NEC XG52 shutoff and error code
paiaboy7
PostLink    Posted: Mon Nov 26, 2018 8:59 pm    Post subject: NEC XG52 shutoff and error code Reply with quote
I have a NEC XG52 CRT projector currently not working. As soon as you try to turn on the power, it starts to power up then just immediately shuts itself off. It will cycle a couple of times trying to turn on but nothing else happens. It was working fine then this issue came up all of a sudden. The picture shows the error code that comes up on the rear display of the projector. Any suggestions? Thanks!
 Filesize:  54.99 KB
 Viewed:  1637 Time(s)
PostLink    Posted: Tue Nov 27, 2018 4:52 am    Post subject: Reply with quote
Is that a CC error or FC?
paiaboy7
PostLink    Posted: Wed Nov 28, 2018 1:20 am    Post subject: Reply with quote
It seemed like a cc but the bottom segment of the first c wasn't lit up.
PostLink    Posted: Wed Nov 28, 2018 11:26 pm    Post subject: Reply with quote
A really tough call then. It could be FC, which is a problem on the +15 volt line. That could be almost any board in the set, and is very hard to troubleshoot.
I have no more XG parts at this point other than remote controls, so it will be up to a scrap set that someone might have here to get you going again.
http://www.curtpalme.com/docs/NECXG_Error_Codes.pdf
paiaboy7
PostLink    Posted: Thu Nov 29, 2018 12:01 am    Post subject: Reply with quote
Thanks for checking. Is CC an easier fix?
pcheadaches
PostLink    Posted: Thu Nov 29, 2018 12:25 am    Post subject: Reply with quote
Try reseating the system board a few times.
PostLink    Posted: Thu Nov 29, 2018 12:34 am    Post subject: Reply with quote
CC is a system board error. I've never had that before, but i guess it's possible. Again, I have no parts, and the most common failure on XGs has been the system board, so finding a working system board will be tough.
Might be the time to go digital perhaps?
paiaboy7
PostLink    Posted: Thu Nov 29, 2018 6:07 pm    Post subject: Reply with quote
Thank you I'll try that
