look at the PM。
bluemoonhu
Link Posted: Thu May 26, 2022 2:41 am Post subject: |
There are new problems again. In order to save this 708, I bought a faulty C7. The deflection board in this C7 is faulty. I used the deflection board in 708 to replace C7. as a result, the deflection board of 708 was burnt out。
bluemoonhu
Link Posted: Thu May 26, 2022 3:37 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
C7 and 708mm
187.21 KB |
2018 Time(s) |
bluemoonhu
Link Posted: Thu May 26, 2022 3:41 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
When I reinstalled the deflection board of 708 back to 708, there was a fault light and the machine could not run
83.11 KB |
2016 Time(s) |
bluemoonhu
Link Posted: Thu May 26, 2022 3:44 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
SF---deflection board fault
160.96 KB |
2014 Time(s) |
bluemoonhu
Link Posted: Thu May 26, 2022 3:54 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
I checked the deflection board electric resistance and found that the resistance values of the two resistors could not be measured. have they been burned?
154.62 KB |
2012 Time(s) |
bluemoonhu
Link Posted: Thu May 26, 2022 3:56 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
Resistance I
104.77 KB |
2010 Time(s) |
bluemoonhu
Link Posted: Thu May 26, 2022 3:57 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
Resistance 2
97.33 KB |
2007 Time(s) |
bluemoonhu
Link Posted: Thu May 26, 2022 4:00 am Post subject: |
Where is the deflection board of 708 most likely to fail? thank you!
bluemoonhu
Link Posted: Thu May 26, 2022 4:01 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
438.65 KB |
2003 Time(s) |
Hulio
Link Posted: Thu May 26, 2022 10:36 am Post subject: |
Keep in mind that not all boards from 708 can be swapped with the ones from C7.
Should your 708 be a data grade, yes. I guess yours is a vision version.
The best way to find out, is to check the part number on the module sticker (R762XXX). A C7 deflection board is R7627625, while the one from the 708 is R762447. Thus, not compatible.
I would try to revive the C7, instead of the 708 (newer components, higher bandwidth, more inputs etc).
bluemoonhu
Link Posted: Thu May 26, 2022 1:25 pm Post subject: Barco 708MM “HOLD DOWN EHT” fault |
Hulio wrote: | Keep in mind that not all boards from 708 can be swapped with the ones from C7.
I would try to revive the C7, instead of the 708 (newer components, higher bandwidth, more inputs etc). |
The 708 is vision 708mm.
yes! I know they had a different number, but they looked almost the same, so I exchanged them. I am sorry!
bluemoonhu
Link Posted: Thu May 26, 2022 3:08 pm Post subject: Re: Barco 708MM “HOLD DOWN EHT” fault |
kal wrote: | bluemoonhu wrote: | Resistance 2 |
That's a diode, not a resistor.
Kal |
Where is the fault?
Thanks!
bluemoonhu
Kal |
Where is the fault?
Thanks!
