rotoscoped
Link Posted: Thu Mar 07, 2019 2:19 am Post subject: WTB: Set of HD10L lenses |
I have a Marquee 9500LC that came with GT17s, and I'm projecting to a 72" wide (horizontal) screen. A lot of soft focus around the edges. It seems like HD10Ls (maybe Es?) are what I should be using for this screen size.
The projector was given to me by a kind person, and I'd like to continue to keep the hobby inexpensive.
I'm willing to travel to northeast NC or anywhere in VA (other than extreme west of the state) for pick up. Depending on shipping costs, will consider that route too.
Link Posted: Thu Mar 07, 2019 2:23 am Post subject: |
I don't think that's your issue. Check the Scheimpflug adjustments. The GT17 should be able to do fine at 72" wide. there's a sticky thread called 'all about lenses' in the CRT forum that has all the specs of the lenses. Double check there before you spend money .
The Scheimpflug is a royal PITA on the Marquees, but follow the manual to the letter, and you'll be fine.
rotoscoped
Link Posted: Thu Mar 07, 2019 2:59 am Post subject: |
Thank you for the reply, Curt. The image is very good on the Marquee other than slight red/blue hot spots and the softer focus at edges. I certainly never mastered the Scheimpflug adjustment. I'll continue to read about it and make further adjustments.
Link Posted: Thu Mar 07, 2019 1:55 pm Post subject: |
Guys
GT17s are hitting the stops at around a 98" throw distance, so check that next. HD10Ls may be preferable inside of 105" throw. I have some HD10Es here at $750 for three.
Link Posted: Thu Mar 07, 2019 7:02 pm Post subject: |
I have a couple of sets of 10L's and I'm right across the WW Wilson Bridge 95north into Maryland -- 8 miles from Virginia.
The GT17 lenses were designed to take over where the 10L's came up short.
rotoscoped
Link Posted: Fri Mar 08, 2019 2:13 pm Post subject: |
Thanks for your replies. I'm right in that 98" to 105" window -- something around 100" or 101". I'm going to work on the Scheimpflug and see if I can get the edges sharper. I will say, center focus across all three tubes is good. Hopefully I can continue with the GT17s, but good to know there are HD10Ls relatively close by. (This 9500LC apparently has your VIM and neck board mods, Mike -- I got it from someone who had it refurbed and retubed in the mid-2000s and that was among the things I was told about the projector.)
Link Posted: Sat Mar 09, 2019 9:46 am Post subject: |
Sounds like a good plan. The "HD" series lens setup or throw distance requirements, were never set in stone because the lens themselves were kind of all over the place, with there being so many revisions of them. And depending on which setup manual or chart you used that was from Electrohome, you could find the words "Simulate" used in the setup instructions where the intent was to place the projector to the screen to determine proper throw distance, with projector being connected the the actual source that will be used. The throw distance chart was recommended only as a reference or idea, but that there was more work to get things right.
So by working with the projector further, you'll get to know the projector better and it's the best way to know for sure if you'll need a different set of lenses.
rotoscoped
Link Posted: Wed Mar 13, 2019 6:08 pm Post subject: |
I spent some time working on Scheimpflug and the electronic RGB focus. Definitely managed to improve the edge sharpness -- it was the electronic focus that was the main issue. It's better dialed in that it has been, with further improvement possible. The GT17s seem to be doing fine (though they are about at their stops). So if someone has a set of HD10Ls they're trying to get rid of in Virginia, I remain interested, just to see if there's any optical improvement. Thanks everyone for suggestions and notes.
