Link Posted: Tue Aug 06, 2019 11:32 am Post subject: The VIM-DB |
Not that modifying CRT projectors are still a hot topic, but I have to entertain myself with something...
Here is a new development waiting for trial.
This is a modification board specifically for Marquee projectors. This daughter board follows the conventional circuit topology like the original VIM: signal switch followed by a variable gain amplifier. But with all new components, this is not based on the AD834/835 multipliers anymore, instead a variable gain amplifier called VCA824.
Regarding bandwidth the previous VNB-DB boards were already as good as needed, but it is somewhat difficult to deal with as it needs the VIM, VNB, LVPS and HDM modified to various extent. While the later two is a recommended modification to any Marquee anyway, it is still somewhat demanding to carry out such modification.
This new board is aimed to overcome this weakness, it again contains all signal processing on a single PCB (including own, separate, low noise power supply), but this time located on the VIM, with retaining the miniRCA connectors it would be possible to upgrade the signal path in a simple way. The board is so much self contained that only minimal modification would be needed to the VIM: adding only three resistors and tapping certain control signals, and of course the video input.
The VCA824 multiplier has 700MHz bandwidth (even better than the AD834, while cheaper than that!) and offers easily adjustable gain (beyond unity), which was torublesome on both AD834-835. Also very low noise.
The signal switch is called TMUX154E, which also appears to be an excellent switch with good isolation (which is further augmented by double switching scheme), 900MHz bandwidth, while having low on channel resistance and low input capacitance.
Overall I'd expect even better bandwidth performance as possible with the VNB-DB but at a lower labour.
blank PCB waiting for populating the components |
111.25 KB |
10497 Time(s) |
nidi
Link Posted: Tue Aug 06, 2019 6:02 pm Post subject: |
Fantastic , sounds very interesting.
It's great we Marquee owners still have things to look forward to.
nidi
so how long has this pcb to wait to be populated?
Link Posted: Wed Aug 07, 2019 10:55 am Post subject: |
nidi wrote: | so how long has this pcb to wait to be populated? |
As soon as I'll have my electronics stuff in the new house
Meemil
Link Posted: Wed Aug 07, 2019 3:00 pm Post subject: |
Big ups for this, absolutely great stuff!
Link Posted: Thu Aug 08, 2019 3:51 am Post subject: |
Now if some one would just mod a SONY 1031 ;P
Link Posted: Thu Aug 08, 2019 6:06 am Post subject: |
AnalogRocks wrote: | Now if some one would just mod a SONY 1031 ;P |
The VNB-DB was designed for cross-platform (Sony, Barco, etc) operation in mind, although my first idea wasn't exactly the 1031
Regardless, so far I've only made VNB-DB for Electrohome and I believe it will stay like that, although the door is open for the possibilities
nidi
Link Posted: Fri Aug 09, 2019 6:31 pm Post subject: |
one board for Marquee, Sony & Barco ?
wouldn't that be sweet!
so when's the big move of the electronics stuff to the house?
can't wait!
HaydnG90
Link Posted: Fri Aug 09, 2019 11:06 pm Post subject: |
Sony please
Link Posted: Sat Aug 10, 2019 5:24 am Post subject: |
nidi wrote: | one board for Marquee, Sony & Barco ?
The VNB-DB family was meant just like that. I've briefly evaluated the possibility adding Marquee VNB (the best possible neck card) to Sony and Barco. In fact I've almost finished -on theoretical basis at least- the needed modifications for fitting in to a Barco 909, and the Sony G90 way does not look impossible either. But without a test chassis (or a helper with deep understanding) it would be really hard to fully finish such project.
Link Posted: Sat Aug 10, 2019 7:22 am Post subject: |
gjaky wrote: | nidi wrote: | one board for Marquee, Sony & Barco ?
The VNB-DB family was meant just like that. I've briefly evaluated the possibility adding Marquee VNB (the best possible neck card) to Sony and Barco. In fact I've almost finished -on theoretical basis at least- the needed modifications for fitting in to a Barco 909, and the Sony G90 way does not look impossible either. But without a test chassis (or a helper with deep understanding) it would be really hard to fully finish such project. |
Have you ever built this for any Barco?
Link Posted: Sat Aug 10, 2019 9:27 am Post subject: |
km987654 wrote: | gjaky wrote: | nidi wrote: | one board for Marquee, Sony & Barco ?
Have you ever built this for any Barco? |
I haven't built it (yet), but worked out an easy and cheap way to power the Marquee VNBs in the Barco. I also have enough Marquee VNBs to supply such an experiment. I also figured out the needed modifications to interface the daughterboards to the Barco (using 909 style switcher and driver boards).
As usual, these ideas not necessarily mean it will work right away, so a 909 test chassis would be needed (what I don't have) to finalize such idea, or someone who can also understand what is going on the projector to some extent (and be able to take measurements and solder) so we could work out arising problems remotely at least.
nidi
Link Posted: Fri Aug 16, 2019 5:51 pm Post subject: |
any updates on the project, Gabor?
moved that vintage electronics stuff to the house?
Link Posted: Fri Aug 16, 2019 7:10 pm Post subject: |
nidi wrote: | any updates on the project, Gabor?
moved that vintage electronics stuff to the house? |
Stuff is only partly moved, the Marquee is still over there...
nidi
Link Posted: Fri Aug 23, 2019 5:45 pm Post subject: |
how many people are still out there using 9" CRTprojector?
Marquee? Sony G90? Barco 909 /Cine 9?
who is interested in a mod for the Sony or Barco ?
digitalayon
Link Posted: Fri Aug 23, 2019 6:30 pm Post subject: |
nidi wrote: | how many people are still out there using 9" CRTprojector?
who is interested in a mod for the Sony or Barco ? |
VVI here!!
digitalayon
Link Posted: Fri Aug 23, 2019 6:32 pm Post subject: Re: The VIM-DB |
gjaky wrote: | Not that modifying CRT projectors are still a hot topic, but I have to entertain myself with something...
Overall I'd expect even better bandwidth performance as possible with the VNB-DB but at a lower labour. |
I thought you had Mike Parker modded cards and VIM.
digitalayon
Link Posted: Fri Aug 23, 2019 6:36 pm Post subject: Re: The VIM-DB |
Link Posted: Fri Aug 23, 2019 8:01 pm Post subject: Re: The VIM-DB |
digitalayon wrote: | gjaky wrote: | Not that modifying CRT projectors are still a hot topic, but I have to entertain myself with something...
I thought you had Mike Parker modded cards and VIM. |
No, I never had any MP modded boards, really.
nidi
Link Posted: Wed Aug 28, 2019 4:44 pm Post subject: |
Gabor, any chance of a pic of the populated board?
