sukwoto
Link Posted: Thu Jul 02, 2020 2:04 pm Post subject: suddenly shutdown Barco 1209 |
I have a problem in my Barco 1209, the projector suddenly shutdown when the projector running.
After turn ON again, the projector running normal...time to time more often shutdown
Is it problem at EHT board or Quadrupler or else?
Pls advice
Thank you very much
Regards
Hulio
Link Posted: Thu Jul 02, 2020 9:45 pm Post subject: |
Hello,
Same symptoms few months ago with a BR909. Changing the quad solved the problem.
sukwoto
Link Posted: Fri Jul 03, 2020 1:13 am Post subject: |
Thanks for the inform my friend
Anyway...who has a stock for Barco 1209 graphics quad?
Thanks and keep healthy
sukwoto
Link Posted: Sat Jul 04, 2020 4:42 am Post subject: |
I just check...I have one unit quadrupler ex Barco 1208, is same with Barco 1209 ?
Pls advice..
Thank you
Regards
Hulio
sukwoto
Link Posted: Sat Jul 04, 2020 1:10 pm Post subject: |
Many thanks for your inform.
It's very helping
Regards
sukwoto
Link Posted: Sun Jul 12, 2020 5:30 pm Post subject: |
Hello,
I was change the quad and the projector running normal, but a few days later it's happen again, the projector suddenly shutdown every a few time.
Has another problem?
Pls advice
Thank you very much
Regards
Sukwoto
sukwoto
Link Posted: Thu Jul 16, 2020 5:27 am Post subject: |
I just trying to replace HV Splitter, but still not working, no picture at all.
One tube (green) not glow, I try to change neck board, but that tube still not glow and no picture
Pls advice.
Link Posted: Thu Jul 16, 2020 9:37 am Post subject: |
Have you Checked 17.5v on SMPS?
Have you checked that the Maximum Horizontal Width is not too wide. That's also set from SMPS.
Link Posted: Fri Jul 17, 2020 8:40 am Post subject: |
In terms of checking the SMPS you can try the following
Check that the 17.5 volt line is adjusted correctly. You can also check the heater voltage which should be around 6.3 volts and make sure the maximum horizontal width is set correctly. Check the capacitors visually for any deformities, Check solder joints for cracks. That's a pretty good start.
sukwoto
Link Posted: Tue Aug 25, 2020 9:03 am Post subject: |
Hello,
I just replace video signal after quad and splitter was replace previous.
All the tube are glowing now but still no picture.
Before video signal replace, one tube (green) is not glowing.
Red led at The EHT board still on.
Pls advice.
Thank you
Sukwoto
Link Posted: Tue Aug 25, 2020 9:48 am Post subject: |
sukwoto wrote: | Hello,
Pls advice.
Thank you
Sukwoto |
The red LED is a scan fail. I have attached the schematic for the scan fail circuit for an 808s. I would think its much the same for the 1209. Check these components,
EHT
RGB Driver
Vertical and horizontal deflection boards. Check for red LED.
All three deflection coils
Vertical Scan switch which is on the frame. This switch should be in if the projector is table mounted. Check its position and the position of the three horizontal switches.
Have you tried an external video source?
Download |
Filename: |
ScanFailCircuit.pdf |
57.28 KB |
Downloaded: |
251 Time(s) |
sukwoto
Link Posted: Thu Aug 27, 2020 6:04 pm Post subject: |
I just try to replace RGB Driver and Vertical and horizontal boards with my stock but still not working/no picture.
Is it the EHT board problem? Red led still On at EHT board
I don't have EHT board stock.
Anyone have stock? EHT board for Barco 1209/R762xxx
sukwoto
Link Posted: Sun Sep 13, 2020 11:45 am Post subject: |
Hello,
I just replace EHT board and video signal, but still no picture.
All tubes are glowing now.
Red led at vertical board turns ON.
Pls advice
Thank you
sukwoto
Link Posted: Sun Sep 13, 2020 1:05 pm Post subject: |
I just try to replace vertical board but still not working, the red led still ON
