G90 owners may want to consider this: BA Board Rebuild
PostLink    Posted: Thu Dec 24, 2020 4:02 pm    Post subject: G90 owners may want to consider this: BA Board Rebuild Reply with quote
Having me rebuild your BA board. All of the BA boards that I have seen in recent years have exhibited the problem with horizontal lines running through the image to some degree or another.
Curt wrote:
...I do have two RGB input boards that pass signal, but have lines running through the image (I suspect bad SMT electrolytic caps)...
I responded with:
CIR Engineering wrote:
This has been a common issue with the BA boards that surprisingly has not gotten much attention on the forums. The early signs are that when the projector is first turned on horizontal lines (about 1.5" depending on screen size) will roll quickly from either top to bottom or bottom to top, slow down, and then reverse direction. When the problem begins the lines will slowly disappear as the projector warms up. If you want to look, it's easiest to see on a simple white on black cross-hatch pattern, but you can usually see it in real world video even in early stages.
The issue gets worse the older the projector gets whether or not you use the G90. Finally, the problem will become so bad that the lines never disappear and the picture is unwatchable. Even long before this state, rebuilding the BA board will make the image much better. The problem causes a haze in the image and loss of clarity and sharpness. Black level is also affected because the lines are of alternating brightness levels.
I've been rebuilding BA boards because of this for the past three or four years. It's caps and power chips. It's best to keep a specific BA board with its matching neck cards and YA board whenever possible (BA and neck card most important), so I like to rebuild the projector's original BA board whenever it's available. I charge $350 $395 parts and labor plus shipping and PayPal fees to do the job. I do them on off-days because they actually do take a full day of work once I unpack, rebuild, test, and then repack.
A forum member harry27 had me rebuild his BA board a few weeks ago, but he brilliantly captured the distortion in a video before he sent the board to me for rebuild. I got permission from him to post his video linked below. If yours looks this bad in real world, it will be blatantly obvious in a cross-hatch pattern. This is what I would still consider "early stage" degradation, it will get much worse. Either way, all the G90's will benefit from a BA board rebuild at this point and you will see an image quality improvement. If you want to keep your G90 for a while or if you are just setting up a new to you G90 I'd suggest having me do this.
Video of problem on real world video:
http://www.cir-engineering.com/bin/banoise.mov
The lines you see may be darker, move faster, or change direction more or less often. Sometimes the lines can even remain stationary at times.
I have been doing lots of these so I keep plenty of parts in stock at all times and can turn these over quickly as long as we coordinate on date before shipping. Please email me if you are interested. Also, feel free to call or text.
Last edited by CIR Engineering on Tue Jan 25, 2022 5:26 pm; edited 2 times in total
PostLink    Posted: Thu Dec 24, 2020 5:47 pm    Post subject: Reply with quote
yup, I've seen that a bunch now. I'll send my bad BA boards to you next week.
PostLink    Posted: Thu Dec 24, 2020 6:45 pm    Post subject: Reply with quote
Cool Curt. You’ll get your special dealer pricing of course. Just let me know when you send them out with tracking.
PostLink    Posted: Thu Dec 24, 2020 6:58 pm    Post subject: Reply with quote
I don't need them back, keep them for parts. Smile
I got rid of my G90 test chassis last month, so I have nothing here for G90s, save for some boards that I'll get rid of over the holidays. They're all yours. Smile
PostLink    Posted: Thu Dec 24, 2020 7:01 pm    Post subject: Reply with quote
Even better. Thanks Curt Cool
Happy holidays!
PostLink    Posted: Thu Dec 24, 2020 7:19 pm    Post subject: Reply with quote
Hmmm maybe I should buy a BA and YA board off you Craig. Then all I would need is the rest of the projector to go with it lol
I've seen those lines before and he did capture that well on video.
Wonder if this happens on the 1292's?
PostLink    Posted: Fri Dec 25, 2020 12:51 am    Post subject: Reply with quote
Well, if you buy those two parts I’ll throw in the test of the projector Laughing
It’s just noise and as the caps degrade with time and the power regulators grow old with usage and age I’d say that kind of noise can work it’s way into about any analog device. The thing is whether or not it’s perceivable, and in this case it very much is. One thing the G90 has always had working against it is its tremendous complexity. More places for noise to be generated and also more paths for noise to get into the video signal. There are more than half a dozen power regulators on the BA alone.
PostLink    Posted: Sat Jan 15, 2022 5:10 pm    Post subject: Reply with quote
Just want to give this thread a bump because I have been doing a lot of G90 BA boards lately. Just want to remind those of you on the fence that there really is a need for this now on the G90's and the visual improvement is very noticeable.
This is a very labor intensive job though and my time is even more scarce than before. I have raised the original price to rebuild the BA boards from $350 to $395 plus shipping and any money transfer fees if applicable (ACH, check, and cash have no fees).
RickNa
PostLink    Posted: Wed Feb 16, 2022 9:12 pm    Post subject: Reply with quote
These post are pretty old, are you still rebuilding these boards? I've had the issue you describe for quite awhile now on my G90. Let me know! I have another issue I need to resolve though with color being wrong but I want to try to see if it occurs from all sources. Thanks!
PostLink    Posted: Wed Feb 16, 2022 9:19 pm    Post subject: Reply with quote
Yup, I just bumped this thread a couple weeks ago to make it visible again. I've been doing a lot of these rebuilds lately.
Just shoot me an email: craigr@cir-engineering.com
Dancrt
PostLink    Posted: Wed Feb 16, 2022 11:30 pm    Post subject: Reply with quote
Hi Craig can you check your email
Please I sent you a private message in this forum
6 months ago and emailed maybe it’s in you spam
It’s still in outbox in forum so unread ?
Can you check spam Folder and I remailed you just then
I got the main stuff from you two years ago but there
Was the last thing
thanks dan
PostLink    Posted: Wed Feb 16, 2022 11:38 pm    Post subject: Reply with quote
Sorry. Just wrote a quick reply to your email. I'll get you taken care of tomorrow.
