Getting back into CRT :) Barco 909
PostLink    Posted: Thu Aug 16, 2018 9:36 am    Post subject: Reply with quote
JayAllan wrote:
Well... I found my DVDO VP50 and my VP30. Found both remotes and both power cords. Neither works. Sad They both power up but the VP30 screen flashes on and off and the VP50 shows "serious Error 16". Ugh.
I guess you know its a serious problem Laughing
barclay66
PostLink    Posted: Thu Aug 16, 2018 12:58 pm    Post subject: Reply with quote
Most problems of the DVDO VP series originate from crappy power supplies. Try to get a replacement with 6V and at least 8A or more...
Kind Regards,
barclay66
crtbilly
PostLink    Posted: Thu Aug 16, 2018 2:28 pm    Post subject: Reply with quote
Kind Regards,
barclay66
I can confirm this. I bought a cheap one off eBay for my vp50 and it seems to be holding up.
My vp50 had other problems but I knew that when I bought mine off eBay for $20. When I opened it up it had about 5 tantalum capacitor blown. Replaced and it's been working great.
I also have the latest firmware if interested.
ElTopo
PostLink    Posted: Thu Aug 16, 2018 3:54 pm    Post subject: Reply with quote
Have you checked the 909 with another source already ?
Barco Cine 9 the one and only
PostLink    Posted: Thu Aug 16, 2018 4:07 pm    Post subject: Reply with quote
Or, send me both supplies, and I'll rebuild them.
JayAllan
PostLink    Posted: Thu Aug 16, 2018 6:34 pm    Post subject: Reply with quote
Thanks guys! I figured it is likely the power supplies. I actually have 3 here and tried them all but they are all old and off brand. I will try the eBay route first and then if that doesn't work I will send them over to you Curt Smile I haven't tried another source yet ElTopo but I did find my RGB to BNC breakout cable. I am going to hook that up to a PC tonight once I find a long RGB cable to reach.
JayAllan
PostLink    Posted: Sun Aug 19, 2018 6:36 pm    Post subject: Reply with quote
Quick update:
I managed to hook this up to my PC with an RGB breakout cable. It looks to be working well! Going to move the projector into place tonight and put on the lenses. HFQ900HM. Just need to figure out the optimal throw distance. Smile
 Filesize:  474.13 KB
 Viewed:  2966 Time(s)
PostLink    Posted: Sun Aug 19, 2018 8:48 pm    Post subject: Reply with quote
Hell yeah! Very Happy
JayAllan
PostLink    Posted: Mon Aug 20, 2018 7:01 am    Post subject: Reply with quote
I moved the projector tonight into position roughly. I put the lenses on and powered it up.
I noticed right away looking at the tubes that the image is going outside the raster on at least one side (which if I recall is bad!)
So... I shut it down for now. Since I have never owned a Barco and it has been 6 years since I have setup a CRT,
I am going to have to dig in the manual to see how to shrink and move over the raster.
I am feeding it 1600x900 since that is the max my video card will apparently go through the RGB port.
ElTopo
PostLink    Posted: Mon Aug 20, 2018 10:58 am    Post subject: Reply with quote
Hey,
please be sure to center the image on the tubes.
Mostly if you center green (Raster Shift option "coarse" of "fine") the other two colors get touched also and should be centered. If not you can do raster shift on each color.
You can also use the Geometry option to shrink vertical and horizontal.
ElTopo
JayAllan
PostLink    Posted: Mon Aug 20, 2018 6:23 pm    Post subject: Reply with quote
Thanks ElTopo. Yes, I am not at all familiar with the Barco menus yet so I am reading up on them now so I can go in quick and shrink them down without the tubes on for long. That will be the first thing I do before working on focus.
PostLink    Posted: Mon Aug 20, 2018 6:57 pm    Post subject: Reply with quote
The other 6 splitpacks are here. Brought one across the border this AM, will set it up this weekend. Lots of interest with these units..
PostLink    Posted: Mon Aug 20, 2018 6:59 pm    Post subject: Reply with quote
Oh, and do a 'set to midposition, all' in the service menu, under the memory page. The keystone and everything else will be a mile off on these sets given the installation. No problem running to the edge of the tubes, but turn the contrast way down, to 10 or so, and you won't implode tubes.
JayAllan
PostLink    Posted: Mon Aug 20, 2018 8:20 pm    Post subject: Reply with quote
Awesome! I was going to ask you about that Smile I love the design of these units.
JayAllan
PostLink    Posted: Mon Aug 20, 2018 8:22 pm    Post subject: Reply with quote
Ok good to know. I was hoping there was some sort of "revert to factory" type setting. Its hard to even read the on screen menus at this point. I have NO IDEA how to set these up lol. I am having to re-educate myself on CRTs. It's been a while!
ElTopo
PostLink    Posted: Mon Aug 20, 2018 9:08 pm    Post subject: Reply with quote
1st = mechanichal focus on the lens
2nd = focusing inside the menu
After that reading should be no problem anymore Wink
PostLink    Posted: Mon Aug 20, 2018 10:18 pm    Post subject: Reply with quote
Aww, do I have to make another drive down? Very Happy
HaydnG90
PostLink    Posted: Mon Aug 20, 2018 11:05 pm    Post subject: Reply with quote
Whats the fan noise like vs a standard 909?
PostLink    Posted: Tue Aug 21, 2018 1:57 pm    Post subject: Reply with quote
Same amount of fans, but since you can place the electronics with the fans up to 2m away, it should be less noisy.
JayAllan
PostLink    Posted: Sat Aug 25, 2018 1:45 am    Post subject: Reply with quote
Not until I am ready to set up the stack! Wink Very Happy
Page 2 of 4
