bluemoonhu
Link Posted: Sat Jun 18, 2022 8:23 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
Is the colored logo on the three plugs facing up or down?
160.84 KB |
3668 Time(s) |
bluemoonhu
Link Posted: Sat Jun 18, 2022 8:53 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
I found a wire out of position. Where should it be installed?
99.44 KB |
3664 Time(s) |
Link Posted: Sat Jun 18, 2022 2:39 pm Post subject: |
That's not a Barco original wire. Someone modded that set. IS it a Runco? They did stuff like that all the time.
bluemoonhu
Link Posted: Sat Jun 18, 2022 3:25 pm Post subject: |
Curt Palme wrote: | That's not a Barco original wire. Someone modded that set. IS it a Runco? They did stuff like that all the time. |
This is a barco c7
Thanks Curt
bluemoonhu
Link Posted: Sat Jun 18, 2022 11:45 pm Post subject: Barco 708MM “HOLD DOWN EHT” fault |
kal wrote: | Where does the other end of the wire go?
Kal |
One end of this wire should be led out from the metal component of the fan
bluemoonhu
132.27 KB |
3628 Time(s) |
bluemoonhu
Link Posted: Sun Jun 19, 2022 1:54 am Post subject: |
kal wrote: | It’s a fan wire? So what does the service manual say? We have them all on our site. It should show where it connects.
Kal |
There seems to be no introduction to this aspect on the site
Hulio
Link Posted: Sun Jun 19, 2022 11:08 am Post subject: |
Hu,
Right between those two rear fans, there is a small PCB board (with a white J5 connector on it). On the backside of that PCB board, you'll find the connectors for the fans. You can't really reach them, you'll have to remove the metal plate first.
Check your mail for pictures, it seems I reached my max. upload limit here.
bluemoonhu
Link Posted: Sun Jun 19, 2022 1:20 pm Post subject: |
Hulio wrote: | Hu,
Check your mail for pictures, it seems I reached my max. upload limit here. |
Yes, I have to remove the fan metal plate。
Thank you!
bluemoonhu
Link Posted: Mon Jun 20, 2022 8:52 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
After remove the fan metal plate, the red-black wire shows up。。。
115.02 KB |
3568 Time(s) |
bluemoonhu
Link Posted: Mon Jun 20, 2022 9:01 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
The red-black wire seems to be a wire testing 12V
61.96 KB |
3566 Time(s) |
bluemoonhu
Link Posted: Mon Jun 20, 2022 9:19 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
The socket of this wire can exactly match with the two sockets on the baseplate board....I don't know if I can connect them like this or no connect?
191.04 KB |
3564 Time(s) |
Hulio
Link Posted: Mon Jun 20, 2022 11:54 am Post subject: |
Yes, it is ok to plug the fan connector in there.
The 12V trigger is meant to control an electrical projection screen. Barco on, the screen automatically rolls down in his memory position.
Only later designed Barco's had that.
bluemoonhu
Link Posted: Mon Jun 20, 2022 12:06 pm Post subject: |
Hulio wrote: | Yes, it is ok to plug the fan connector in there.
Only later designed Barco's had that. |
Praise Barco!Great Barco...
Thank you!
bluemoonhu
Link Posted: Tue Jun 21, 2022 10:08 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
The part in the red circle of C7 is different from the measured value of 708,I don't know if this part is good or bad
105.53 KB |
3519 Time(s) |
bluemoonhu
Link Posted: Tue Jun 21, 2022 10:11 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
This is it
129.97 KB |
3518 Time(s) |
bluemoonhu
Link Posted: Tue Jun 21, 2022 10:15 am Post subject: Barco 708MM “HOLD DOWN EHT” fault |
Is the measured value correct?
89.04 KB |
3517 Time(s) |
