jbltecnicspro
Link Posted: Wed Aug 04, 2021 4:35 pm Post subject: Plasma TV issues |
Good morning all,
Was gifted an old Sony plasma. Decent TV for the kids. One thing I've noticed is that after it's been on for 30 mins, it develops a thin vertical line on the left end of the panel. Sometimes it's a different color than the rest of the content, and sometimes on red it's black. Anyways...
What should be a first step to troubleshoot/fix this? The set was made in 2004. I was going to take it apart and see if the cables need to be reconnected to the panel. Anything else? Thanks,
jbltecnicspro
Link Posted: Wed Aug 04, 2021 9:46 pm Post subject: |
Bad panel or driver board. Generally, a bad panel.
jbltecnicspro
Link Posted: Wed Aug 04, 2021 10:13 pm Post subject: |
Curt Palme wrote: | Bad panel or driver board. Generally, a bad panel. |
Could you expand on this? I’m only really versed in the workings of CRT’s. Guess I’m a dinosaur. . What’s going bad on the panel?
Link Posted: Mon Aug 09, 2021 2:45 pm Post subject: |
The panel itself it likely going. Do the stripes come and go, OR are they there all the time just changing colors?
Link Posted: Mon Aug 09, 2021 6:38 pm Post subject: |
jbltecnicspro wrote: | Curt Palme wrote: | Bad panel or driver board. Generally, a bad panel. |
Could you expand on this? I’m only really versed in the workings of CRT’s. Guess I’m a dinosaur. . What’s going bad on the panel? |
Plasmas have two boards generally driving the panels, one for the X and one for the Y. Some sets also have small driver chips embedded into the plasma panel ribbon cables. If those go bad (possibly your problem, then the set is a throwaway.
you can also try reseating the ribbon cables on the boards.
