None of the mid-range AVRs have preouts anymore
PostLink    Posted: Wed Dec 16, 2020 9:22 pm    Post subject: None of the mid-range AVRs have preouts anymore Reply with quote
Things have changed, and for the worse, over the decade I spent happily with my home theater setup. Recently I went and bought a new TV that was enough of a critical change it can be used for critical viewing. But I had no AVR in the house that could do 4K. Initially, I just plugged the 4K sources into the TV directly, using the eARC channel (designated HDMI) to back feed audio only to discover my AVR didn't support ARC, let alone eARC. I had to settle for DD, or DD+, or whatever SPDIF optical out afforded me.
This lead me to go looking at AVRs in the $600-900 range and to my shock none of them had preouts. Only the high end models by manufacturers had them. Way back in 2009 I made the move to buy into separates but used mid-range AVRs as a Prepro because actual prepro products were absurdly price, IMO. I guess something had changed in the past decade that makers chose to remove unamplified channel outputs unless you are willing to pay $1K or more.
I always thought--without solid knowledge--the processing stage and the amplification stage were two separate sections of the same PCB, or even different PCBs. I had not considered now that the processing and amplification is done in an integrated fashion to where one couldn't simply cable-out the processed signals just prior to inputting them into an amplification stage.
Does anyone know how to determine this, and if anyone runs a side business of making a preout breakout block modification where the tapped into (soldered)?
PostLink    Posted: Wed Dec 16, 2020 9:28 pm    Post subject: Reply with quote
I don't think it's so much that they *can't* put pre-outs on an AVR, but that people at a certain price point just don't want or need them. Removing half a dozen to a dozen RCA/phono connectors on the back of the unit saves a few bucks and if few people want them, why bump up the price? Keeping certain features off the lower end models also forces people to "buy up" too which the manufacturer of course wants.
What about a low end pre-pro (no amps) instead of an AVR. By the very definition it has to have pre-outs otherwise it's kinda pointless. Wink
Example: https://emotiva.com/collections/processors/products/mc-700 ($699 at this time)
PostLink    Posted: Wed Dec 16, 2020 11:33 pm    Post subject: Reply with quote
It's called cutting corners. I am using a top of the line Onkyo from about 8 years ago that I had repaired under their extended warranty. $1400 new, and I picked it up at the local recycler. Onkyo discontinued that program in Dec 2019, but I got mine (and about 8 others that I ended up selling) done at no charge.
If you don't need Atmos, I may still have an Onkyo repaired unit here with preamp outs.. I think.
PostLink    Posted: Thu Dec 17, 2020 1:22 am    Post subject: Reply with quote
Lexicon like the RV-9 has them and I'm pretty sure Marantz as well.
PostLink    Posted: Thu Dec 17, 2020 1:11 pm    Post subject: Reply with quote
Not sure I'd call that a mid-range AVR. Wink
PostLink    Posted: Thu Dec 17, 2020 2:23 pm    Post subject: Reply with quote
True...
I have a dealer demo that is in perfect condition with full warranty that I can do really cheap though! High end and mid-fi prices Mr. Green
PostLink    Posted: Thu Dec 17, 2020 2:50 pm    Post subject: Reply with quote
Go for it Wan! That's an excellent AVR.
P.S. I've been eye-balling the Anthem AVM70 myself: https://www.anthemav.com/products-current/type=av-processor/model=avm-70/page=overview
(I'm seriously due... I'm still running an Acurus ACT-3 from the late 90s myself Shocked (lossy DD/DTS 5.1 only))
PostLink    Posted: Thu Dec 17, 2020 2:51 pm    Post subject: Reply with quote
The MC-700 does not offer HDMI 2.1, so no 4K60, let alone 4K120. BTW, I found that Monoprice, somewhere we all went to for cheap stuff, selling a surround processor for $4K! Even they went upscale.
PostLink    Posted: Thu Dec 17, 2020 2:54 pm    Post subject: Reply with quote
Yep, and it's getting pretty good reviews too: https://www.monoprice.com/product?p_id=37887
PostLink    Posted: Thu Dec 17, 2020 2:59 pm    Post subject: Reply with quote
I talked to Kris Deering while he was reviewing Monoprice's new top of the line, and he was floored with how great it is. He can't believe the price point and capability of the thing. He's not the type to open a unit so he couldn't comment on build quality, but like I say, he was blown away with the value per dollars and that it was simply so good. I did not get a final opinion before he sent it back to them though.
Last edited by CIR Engineering on Thu Dec 17, 2020 3:03 pm; edited 1 time in total
PostLink    Posted: Thu Dec 17, 2020 3:02 pm    Post subject: Reply with quote
This is the lexicon I have a demo unit of:
https://www.lexicon.com/products/receivers/RV-9.html
It has HDMI 2.0a. It's the same thing as the MC-10 pre/pro (I own this) except with amps and minus the XLR outputs.
