HaydnG90
Link Posted: Fri Jan 25, 2019 2:30 am Post subject: G90 and odd behavior |
This is a new one on me. If I leave the G90 in standby for several days its unresponsive to power switch on both remote and on board control panel. I have to toggle the on/off switch and then normal service resumes. Anyone seen this issue before? No error codes.
deronmoped
Link Posted: Fri Jan 25, 2019 6:26 am Post subject: |
It sounds like some computers I have had, well a lot of computers I have had. There is always some odd behavior. The computer I'm on right now, the CD tray does not know if it wants to stay in or out.
Link Posted: Fri Jan 25, 2019 3:22 pm Post subject: |
Have you changed the Dallas chip? If not, do so immediately.
HaydnG90
Link Posted: Fri Jan 25, 2019 6:50 pm Post subject: |
Dallas chip was replaced 4 months ago. Got it from Mouser and had my original file copied over to it.
Link Posted: Fri Jan 25, 2019 10:06 pm Post subject: |
My guess is that the Ya board is starting to die. I've argued in the past with Craig (Rounds) about this, but I've seen the SMT caps go close to open on the RGB board. I can only imagine that the Ya board is close to doing the same thing on some sets. He hasn't seen it yet (or at least as of 2 years ago when we discussed it)
My guess is to keep using it until it dies completely, then send it to Craig. The IR and wired remote signals go right to the YA board, so it's a likely suspect.
HaydnG90
Link Posted: Fri Jan 25, 2019 10:25 pm Post subject: |
I have a spare working YA board (thanks to JohnHWman) so if it does kick the bucket I have a test board. So the internal control pad isn't hard wired to the YA?
Link Posted: Sat Jan 26, 2019 1:46 am Post subject: |
It is, but the data stream, whether from the IR sensors or the keypad are the same. In the menus, you can shut off the front or back IR sensors, that might make a difference.
HaydnG90
Link Posted: Sat Jan 26, 2019 2:28 am Post subject: |
Started fine after 24 hours in standby. I think your failing capacitor suggestion is likely correct.
HaydnG90
