My NEC needs help.
Tom C.
PostLink    Posted: Sun Feb 24, 2019 11:05 pm    Post subject: My NEC needs help. Reply with quote
Hello all. This my first post in a long while . Im an NEC owner... I think I killed it while moving it recently .
Im a little bummed out. My 6PG Xtra slid down a 4 step staircase and landed on the basement floor . It looks okay on the outside but will not power on . No signs of life ... I do have the service manuals and a multimeter. Ive removed the necessary covers to start diagnostics .. To be honest this is the first projector i have to diagnose ..its been great for over 12 years since I had it retubed in 2007 . Id like to save it if possible. Any pointers are appreciated. Thank you
Tom
PostLink    Posted: Mon Feb 25, 2019 7:23 am    Post subject: Reply with quote
When plugged in does the standby lamp comes on at the back of the unit?
The MOD: VNB-DB
Tom C.
PostLink    Posted: Mon Feb 25, 2019 12:11 pm    Post subject: Reply with quote
I may have used a bad power cord . Switching to another cord . the unit does now light up rear panel...showing 00 code. When i press the rear power button it does power on temporarily then shuts down . with no input connected ... Showing code F6 .. my situation is looking better .
PostLink    Posted: Mon Feb 25, 2019 12:39 pm    Post subject: Reply with quote
Have you tried to look inside the set, if there is anything loose or broken?
The MOD: VNB-DB
Tom C.
PostLink    Posted: Mon Feb 25, 2019 12:50 pm    Post subject: Reply with quote
I will go through it tonight ... before i connect an input signal. Thank you for helping out.
PostLink    Posted: Tue Feb 26, 2019 4:27 am    Post subject: Reply with quote
Hello
I am concerned that the jolt of dropping it may have cracked a tube or broken an electron gun; I would inspect the tubes very thoroughly and look into the lenses with a flashlight.
Tom C.
PostLink    Posted: Wed Feb 27, 2019 2:25 am    Post subject: Reply with quote
My green tube is toast. When I power on with the rear button and the deflection board raised up i can see fireworks where the bell meets the stem of greencrt tube . Within seconds the unit powers off with both red lights flash on the deflection board. The error code shows Fd
PostLink    Posted: Wed Feb 27, 2019 2:39 pm    Post subject: Reply with quote
Drat
You have either cracked the tube glass or the metal conductor from the anode attachment is loose.
