bluemoonhu
Link Posted: Mon Sep 06, 2021 2:45 pm Post subject: barco cine8 PWC has failed... |
my barco c8 PWC has failed,I checked it and found that a power amplifier tube was broken, a fuse was broken, I replaced them,I reinstalled this PWC on the machine, The c8 was normal,You can see the image, but ,two minutes later, the machine automatically shut down again, I checked the PWC again and found that another power amplifier tube was burned,The reason is that there was no silica gel between the power amplification tube and the heat dissipation plate, which makes the tube burn. I replaced the power amplifier tube again,When I installed the PwC into the machine again , I pressed the power button on the rear of the machine,the power indicator light is on, and a row of detection lights are also on, but ,the machine cannot run with the remote control。 Why is that?
Thanks!
bluemoonhu
Link Posted: Mon Sep 06, 2021 3:08 pm Post subject: |
PWC= SMPS,Main Power Supply
bluemoonhu
Link Posted: Mon Sep 06, 2021 11:29 pm Post subject: |
yes, the main SMPS has failed, its number is R7690205. the power amplifier on it was broken.
bluemoonhu
Link Posted: Tue Sep 07, 2021 1:12 am Post subject: |
I have two main SMPS boards (a R7621706 and a R7621705) , can they replace R7690205 board on barco Cine8?
Link Posted: Tue Sep 07, 2021 1:57 pm Post subject: |
I believe so. Try it.
bluemoonhu
Link Posted: Wed Sep 15, 2021 2:01 am Post subject: |
The SMPS board is repaired。
