SGT Dave
Link Posted: Mon Jun 21, 2021 7:45 pm Post subject: NEC XG Factory Mount |
Hello,
I am preparing to ceiling mount my NEC-XG85 using the factory mount. I was going to attach unistrut to the ceiling with lag bolts and then attach the mount to the unistrut with 3/8" machine screws. That all seems more than beefy enough for the task. However, I am worried about the eight M6 screws that attach the mount's L-brackets to the projector. Is that correct? They seem like awfully tiny screws for all that weight.
Anyone use this mount before?
Link Posted: Mon Jun 21, 2021 10:47 pm Post subject: |
You're right, I questioned that as well, but nope, you're fine.
jask
Link Posted: Tue Jun 22, 2021 7:52 am Post subject: |
I have also used them, they are fine👍 keep in mind that each one of those screws should be able to support over 400lbs of pull out force under standard design calculations.... It just looks sketchy😁
SGT Dave
Link Posted: Wed Jun 23, 2021 3:14 am Post subject: |
Thank guys, finished hanging her tonight. I'm going to be sore in the morning.
SGT Dave
Link Posted: Fri Jun 25, 2021 12:32 am Post subject: |
Here is the finished job.
288.3 KB |
2290 Time(s) |
