Fixing the DVI signal from an Atari 8 bit computer, how?
jowi
PostLink    Posted: Sun Dec 16, 2018 1:43 pm    Post subject: Reply with quote
So far the only thing that works out of the box is an ancient HP LP2465 monitor... that displays the 1280x960 over DVI perfectly. Just connect the atari to the HP with a DVI cable... so there is hardware out there that can cope with this signal. I bought the HP 2nd hand on advice of the developer of the Atari DVI board, but is has over 90.000 hours on it (!) and has probably been running with 100% contrast and 100% brightness all the time... image has brown area's and it takes a few minutes to warm up... not ideal but it does work...
Arcam AVR850 Pioneer KURO KRP-600M KEF Reference Model 4/2/200c Velodyne DD15 HDI Dune 4K Solo Squeezebox Radio/Duet Wyrewizard Dreamcaster & Spellbinder (by Nordost) JVC D-ILA-X7500 HdFury Vertex
PostLink    Posted: Sun Dec 16, 2018 2:55 pm    Post subject: Reply with quote
nidi wrote:
Yep - have to say it looks pretty cool! Makes me want to boot up one of my C64s again... Wink
Kal, check this out,
this is awesome!
http://www.1541ultimate.net/content/index.php?option=com_content&view=article&id=74&catid=9&Itemid=127
Cool!
PostLink    Posted: Sun Dec 16, 2018 8:03 pm    Post subject: Reply with quote
jowi wrote:
According to the manual: http://static.highspeedbackbone.net/pdf/DVDOiScanVP30Manual.pdf (link says vp30 but document is vp50...) section 5 table 2, there is a mention of passthrough, but i can't find that option anywhere in the menu tree...
The vp50 does support 1280x960 as output.
I was just looking at the resolution table on page 8 of the manual. It says SXGA but only at 60Hz which does you no good.
I can't find the pass-through settings either.
I also had a look at the Atlona we use to use to convert 50hz to 60Hz AT-HD560 but it doesn't list 1280x960
Neither does the Atlona DVI550 nor the HD550. Guess there's no way the creator of the Atari DVI board could add 60Hz output? That would be way more compatible with everything.
 Filesize:  118.83 KB
 Viewed:  1799 Time(s)
PostLink    Posted: Sun Dec 16, 2018 8:16 pm    Post subject: Reply with quote
I was just on the http://atariage.com/forums/topic/258702-new-development-gtia-in-cpld/page-34#entry3916097
They say there's a 1536x960 50Hz signal coming out of the Sophia. Is that the module you are using?
jowi
PostLink    Posted: Sun Dec 16, 2018 8:26 pm    Post subject: Reply with quote
No, this is the version of the board i'm using: http://atariage.com/forums/topic/274004-sophia-revc-dvi-board/page-1
i've got 2 boards, 1280x960 and a 1280x1024, both at 50Hz, both have the same problems.
PostLink    Posted: Sun Dec 16, 2018 9:52 pm    Post subject: Reply with quote
You need a scaler that can convert 50 to 60Hz it seems.
jowi
PostLink    Posted: Tue Dec 18, 2018 4:28 pm    Post subject: Reply with quote
Maybe i'll just go the easy way and get me a good monitor (probably a NEC multisync) that can handle the signal, and just forget about connecting the Atari to the Pioneer Kuro or JVC projector over HDMI... if i do want to do that, i'll just use the HDMI input on the Dune Pro 4K mediaplayer, that accepts it as well, and route it to the Kuro or JVC that way...
PostLink    Posted: Tue Dec 18, 2018 4:38 pm    Post subject: Reply with quote
Lotta hoops to jump through...it would be nice if the developer could do the conversion on the DVI adaptor. I understand you're working with a PAL signal that's 50Hz to begin with but having 60Hz would make life easier.
jowi
PostLink    Posted: Wed Dec 19, 2018 11:42 am    Post subject: Reply with quote
Yep. The developer is a bit stubborn, basically he says if a monitor or tv can't display the signal, there is something wrong with that tv or monitor. Now i know he is limited by the atari's hardware and signals, but i'm 100% sure it can be solved at the dvi board. I think if he could output 576p50 (720x576) it would be fine, or 720p50. There is no need for larger resolutions anyway...
